Ok Guys and Gals,
I do not remember the formula for this to save my life, so I will see if yall can come up with it. Yes I did check on the web, but did not see the formula I need. I want to figure the volume of a gas tank that will not be round or square, It will have five sides and then the two ends of the tank. With one end being larger than the other. I would give exact measurements , but being as I don't know what they will be yet I can't:} I need to find the right volume in order to get the right measurement . Oh the dilemma ! Be gentle math wizards it's been 25 years since I have had to do this! ![]() -- Patrick Dixon student SPL aircraft structural mech |
sounds like you will need to just fill the tank and measure the output.
Dave W P Dixon wrote: Ok Guys and Gals, I do not remember the formula for this to save my life, so I will see if yall can come up with it. Yes I did check on the web, but did not see the formula I need. I want to figure the volume of a gas tank that will not be round or square, It will have five sides and then the two ends of the tank. With one end being larger than the other. I would give exact measurements , but being as I don't know what they will be yet I can't:} I need to find the right volume in order to get the right measurement . Oh the dilemma ! Be gentle math wizards it's been 25 years since I have had to do this! ![]() |
W P Dixon wrote:
Ok Guys and Gals, I do not remember the formula for this to save my life, so I will see if yall can come up with it. Yes I did check on the web, but did not see the formula I need. I want to figure the volume of a gas tank that will not be round or square, It will have five sides and then the two ends of the tank. With one end being larger than the other. I would give exact measurements , but being as I don't know what they will be yet I can't:} I need to find the right volume in order to get the right measurement . Oh the dilemma ! Be gentle math wizards it's been 25 years since I have had to do this! ![]() Depending on how irregular the tank shape is, you may have to solve this using numerical integration. However, if the tank shape is the same in at least one axis (say z or vertical), then figure the area of the shape in the x-y plane and then simply multiply times the height, z, and equate that to the volume you desire. Then solve for z. Matt |
Matt Whiting wrote:
W P Dixon wrote: Ok Guys and Gals, I do not remember the formula for this to save my life, so I will see if yall can come up with it. Yes I did check on the web, but did not see the formula I need. I want to figure the volume of a gas tank that will not be round or square, It will have five sides and then the two ends of the tank. With one end being larger than the other. I would give exact measurements , but being as I don't know what they will be yet I can't:} I need to find the right volume in order to get the right measurement . Oh the dilemma ! Be gentle math wizards it's been 25 years since I have had to do this! ![]() Depending on how irregular the tank shape is, you may have to solve this using numerical integration. However, if the tank shape is the same in at least one axis (say z or vertical), then figure the area of the shape in the x-y plane and then simply multiply times the height, z, and equate that to the volume you desire. Then solve for z. Matt That would work if it had the same cross sectional area along Z. He says otherwise. This leaves to 3 solutions: 1) build it, fill it and measure the volume coming out, 2) calculus which would be quickest and easiest or 3) draw a diagram, cut it into solids you can calculate, then add up the volume of the solids. If the small end isn't very much smaller than the big end go ahead and do it Matt's way and add a fudge factor. Dan, U.S. Air Force, retired |
Hee Hee,
No simple answer huh? ![]() night and I do think I will have to make the shapes into smaller measureable shapes and add the totals. I do think figuring up something before you actually build it is alot cheaper,...you don't have to build it but once. Well we all hope anyway! ![]() Also planning to build a set of floats and that's where the volume formulas really get funky. I would sure hate to spend a grand just to fill it with water and say, well not right can't use it. Heck my old lady would kill me if I wasted 200 bucks on a ruined gas tank! HAHA It won't be to bad figuring it all up "cutting it into basic shapes" , just will take some time. For the gas tank, it will be in a VP-1. I am welding aluminum instead of using the fiberglass. An old high school buddy, certified nuclear welder is going to weld it up for me. So I need to send him a drawing of it, thus the need for getting it right. That math stuff is pretty cool when you can remember the formulas ain't it? ![]() tank, I just wanted to see how much fuel a aluminum tank would hold with alittle mod. But the floats , I definitely have to know the volumes of each compartment before I even think of starting the build there. Patrick student SPL aircraft structural mech |
W P Dixon wrote:
Also planning to build a set of floats and that's where the volume formulas really get funky. I just got my seaplane rating. I spent some time looking at the floats -- it looks like the only way I could calculate the volume of the floats I was looking at would be a double-integral. Elegant, but could still be tricky. One thing to keep in mind is the place where the float will contact the water at various attitudes. If the contact-point is too far forward (either because of the attitude of the aircraft or because of the design of the float), you're flying a taildragger in a soft-sticky-massive substance that is many times more dense than air... Scary! Also, floats a have many effects on the aerodynamics of the aircraft. The side area of the craft is different when it has floats -- a lot more aerodynamic stuff happening in front of the CG, which can require a bigger rudder. Also, the instructor told me that in a plow turn, the change in the amount of the float exposed to the wind was one of the things that makes the aircraft turn downwing. Lastly, the mass of the floats would probably change the CG around a bit too. -Luke |
W P Dixon wrote:
Hee Hee, No simple answer huh? ![]() last night and I do think I will have to make the shapes into smaller measureable shapes and add the totals. I do think figuring up something before you actually build it is alot cheaper,...you don't have to build it but once. Well we all hope anyway! ![]() Also planning to build a set of floats and that's where the volume formulas really get funky. I would sure hate to spend a grand just to fill it with water and say, well not right can't use it. Heck my old lady would kill me if I wasted 200 bucks on a ruined gas tank! HAHA It won't be to bad figuring it all up "cutting it into basic shapes" , just will take some time. For the gas tank, it will be in a VP-1. I am welding aluminum instead of using the fiberglass. An old high school buddy, certified nuclear welder is going to weld it up for me. So I need to send him a drawing of it, thus the need for getting it right. That math stuff is pretty cool when you can remember the formulas ain't it? ![]() tank would hold with alittle mod. But the floats , I definitely have to know the volumes of each compartment before I even think of starting the build there. Patrick student SPL aircraft structural mech Nothing says you have to build a full size model. Make a fiberglass model at 1/8 to 1/4 the size you SWAG, fill it with water and measure it out. You can now scale as needed mathematically. Don't forget to take into consideration material thickness, baffle thickness etc as you plan. Dan, U.S. Air Force, retired |
Now that may not be a bad idea, and it would be pretty cool to build a RC
plane to go on top too! Dang Dan now I have to build another toy!!!!! My wife is gonna shoot me for sure! ![]() Seriously , that is not a bad idea, may just do that. Will check out the math stuff first. If it befuddles me to bad I may have to resort to a plan B, or Plan Dan! ![]() Patrick student SPL aircraft structural mech "Dan, U.S. Air Force, retired" wrote in message news:LHOce.1573$aB.391@lakeread03... W P Dixon wrote: Hee Hee, No simple answer huh? ![]() night and I do think I will have to make the shapes into smaller measureable shapes and add the totals. I do think figuring up something before you actually build it is alot cheaper,...you don't have to build it but once. Well we all hope anyway! ![]() Also planning to build a set of floats and that's where the volume formulas really get funky. I would sure hate to spend a grand just to fill it with water and say, well not right can't use it. Heck my old lady would kill me if I wasted 200 bucks on a ruined gas tank! HAHA It won't be to bad figuring it all up "cutting it into basic shapes" , just will take some time. For the gas tank, it will be in a VP-1. I am welding aluminum instead of using the fiberglass. An old high school buddy, certified nuclear welder is going to weld it up for me. So I need to send him a drawing of it, thus the need for getting it right. That math stuff is pretty cool when you can remember the formulas ain't it? ![]() So for the gas tank, I just wanted to see how much fuel a aluminum tank would hold with alittle mod. But the floats , I definitely have to know the volumes of each compartment before I even think of starting the build there. Patrick student SPL aircraft structural mech Nothing says you have to build a full size model. Make a fiberglass model at 1/8 to 1/4 the size you SWAG, fill it with water and measure it out. You can now scale as needed mathematically. Don't forget to take into consideration material thickness, baffle thickness etc as you plan. Dan, U.S. Air Force, retired |
![]() "W P Dixon" wrote .. For the gas tank, it will be in a VP-1. I am welding aluminum instead of using the fiberglass. An old high school buddy, certified nuclear welder is going to weld it up for me. Why not make it round on the ends, and just wrap it, instead of having flat sides? Less welds to leak. That is, if you are welding each flat to the other. If you are going continuous, nevermind! g -- Jim in NC |
Jim,
If I were welding it, it wouldn't be welded!!! HAHA It would be riveted and sloshed. However the fellow that will be doing the welding welds at nuclear facilities and has an xray certification. I know his work very well, and it won't leak. Patrick student SPL aircraft structural mech "Morgans" wrote in message ... "W P Dixon" wrote . For the gas tank, it will be in a VP-1. I am welding aluminum instead of using the fiberglass. An old high school buddy, certified nuclear welder is going to weld it up for me. Why not make it round on the ends, and just wrap it, instead of having flat sides? Less welds to leak. That is, if you are welding each flat to the other. If you are going continuous, nevermind! g -- Jim in NC |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
