Parajumper breaks legs???
Old April 26th 05, 04:22 AM
jerry wass
Default Parajumper breaks legs???
How did the jumper jump outa that plane, travel upward & forward & break
his legs on the L.E. of the wing outboard the engine nacele ???
'twas on the OK news last nite, but didn't catch where it happened..
Old April 26th 05, 04:37 AM
break
Jump from high altitude and the jump bird pilot will bring the bird
down to pattern altitude at a mind blowing desent rate. A jumper fully
tucked up can catch and even outrun the jump plane under the right
conditions. In this case, it appears that the a/c was already down in
the pattern and the jumper blew through the pattern altitude and struck
the a/c from overhead still in freefall.
Non-survivable injuries unless the EMT's just happened to be right
there when he landed.
Craig C.
Old April 26th 05, 06:15 AM
Morgans
What, broken legs, un-survivable? Were they massively bleeding, from
compound breaks or something?
Jim in NC
Old April 26th 05, 06:41 AM
Montblack
("Morgans" wrote)
AvWeb
http://www.avweb.com/newswire/11_17a.../189644-1.html
Florida skydiver Albert "Gus" Wing III, 50, died after he collided with the
wing of the Twin Otter that he jumped from Saturday morning, severing both
legs at the knees. After the impact at 600 feet, Wing controlled his
parachute to a landing but died from his injuries later at Halifax Medical
Center. The aircraft landed safely...
Montblack
Old April 26th 05, 02:51 PM
Dave S
If we are talking about the Skydive Deland incident, Then there are a
LOT of bits of misinformation that need to be tweaked here in these
first two posts.
The jumper, Gus Wing, was a veteran jumper. He and the Otter pilot are
both reputed to be saftey-freaks.
The jumper was serving as a photographer for a student/tandem jump and
was reportedly getting in position to film the student's landing. He was
under canopy (NOT in freefall) and the accident occured at either 600 or
1000 ft (depending on what version of the story). (Very few people would
DARE freefall at 600 ft AGL, I speculate)
The Otter Checklists I've seen call out a landing speed of 90 kts, and
approach speeds anywhere from 100-140 knots depending on phase of
approach. The story is that his legs were hit by the leading edge of the
otter, severing them partially or totally. The jumper was able to land,
but died at the hospital.
Those bits were gleaned from Usenet, CNN, Local media and Dropzone.com.
I am not a jumper and live over 800 miles away and have no personal
connection to any of this.
The rest is my opinion and speculation.
Now.. from a medical standpoint, A traumatic amputation usually mangles
things in the process.. torn blood vessels dont have as much of a
tendency to "self seal" as do tranversely CUT ones (like cutting a
vessel with a razor).. and the Femoral (and further down, the Popliteal)
arteries are large vessels that can flow a lot of volume. Your heart
can pump your entire blood volume in a minute. If there is a big enough
hole, you really CAN bleed out that fast.
Couple that with torn vessels, mangled legs, the probablility that for
the first minute or two (or maybe longer.. people who jumped from the
same plane reported hearing sirens as they landed.. so help was CLOSE)
the people arriving are NOT trained medical personnel who would KNOW to
apply direct pressure to pressure points (above the injury) to try to
stop the bleeding (rather than trying to stem it with direct pressure at
a mangled injury site).
Couple this again with responding medical personnel only having IV
fluids to try and raise blood pressure.. IV fluids dont carry oxygen..
hemoglobin does.. and right now there are no acceptable blood
substitutes out there (there have been recent trials, but no marketed
product).. all this leaves you with a diminishing chance of survival.
My speculation is that unless Mr. Wing had paradropped into a MASH unit,
he was doomed by his injury, having significantly bled out in the last
minute of his descent. Even if a trained paramedic crew was right there
and on the scene immediately, they would have had a hell of a fight (to
save him) on their hands.
Dave
break
Craig C.
Old April 26th 05, 03:30 PM
Ron Natalie
A paramedic crew can't do squat except try to stop things from getting any
worse while rushing him to a surgical (preferably trauma staffed)
facility. Unlike cardiac and other medical cases where the paramedics
have stuff they can do to actually treat in the field, it's still pretty
much swoop and scoop for large-scale trauma.
Old April 26th 05, 11:38 PM
Dave S
Ron Natalie wrote:
unit, he was doomed by his injury, having significantly bled out in
the last minute of his descent. Even if a trained paramedic crew was
right there and on the scene immediately, they would have had a hell
of a fight (to save him) on their hands.
I agree 100% Before I started working as a nurse in trauma centers, I
was an active paramedic (and still maintain my paramedic credentials to
this day). You see and do a lot in 15 years.
Dave
Old April 26th 05, 11:21 AM
Matt Whiting
Most jump planes dive for the ground after release, and it is likely the
airplane ran him down.
Matt
Old April 26th 05, 01:37 PM
Nick Funk
I have seen jump planes beat the sky diver down. Many times I have seen
the pilot put a plane (Cessna) into a spin from 10,000 to 12,000 feet
and pull at about 1500 feet, usually near the downwind leg of the
pattern. Many times the plane is on the runway before the sky diver
touches down.
Old April 26th 05, 06:44 PM
LCT Paintball
the pilot put a plane (Cessna) into a spin from 10,000 to 12,000 feet and
When you say spin, do you mean a controlled radial decent, or an O-Crap I'm
in a spin?
Need Gear Legs for '59 Cessna 150 Burt Compton Aviation Marketplace 0 March 22nd 04 03:03 PM
Cessna landing gear legs Reserve MET! Bill Berle Aviation Marketplace 0 February 22nd 04 07:50 PM
Cessna landing gear legs Reserve MET! Bill Berle Restoration 0 February 22nd 04 07:50 PM
Wanted: Gear Legs 1959 C-150 Burt Compton Home Built 0 December 29th 03 04:32 PM
Wanted: Gear Legs C-150 (1959) Burt Compton Aviation Marketplace 0 December 29th 03 04:18 PM
