![]() https://en.wikipedia.org/wiki/Xi%27an_Y-20 The Xi'an Y-20 (Chinese: ?-20; pinyin: Yłn-20; literally: 'transport-20') is a large military transport aircraft. The project is being developed by Xi'an Aircraft Industrial Corporation and was officially launched in 2006. The official codename of the aircraft is Kunpeng (Chinese: ??), after the mythical bird that can fly for thousands of miles described in the ancient Chinese Taoist classic Zhuangzi. However, within the Chinese aviation industry itself, the aircraft is more commonly known by its nickname Chubby Girl (Chinese: ??), because its wide fuselage in comparison to other Chinese aircraft previously developed in China. The aircraft was primarily designed and developed in China under Xi'an Aircraft Industrial Corporation. Certain parts of the wing such as the triple-slotted trailing-edge flaps were developed by the Ukrainian Antonov Design Bureau. The the Y-20 is the first cargo aircraft to use 3D printing technology to speed up its development and to lower its manufacturing cost. Model-based definition (MBD) is also used, and it's the third aircraft to utilize MBD technology in the world, after Airbus A380 (2000) and Boeing 787 (2005).[15] A project team to implement MBD for Y-20 program was formally formed in October 2009, and after the initial success in application on the main landing gear, MBD application was expanded to the entire aircraft and became mandatory for all contractors and sub contractors of the Y-20 program.[15] The implementation of MBD was initially met with strong resistance, with only a third of suppliers agreeing to implement MBD. However, the general designer of Y-20 declared that those who refused to implement MBD will be banned from participating in the Y-20 program, thus forcing everyone to comply, resulting in increases in productivity. The implementation of MBD greatly shortened the time required, for example, without MBD, installation of wings takes a month or two, but with MBD adopted, the time is drastically shortened to just a few hours, and in general, the design work reduced by 40%, preparation for production reduced by 75%, and manufacturing cycle reduced by 30%. In addition to 3D printing, the Y-20 is also the first aircraft in China adopting associative design technology (ADT) in its development. Headed by the deputy general designer of structural design, Mr. Feng Jun (??), the initial attempt to implement ADT actually failed after two months spent on application on the nose section. It was only after the second attempt that took another three months on the application on wings did ADT became successful. The adaptation of ADT greatly shortened the development time by at least eight months, and modification of wing design that previously took a week is shortened to half a day. Cargo is loaded through a large aft ramp that accommodates rolling stock. The Y-20 incorporates a shoulder wing, T-tail, rear cargo-loading assembly and heavy-duty retractable landing gear, consists of three rows, with a pair of wheels for each row, totaling six wheels for each side. The structural test was completed in 194 days as opposed to the 300 days originally planned, thanks to the successful development and application of an automated structural strength analysis system. In comparison, similar work for the Xian JH-7 took a year. According to the deputy general designer, the shortest take-off distance of the Y-20 is 600 to 700 meters.[8] Y-20 incorporates a total of four LCD EFIS, and the development of EFIS for Y-20 utilizes virtual reality via helmet mounted display.[8] Eight types of different relays used on Y-20 are developed by Guilin Aerospace Co., Ltd. a wholly own subsidiary of China Tri-River Aerospace Group Co., Ltd.(????????), which is also known as the 9th Academy of the China Aerospace Science and Industry Corporation (CASIC). Role Strategic airlifter National origin China Manufacturer Xi'an Aircraft Industrial Corporation Designer Tang Changhong First flight 26 January 2013 Introduction 6 July 2016 Status In service, in production Primary user PLA Air Force Produced 2013present Number built 8 prototypes 40+ initial production aircraft Unit cost US$160 million (flyaway cost) The Y-20 is currently powered by four 12-ton thrust Soloviev D-30KP-2 engines, and all early production units are fitted with the same engine. The Chinese intend to replace the D-30 with the 14-ton thrust WS-20, which is required for the Y-20 to achieve its maximum cargo capacity of 66 tons. The Shenyang WS-20 is derived from the core of the Shenyang WS-10A, an indigenous Chinese turbofan engine for fighter aircraft. Specifications (estimated) General characteristics Crew: 3 Capacity: 66,000 kg (145,505 lb)[20] Length: 47 m (154 ft 2 in) [54] Wingspan: 45 m (147 ft 8 in) [55] Empty weight: 100,000 kg (220,462 lb) Max takeoff weight: 220,000 kg (485,017 lb) Powerplant: 4 × Soloviev D-30KP-2 (WS-20 planned) turbofan engines Performance Maximum speed: Mach 0.75 Range: 4,500 km (2,800 mi, 2,400 nmi) with max payload 7,800 km (4,847 mi) with 40,000 kg (88,185 lb)10,000 km (6,214 mi)+ with paratroops.Service ceiling: 13,000 m (43,000 ft) Wing loading: 710 kg/m2 (150 lb/sq ft) * |
On 15 Feb 2020 07:24:27 -0800, Miloch
wrote: China invents the Lockheed C-141. https://en.wikipedia.org/wiki/Xi%27an_Y-20 The Xi'an Y-20 (Chinese: ?-20; pinyin: Yłn-20; literally: 'transport-20') is a large military transport aircraft. The project is being developed by Xi'an Aircraft Industrial Corporation and was officially launched in 2006. The official codename of the aircraft is Kunpeng (Chinese: ??), after the mythical bird that can fly for thousands of miles described in the ancient Chinese Taoist classic Zhuangzi. However, within the Chinese aviation industry itself, the aircraft is more commonly known by its nickname Chubby Girl (Chinese: ??), because its wide fuselage in comparison to other Chinese aircraft previously developed in China. The aircraft was primarily designed and developed in China under Xi'an Aircraft Industrial Corporation. Certain parts of the wing such as the triple-slotted trailing-edge flaps were developed by the Ukrainian Antonov Design Bureau. The the Y-20 is the first cargo aircraft to use 3D printing technology to speed up its development and to lower its manufacturing cost. Model-based definition (MBD) is also used, and it's the third aircraft to utilize MBD technology in the world, after Airbus A380 (2000) and Boeing 787 (2005).[15] A project team to implement MBD for Y-20 program was formally formed in October 2009, and after the initial success in application on the main landing gear, MBD application was expanded to the entire aircraft and became mandatory for all contractors and sub contractors of the Y-20 program.[15] The implementation of MBD was initially met with strong resistance, with only a third of suppliers agreeing to implement MBD. However, the general designer of Y-20 declared that those who refused to implement MBD will be banned from participating in the Y-20 program, thus forcing everyone to comply, resulting in increases in productivity. The implementation of MBD greatly shortened the time required, for example, without MBD, installation of wings takes a month or two, but with MBD adopted, the time is drastically shortened to just a few hours, and in general, the design work reduced by 40%, preparation for production reduced by 75%, and manufacturing cycle reduced by 30%. In addition to 3D printing, the Y-20 is also the first aircraft in China adopting associative design technology (ADT) in its development. Headed by the deputy general designer of structural design, Mr. Feng Jun (??), the initial attempt to implement ADT actually failed after two months spent on application on the nose section. It was only after the second attempt that took another three months on the application on wings did ADT became successful. The adaptation of ADT greatly shortened the development time by at least eight months, and modification of wing design that previously took a week is shortened to half a day. Cargo is loaded through a large aft ramp that accommodates rolling stock. The Y-20 incorporates a shoulder wing, T-tail, rear cargo-loading assembly and heavy-duty retractable landing gear, consists of three rows, with a pair of wheels for each row, totaling six wheels for each side. The structural test was completed in 194 days as opposed to the 300 days originally planned, thanks to the successful development and application of an automated structural strength analysis system. In comparison, similar work for the Xian JH-7 took a year. According to the deputy general designer, the shortest take-off distance of the Y-20 is 600 to 700 meters.[8] Y-20 incorporates a total of four LCD EFIS, and the development of EFIS for Y-20 utilizes virtual reality via helmet mounted display.[8] Eight types of different relays used on Y-20 are developed by Guilin Aerospace Co., Ltd. a wholly own subsidiary of China Tri-River Aerospace Group Co., Ltd.(????????), which is also known as the 9th Academy of the China Aerospace Science and Industry Corporation (CASIC). Role Strategic airlifter National origin China Manufacturer Xi'an Aircraft Industrial Corporation Designer Tang Changhong First flight 26 January 2013 Introduction 6 July 2016 Status In service, in production Primary user PLA Air Force Produced 2013present Number built 8 prototypes 40+ initial production aircraft Unit cost US$160 million (flyaway cost) The Y-20 is currently powered by four 12-ton thrust Soloviev D-30KP-2 engines, and all early production units are fitted with the same engine. The Chinese intend to replace the D-30 with the 14-ton thrust WS-20, which is required for the Y-20 to achieve its maximum cargo capacity of 66 tons. The Shenyang WS-20 is derived from the core of the Shenyang WS-10A, an indigenous Chinese turbofan engine for fighter aircraft. Specifications (estimated) General characteristics Crew: 3 Capacity: 66,000 kg (145,505 lb)[20] Length: 47 m (154 ft 2 in) [54] Wingspan: 45 m (147 ft 8 in) [55] Empty weight: 100,000 kg (220,462 lb) Max takeoff weight: 220,000 kg (485,017 lb) Powerplant: 4 × Soloviev D-30KP-2 (WS-20 planned) turbofan engines Performance Maximum speed: Mach 0.75 Range: 4,500 km (2,800 mi, 2,400 nmi) with max payload 7,800 km (4,847 mi) with 40,000 kg (88,185 lb)10,000 km (6,214 mi)+ with paratroops.Service ceiling: 13,000 m (43,000 ft) Wing loading: 710 kg/m2 (150 lb/sq ft) * |
