PowerMouse
Old August 12th 20, 04:23 PM posted to rec.aviation.soaring
soaringjac
Default PowerMouse
With the PowerMouse with ADSB Module, what non-Flarm traffic will I be able to see and not see? Obviously I will be able to see ADSB traffic, but what about regular transponder equipped aircraft?
Old August 12th 20, 07:23 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default PowerMouse
3.2 ADS-B module
PowerMouse device has a possibility to have an internal ADSB module, which is the ADSB IN module. All four variants can have the ADSB.
ADS-B module is not a standard part of the PowerMouse, therefore when ordering you have to order PowerMouse with ADSB.
ADS-B can receive MODE S transponders with ADS-B OUT. You will see all traffic equipped with mode S transponders.
http://www.craggyaero.com/lxnav_flarm.htm
Richard
www.craggyaero.com
Old August 12th 20, 07:32 PM posted to rec.aviation.soaring
soaringjac
Default PowerMouse
3.2 ADS-B module
Richard
www.craggyaero.com
So you won't see transponder only traffic, they need to have transponder and adsb-out?
Old August 12th 20, 10:05 PM posted to rec.aviation.soaring
soaringjac
Default PowerMouse
3.2 ADS-B module
Richard
www.craggyaero.com
Ok I think I get it now. So the only "transponder only" aircraft I will see are the ones with Mode S transponders. I will not see people with only a Mode C transponder.
PowerMouse in certified glider soaringjac Soaring 1 July 15th 20 06:45 PM
File from PowerMouse - IGC? Dave Springford Soaring 5 May 22nd 20 11:04 PM
PowerFLARM Core or LXNAV PowerMouse Installation in Towplane Paul Remde Soaring 1 October 2nd 19 04:58 PM
LXNAV PowerMouse - U.S. F.C.C. Approved Paul Remde Soaring 11 August 24th 19 05:18 PM
IGC-approval for the LXNAV PowerMouse-IGC Flight Recorder Ian Strachan[_3_] Soaring 0 February 19th 18 11:48 AM
