Any comments pro or con about the Appleboy nose release?
Reportedly there are some PIK's, ASW's, LS's and Zuni's out there with them. Had the same request on gliderforum.com for a few days. A few views, but no comments. Perhaps someone here that I haven't already had an exchange with? TIA, Frank |
![]() F.L. Whiteley wrote: Any comments pro or con about the Appleboy nose release? Reportedly there are some PIK's, ASW's, LS's and Zuni's out there with them. Had the same request on gliderforum.com for a few days. A few views, but no comments. Perhaps someone here that I haven't already had an exchange with? TIA, Frank There is one on my ASW 20. I have not used it to many times but it seems to work fine. It is a real pain to open it for the hook-up. Once it releases and retracts there is nothing to grab a hold of to extend it. A pocket knife or small screwdriver blade is needed to pull it out of the fuselage far enough that you can open it. Craig- |
Is the Applebay hook similar to the Schreder design?
http://www.soaridaho.com/Schreder/Sc...76_Page_29.JPG wrote in message ps.com... F.L. Whiteley wrote: Any comments pro or con about the Appleboy nose release? Reportedly there are some PIK's, ASW's, LS's and Zuni's out there with them. Had the same request on gliderforum.com for a few days. A few views, but no comments. Perhaps someone here that I haven't already had an exchange with? TIA, Frank There is one on my ASW 20. I have not used it to many times but it seems to work fine. It is a real pain to open it for the hook-up. Once it releases and retracts there is nothing to grab a hold of to extend it. A pocket knife or small screwdriver blade is needed to pull it out of the fuselage far enough that you can open it. Craig- |
Earlier, Wayne Paul wrote:
Is the Applebay hook similar to the Schreder design? I think it's similar but not identical. George has said that he's not familiar with the Schreder hook design. My memory of hooking up Z2 at Sky Sailing (we're talking 1979 or so) is that the Applebay hook is similar on the outside to the Schreder -455 hook, but I have no clue what's on the inside. By the way, one of the Schreder apprentices (I can't remember which, though it might have been Australian Ross Nolan) once told me that Dick saw the -455 hook in a dream, and drew all its parts out that afternoon. That would have been between about 1958 and 1962. Dick used that exact hook design in all subsequent HP designs through about the HP-20 in 1984 or so. About five years ago I sold one of the SparrowHawk guys a set of drawings for the -455 hook. They seem to have used that same basic design, though resized and optimized for their lighter weights and lower loadings. Thanks, and best regards to all Bob K. http://www.hpaircraft.com |
George admits that it's 'borrowed' from the Schreder design.
Frank Wayne Paul wrote: Is the Applebay hook similar to the Schreder design? http://www.soaridaho.com/Schreder/Sc...76_Page_29.JPG wrote in message ps.com... F.L. Whiteley wrote: Any comments pro or con about the Appleboy nose release? Reportedly there are some PIK's, ASW's, LS's and Zuni's out there with them. Had the same request on gliderforum.com for a few days. A few views, but no comments. Perhaps someone here that I haven't already had an exchange with? TIA, Frank There is one on my ASW 20. I have not used it to many times but it seems to work fine. It is a real pain to open it for the hook-up. Once it releases and retracts there is nothing to grab a hold of to extend it. A pocket knife or small screwdriver blade is needed to pull it out of the fuselage far enough that you can open it. Craig- |
Hi Craig,
I had an HP-14 and presently have a Zuni. Their hooks were functionally indentical, though of mildly differing geometry. Both ships' hooks could be opened, latched into place and connected to a ring without resort to an opening tool. Rather than *pulling* the hook open, try PUSHing it open from the aft end. Once the plate with the cutout for the ring comes into view, you can continue rotating that plate until it latches. (It's easier to see/do than describe or visualize.) Those times I've forgotten to open the hook prior to pulling into place for hookup and am in the cockpit ready to go only to see the puzzled face of the hookup person pop back up, I've merely (as above) described how to get the hook started, told them there's nothing I can do from the cockpit to help them, and seconds later I can hear the hook click into it's 'open' position. Sometimes they also need verbal assistance making the actual connection...but you probably already know how to do that. Regards, Bob Whelan |
I had George install a Zuni in my ASW19 just last year.
I wanted to have both a CG and a nose hook. I really wasn't all that comfortable with just a CG release since I was 'raised' on a nose hook and just didn't like the feel of the CG hook. The very first time I used the Zuni I had an inadvertent release at about 900-1000 feet AGL. I had let the glider get a little higher than it should have been, but I clearly remember being able to see the tow plane. I would have released in a hurry had I lost sight of it. Turns out the tension spring (on mine) is just too weak, and it will release with very little back pressure. I found this to be reason enough not to use it again until it is replaced with a much stronger spring. Unfortunately it will have to wait until I make the 1000 mi trek to Moriarty one day. Replacement of the spring requires two small holes to be cut into the fuse, opposite the ends of the spring in order to unscrew the retaining bolt and nut. I'm not comfortable doing it myself. Now all I use the nose hook for is to be pulled over to the grid. |
Les Walker wrote:
I had George install a Zuni in my ASW19 just last year. I wanted to have both a CG and a nose hook. I really wasn't all that comfortable with just a CG release since I was 'raised' on a nose hook and just didn't like the feel of the CG hook. The very first time I used the Zuni I had an inadvertent release at about 900-1000 feet AGL. I had let the glider get a little higher than it should have been, but I clearly remember being able to see the tow plane. I would have released in a hurry had I lost sight of it. Turns out the tension spring (on mine) is just too weak, and it will release with very little back pressure. I found this to be reason enough not to use it again until it is replaced with a much stronger spring. Unfortunately it will have to wait until I make the 1000 mi trek to Moriarty one day. Replacement of the spring requires two small holes to be cut into the fuse, opposite the ends of the spring in order to unscrew the retaining bolt and nut. I'm not comfortable doing it myself. Now all I use the nose hook for is to be pulled over to the grid. Les, Could you elaborate a bit more? What type of ring in use? Tow rope, that is, with weak or without weak link at glider end, or whiffle ball or some other rope protection? Thanks, Frank |
Hi Frank,
Didn't see the request on gliderforum.com. Where was it? What are you thinking of putting one in? There are lots of similarities between the Schreder hook and Applebay's version. George made his so that it will auto-release if the pull is too much "down". Trying to protect the towpilot. Les, I suspect the issue is not so much the spring, but is it possible that when you got high, you leveled off for a moment, and got slack in the rope? The weight and drag of the loop may have caused the release? A bit about the release. There are two springs in the design. A torsion spring to close the release, and a tension spring to hold the locking arm in position. There is not any slope on the mating faces of the locking arm and the forward, load carrying part of the hook, so it should not have released unless there was a load to pull the rope down the slot, or the release got tripped by the locking arm being pulled. As for adjustments, remember, there are two ends to a spring. The other end should be easily accessable at the top of the locking arm. You can shorten this spring to increase the tension holding the locking arm in place. Craig, as Bob said, try pushing in at the back of the release. There is plenty of room inside the nose for you to push it most of the way into position from the back end of the release. There is one improvement I think can be made to the design. It will be much easier for the line crew to hook up if a mechanical stop is installed that prevents the forward part of the hook from rotating aft as you push the cover plate back to insert the tow ring. If you look at the geometry, of the hook, you will see what I am talking about. This stop can take several forms. The simplest is a change to the shape of the forward part of the hook. There is also one installed on a Mosquito at my field. My opinion is they work just fine. I have never had any troubles with mine and I have about 1100 hours in my Zuni and probably 300+ flights. Steve Leonard Zuni 2, Serial 28 |
Steve Leonard wrote:
Hi Frank, Didn't see the request on gliderforum.com. Where was it? What are you thinking of putting one in? There are lots of similarities between the Schreder hook and Applebay's version. George made his so that it will auto-release if the pull is too much "down". Trying to protect the towpilot. Les, I suspect the issue is not so much the spring, but is it possible that when you got high, you leveled off for a moment, and got slack in the rope? The weight and drag of the loop may have caused the release? A bit about the release. There are two springs in the design. A torsion spring to close the release, and a tension spring to hold the locking arm in position. There is not any slope on the mating faces of the locking arm and the forward, load carrying part of the hook, so it should not have released unless there was a load to pull the rope down the slot, or the release got tripped by the locking arm being pulled. As for adjustments, remember, there are two ends to a spring. The other end should be easily accessable at the top of the locking arm. You can shorten this spring to increase the tension holding the locking arm in place. Craig, as Bob said, try pushing in at the back of the release. There is plenty of room inside the nose for you to push it most of the way into position from the back end of the release. There is one improvement I think can be made to the design. It will be much easier for the line crew to hook up if a mechanical stop is installed that prevents the forward part of the hook from rotating aft as you push the cover plate back to insert the tow ring. If you look at the geometry, of the hook, you will see what I am talking about. This stop can take several forms. The simplest is a change to the shape of the forward part of the hook. There is also one installed on a Mosquito at my field. My opinion is they work just fine. I have never had any troubles with mine and I have about 1100 hours in my Zuni and probably 300+ flights. Steve Leonard Zuni 2, Serial 28 Steve, Just looking at options. It's under general discussion on gliderforum.com. Many lookers, no comments. Any chance that the shape of a particular hull and mounting position might make the attach angle slightly different, leaving one type a bit more susceptible than another? Bob Whelan had two back releases to report, but admits to having slack lines when they happened. Stronger springs shouldn't change the desired release if high on tow. I'll ask if stronger springs are now standard. Thanks, Frank Whiteley |
Three more newbie Qs, if you don't mind :) | Ramapriya | Piloting | 17 | November 7th 04 05:03 AM |
Fiberglass / Mold release advice requested | Mark Zivley | Home Built | 10 | April 2nd 04 11:15 PM |
VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 05:22 AM |
Air Force Museum Working Group to release final report | Otis Willie | Military Aviation | 0 | November 18th 03 12:28 AM |
ANN: flyWithCE news release - November 2003 | Uros Podlogar | Soaring | 0 | November 16th 03 09:23 AM |
