https://en.wikipedia.org/wiki/Sikorsky_H-19_Chickasaw
he Sikorsky H-19 Chickasaw (company model number S-55) was a multi-purpose helicopter used by the United States Army and United States Air Force. It was also license-built by Westland Aircraft as the Westland Whirlwind in the United Kingdom. United States Navy and United States Coast Guard models were designated HO4S, while those of the U.S. Marine Corps were designated HRS. In 1962, the U.S. Navy, U.S. Coast Guard and U.S. Marine Corps versions were all redesignated as H-19s like their U.S. Army and U.S. Air Force counterparts. Development of the H-19 was initiated privately by Sikorsky without government sponsorship. The helicopter was initially designed as a testbed for several novel design concepts intended to provide greater load-carrying ability in combination with easy maintenance. Under the leadership of designer Edward F. Katzenberger, a mockup was designed and fabricated in less than one year. The first customer was the United States Air Force, which ordered five YH-19 aircraft for evaluation; the YH-19's first flight was on 10 November 1949, less than a year after the program start date. This was followed by delivery of the first YH-19 to the U.S. Air Force on 16 April 1950 and delivery of the first HO4S-1 helicopter to the U. S. Navy on 31 August 1950. A U.S. Air Force YH-19 was sent to Korea for service trials in March 1951, where it was joined by a second YH-19 in September 1951. On 27 April 1951, the first HRS-1 was delivered to the U.S. Marine Corps, and on 2 May 1951, the first S-55 was delivered to Westland Aircraft. 1,281 of the helicopters were manufactured by Sikorsky in the United States. An additional 447 were manufactured by licensees of the helicopter including Westland Aircraft, the SNCASE in France and Mitsubishi in Japan. The helicopter was widely exported, used by many other nations, including Portugal, Greece, Israel, Chile, South Africa, Denmark and Turkey. In 1954 the Marines tested an idea to enhance lift in hot and high and/or heavily loaded conditions by installing a rocket nozzle at the tip of each rotor blade with the fuel tank located in the center above the rotor blade hub. Enough fuel was provided for seven minutes of operation. Although tests of the system were considered successful, it was never adopted operationally. The YH-19 prototypes featured a blunt aft fuselage and a single starboard-mounted horizontal tailplane with a small vertical fin at its outboard end. Initial production models added a large fillet-like fin behind the fuselage and under the tailboom, and the tailplane configuration was changed to an inverted "V" shape. Early H-19 and HO4S variants were powered by a Pratt & Whitney R-1340-57 radial rated at 600 hp (472 kW) and used a centrifugal clutch that automatically engaged the main rotor when a preset engine speed was reached. However, the HO4S was deemed underpowered in U.S. Navy service with this powerplant, so the aircraft was re-engined with a 700 hp (522 kW) Wright R-1300-3 radial which the U.S. Navy found to be adequate in an air-sea rescue role; the H-19B, HO4S-3, HRS-3, and subsequent models would use this powerplant. The R-1300 models also used a single horizontal tailplane in place of the early inverted "V" style, and a new hydro-mechanical clutch gave smoother and more rapid rotor acceleration during clutch engagement and allowed the engine to be started and operated at any speed while disengaged from the transmission and rotors. Early civilian and military S-55 models offered a folding 400 lb (181 kg) capacity hoist above the starboard main cabin door, while later models could be equipped with a more capable and reliable 600 lb (272 kg) capacity unit. Starting with the introduction of the S-55C in October 1956, the tailboom was inclined three degrees downward to provide more main rotor clearance during hard landings; models equipped with the inclined tail also used an 8 ft 9 in (2.67 m) tail rotor in place of the earlier 8 ft 8 in (2.64 m) unit. Role Utility helicopter Manufacturer Sikorsky Designer Edward F. Katzenberger First flight 10 November 1949 Introduction 16 April 1950 (U.S. Air Force) Retired 26 February 1969 (U.S. Navy) Number built 1,728 Variants Westland Whirlwind Developed into Sikorsky H-34 The H-19 Chickasaw holds the distinction of being the U.S. Army's first true transport helicopter and, as such, played an important role in the initial formulation of Army doctrine regarding air mobility and the battlefield employment of troop-carrying helicopters. The H-19 underwent live service tests in the hands of the 6th Transportation Company, during the Korean War beginning in 1951 as an unarmed transport helicopter. Undergoing tests such as medical evacuation, tactical control and frontline cargo support, the helicopter succeeded admirably in surpassing the capabilities of the H-5 Dragonfly which had been used throughout the war by the Army. The U.S. Marine Corps made extensive use of the H-19 in the Korean War. It was designated as the HRS in USMC service. Marine Squadron HMR-161 arrived in Korea on September 2, 1951 with 15 HRS-1 helicopters. The new helicopter squadron started operations upon arrival. On September 13, 1951, during Operation Windmill I, HMR-161 transported 18,848 pounds of gear and 74 Marines onto a ridge in the Punchbowl area. A week later HMR-161 shuttled 224 recon company marines and 17,772 pounds of supplies to a remote hilltop in the same area. Their performance continued to improve and in Operation Haylift II in February 23-27, 1953, HMR-161 lifted 1.6 million pounds of cargo to resupply two regiments. Although HMR-161 helicopters were operating in hot landing zones they did not lose any helicopters to enemy fire. HRS-1 helicopters were also used to relocate rocket launcher batteries. Because rockets create much visible dust when fired they make an easy target for enemy artillery. To reduce their exposure, launchers and crews were moved twice a day. Each HRS-1 helicopter carried four rocket launchers and extra rockets as external cargo, with the crew in the cabin. The HRS-1 helicopter proved to be durable and reliable in Korean service. One reportedly flew home after losing 18 in (46 cm) of main rotor blade to a tree. HMR-161 reported 90% aircraft availability. The U.S. Air Force ordered 50 H-19A's for rescue duties in 1951. These aircraft were the primary rescue and medical evacuation helicopters for the USAF during the Korean War. The Air Force continued to use the H-19 through the 1960s, ultimately acquiring 270 of the H-19B model. On 1 September 1953, Sabena used the S-55 to inaugurate the first commercial helicopter service in Europe, with routes between Rotterdam and Maastricht in the Netherlands and Cologne and Bonn in Germany. The H-19 was also used by the French forces in the First Indochina War. A small number of war-worn H-19s were given to the Republic of Vietnam Air Force in 1958, when the French military departed. These saw very limited service in the early days of the Vietnam War, before being supplanted by the more capable Sikorsky H-34 Choctaw. The H-19 left U.S. military service when the CH-19E was retired by U.S. Navy squadron HC-5 on 26 February 1969. Surplus H-19s were sold on the open market, and civil interest was sufficient that Sikorsky (and later Orlando Helicopter Airways) offered conversion kits allowing a military surplus H-19 to be commercially operated under a standard Federal Aviation Administration type certificate as an S-55B. Turboshaft conversions and a novel campervan-like "Heli-Camper" conversion—featuring a built-in mini-kitchen and sleeping accommodations for four—were also offered by aftermarket modification companies. Specifications (UH-19C) General characteristics Crew: 2 Capacity: ten troops or eight stretchers Length: 42 ft 2 in (12.85 m) fuselage length excluding tail and main rotors ; (UH-19D 42 ft 3 in (12.88 m)) Height: 13 ft 4 in (4.06 m) Empty weight: 4,795 lb (2,175 kg) (UH-19D 5,250 lb (2,380 kg)) Gross weight: 7,500 lb (3,402 kg) (UH-19D 7,900 lb (3,600 kg)) Powerplant: 1 × Pratt & Whitney R-1340-57 9-cylinder air-cooled radial piston engine, 600 hp (450 kW) (UH-19D Wright R-1300-3 Cyclone 7-cylinder air-cooled radial piston engine, 700 hp (520 kW))Main rotor diameter: 53 ft (16 m) Main rotor area: 2,206 sq ft (204.9 m2) Tail rotor diameter: 8 ft 8 in (2.64 m) Performance Maximum speed: 101 mph (163 km/h, 88 kn) (UH-19D 112 mph (97 kn; 180 km/h)) Cruise speed: 85 mph (137 km/h, 74 kn) (UH-19D 91 mph (79 kn; 146 km/h)) Range: 450 mi (720 km, 390 nmi) (UH-19D 385 mi (335 nmi; 620 km)) Service ceiling: 10,500 ft (3,200 m) (UH-19D12,500 ft (3,800 m)) Armament None normally fitted ; H-19s used for armament tests at Fort Rucker were experimentally equipped with a variety of automatic weapons and rockets. H-19s in Southeast Asia were sometimes equipped with door-mounted .30 in (7.62 mm) or ..50 in (12.70 mm) calibre machine-guns for self-defence and suppression of enemy fire near landing zones. * |
Sikorsky H-19/S-55 Chickasaw pics [4/9] - Sikorsky H-19 Chickasaw.jpg (1/1) | Miloch | Aviation Photos | 0 | November 23rd 17 03:32 PM |
Sikorsky H-19/S-55 Chickasaw pics [3/9] - Sikorsky H-19 Chickasaw 3.jpg (1/1) | Miloch | Aviation Photos | 0 | November 23rd 17 03:32 PM |
Sikorsky H-19/S-55 Chickasaw pics [2/9] - Sikorsky H-19 Chickasaw 2.jpg (1/1) | Miloch | Aviation Photos | 0 | November 23rd 17 03:32 PM |
Sikorsky H-19/S-55 Chickasaw pics [1/9] - A Sikorsky S-55B in service with Golden West Helicopters, St. Albert, Alberta, 1985. Fairings for transmission and tail rotor driveshaft have been removed; note later-style downward-inclined tailboom..jpg (1/ | Miloch | Aviation Photos | 0 | November 23rd 17 03:30 PM |
Sikorsky H-19/S-55 Chickasaw | Miloch | Aviation Photos | 0 | November 23rd 17 03:28 PM |
