Got a new pressure washer today and I want to bring it to the airport to
wash the plane. It needs 20 psi to work properly. If I put a 100 gallon water tank in my truck and fed the pressure washer with a standard 5/8" garden hose and a 3 foot drop to the pressure washer on the ground would that give me 20 psi? |
No - You only theoretically get about 0.43 psi per foot of water head - and that is ignoring the wall friction effects of a 5/8 in hose. Use auto wash soap and warm water & a rag or sponge. A pressure washer is hell on bearing seals etc and will promote corrosion in the areas that get pried open from the wash pressure. A rainy day also makes a good wash day with a soft water rinse. |
![]() nrp wrote: would that give me 20 psi? No - You only theoretically get about 0.43 psi per foot of water head - and that is ignoring the wall friction effects of a 5/8 in hose. Use auto wash soap and warm water & a rag or sponge. A pressure washer is hell on bearing seals etc and will promote corrosion in the areas that get pried open from the wash pressure. So what would the pressure be? |
Water pressure is a matter of height/elevation. From my fire department
days, you will get static pressure of 1/2" pound PSI per foot of elevation.. so you need 10 feet of water to get that 20 psi. You've got approx 1.5 psi there of head pressure. Considering you will be flowing very little in the way of gallons per minute, I wont address the flow related pressure loss in that 5/8" hose. Chances are you will actually do just fine.. If not, then you need to "make" a tank that can handle pressure (such as a large air compressor's tank.. coat it for rust proofing, and put an air nipple on it and charge it to 20 psi.. which is prolly overkill in my opinion.. people have pressure washers in the back of trailers all the time with a feed tank right next to it, running atmospheric pressure feeds. Dave Newps wrote: Got a new pressure washer today and I want to bring it to the airport to wash the plane. It needs 20 psi to work properly. If I put a 100 gallon water tank in my truck and fed the pressure washer with a standard 5/8" garden hose and a 3 foot drop to the pressure washer on the ground would that give me 20 psi? |
Dave S wrote:
Water pressure is a matter of height/elevation. From my fire department days, you will get static pressure of 1/2" pound PSI per foot of elevation.. so you need 10 feet of water to get that 20 psi. Wouldn't that be 40' of elevation to get 20 psi? George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
Yes.. you are absolutely right.. and someone else earlier gave the more
exact value of 0.4 psi/ft so actually its more like 50 feet. I had the right idea but did the wrong math the first time around. Think about it like this.. most water towers are in the 100 ft range to get spigot pressures of 40-50 psi. Modern practice is now to get away from towers and stick with continuous duty pumps, but the old style still persists. Dave Thanks. George Patterson wrote: Dave S wrote: Water pressure is a matter of height/elevation. From my fire department days, you will get static pressure of 1/2" pound PSI per foot of elevation.. so you need 10 feet of water to get that 20 psi. Wouldn't that be 40' of elevation to get 20 psi? George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
On Sat, 30 Apr 2005 03:14:38 GMT, Dave S
wrote: Think about it like this.. most water towers are in the 100 ft range to get spigot pressures of 40-50 psi. Modern practice is now to get away from towers and stick with continuous duty pumps, but the old style still persists. Really? This surprises me. Water towers offer a lot of benefits. Water towers allow the purchase of smaller pumps, that will serve the average water flow through the day, vs. peak rate. That saves initial capital cost. Water towers are sized to provide a day or so of water to the community in the event that the pump breaks or power is interrupted. Last, space on water towers are now leased to cellular carriers, so the towers actually provide a revenue stream for the city. OTOH, it probably costs a fair amount of money to build a water tower, so the capital costs may outweight the benefits. Although for what the cell carriers pay for leases, I'd be surprised if it didn't cover the mortgage/bond on the water tower. |
![]() Nathan Young wrote: ((snip)) Really? This surprises me. Water towers offer a lot of benefits. ((snip)) american water works assn and most states still consider elevated water best, ground tank on a hill works fine, but the costs for maintenance, worker and community issues get pretty rough. the real issues are firefighting with a dead electric grid and keeping the system pressurized for health issues. sometimes, if you're clever, you can get/stay certified with ground storage only by strapping in enough big deisel generators to keep the pressure up. personally, i like having lots of water towers with place names on them as an easy and reasuring answer to the question "where the heck am i??" although often as not the city name is covered with spray paint announcing that sally did tommy which isn't much help unless you happen to know sally. hence the aforementioned maintenance issue. dan |
![]() "Newps" wrote in message ... Got a new pressure washer today and I want to bring it to the airport to wash the plane. It needs 20 psi to work properly. If I put a 100 gallon water tank in my truck and fed the pressure washer with a standard 5/8" garden hose and a 3 foot drop to the pressure washer on the ground would that give me 20 psi? The answer is no you will not get 20psi. However, I have a 13hp Karcher pressure washer that I bought at Costco and I have found that you don't need much pressure to the inlet side for it to work. Try to get the largest possible hose and fittings. You need an inlet that flows at least as much as the pressure washer is rated for. The goal is to have enough pressure that the pump doesn't cavitate. It doesn't take 20psi. Mike MU-2 |
![]() Mike Rapoport wrote: "Newps" wrote in message ... Got a new pressure washer today and I want to bring it to the airport to wash the plane. It needs 20 psi to work properly. If I put a 100 gallon water tank in my truck and fed the pressure washer with a standard 5/8" garden hose and a 3 foot drop to the pressure washer on the ground would that give me 20 psi? The answer is no you will not get 20psi. However, I have a 13hp Karcher pressure washer that I bought at Costco and I have found that you don't need much pressure to the inlet side for it to work. Try to get the largest possible hose and fittings. You need an inlet that flows at least as much as the pressure washer is rated for. The goal is to have enough pressure that the pump doesn't cavitate. It doesn't take 20psi. I can get a bigger hose but the inlet fitting is a standard garden hose fitting. |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 05:49 PM |
Cabin Pressure Altitude | Greg Esres | Piloting | 4 | March 24th 04 08:35 PM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
