https://en.wikipedia.org/wiki/Waco_CG-4
The Waco CG-4A was the most widely used American troop/cargo military glider of World War II. It was designated the CG-4A by the United States Army Air Forces, and named Hadrian (after the Roman emperor) in British military service. Designed by the Waco Aircraft Company, flight testing began in May 1942, and eventually more than 13,900 CG-4As were delivered. The CG-4A was constructed of fabric-covered wood and metal and was crewed by a pilot and copilot. It had two fixed mainwheels and a tailwheel. The CG-4A could carry 13 troops and their equipment. Cargo loads could be a ?1/4-ton truck (i.e. a Jeep), a 75 mm howitzer, or a ?1/4-ton trailer, loaded through the upward-hinged nose section. C-47s were usually used as tow aircraft. A few C-46 tugs were used during and after Operation Plunder. The USAAF CG-4A tow line was 11/16 inch (17 mm) nylon, 350 feet (107 m) long. The CG-4A pickup line was ?15/16 inch (24 mm) diameter nylon, but only 225 ft (69 m) long including the doubled loop. In effort to identify areas where strategic materials could be reduced, a single XCG-4B was built at the Timm Aircraft Corporation using wood for the main structure. The factories ran 24-hour shifts to build the gliders. One night-shift worker in the Wicks Aircraft Company factory in Kansas City wrote, “ On one side of the huge bricked-in room is a fan running, on the other a cascade of water to keep the air from becoming too saturated with paint. The men man the paint sprayers covering the huge wings of the glider with the Khaki or Blue and finishing it off with that thrilling white star enclosed in a blue circle that is winging its way around the world for victory ... The wings are first covered with a canvas fabric stretched on like wallpaper over plywood then every seam, hold, open place, closed place, and edge is taped down with the all adhesive dope that not only makes the wings airtight, but covers my hands, my slacks, my eyebrows, my hair, and my tools with a fast-drying coat that peels off like nail polish or rubs off with a thinner that burns like Hell. Role Military glider Manufacturer Waco Aircraft Company, Cessna, Ford, Gibson Appliance, Ward Furniture Designer Waco Aircraft Company First flight 1942 Primary users United States Army Air Forces Royal Air Force Royal Canadian Air Force United States Navy Number built 13,903 Variants Waco CG-15 Sedalia Glider Base was originally activated on 6 August 1942. In November 1942 the installation became Sedalia Army Air Field, (after the war would be renamed Whiteman Air Force Base) and was assigned to the 12th Troop Carrier Command of the United States Army Air Forces. The field served as a training site for glider pilots and paratroopers. Assigned aircraft included the CG-4A glider, Curtiss C-46 Commando, and Douglas C-47 Skytrain. The C-46 was not used as a glider tug in combat, however, until Operation Plunder (the crossing of the Rhine) in March 1945. CG-4As went into operation in July 1943 during the Allied invasion of Sicily. They were flown 450 miles across the Mediterranean from North Africa for the night-time assaults such as Operation Ladbroke. Inexperience and poor conditions contributed to the heavy losses. They participated in the American airborne landings in Normandy on 6 June 1944, and in other important airborne operations in Europe and in the China Burma India Theater. Although not the intention of the Army Air Forces, gliders were generally considered expendable by high-ranking European theater officers and combat personnel and were abandoned or destroyed after landing. While equipment and methods for extracting flyable gliders were developed and delivered to Europe, half of that equipment was rendered unavailable by certain higher-ranked officers. Despite this lack of support for the recovery system, several gliders were recovered from Normandy and even more from Operation Market Garden in the Netherlands and Wesel, Germany. The CG-4A found favor where its small size was a benefit. The larger British Airspeed Horsa could carry more troopers (seating for 28 or a jeep or an anti-tank gun), and the British General Aircraft Hamilcar could carry 7 tons (enough for a light tank), but the CG-4A could land in smaller spaces. In addition, by using a fairly simple grapple system, an in-flight C-47 equipped with a tail hook and rope braking drum could "pick up" a CG-4A waiting on the ground. The system was used in the 1945 high-elevation rescue of the survivors of the Gremlin Special 1945 crash, in a mountain valley of New Guinea. The last known use of the CG-4A was in the early 1950s by the USAF with an Arctic detachment aiding scientific research. The CG-4As were used for getting personnel down to, and up from, floating ice floes, with the glider being towed out, released for landing, and then picked up later by the same type of aircraft, using the hook and line method developed during World War II. The only modification to the CG-4A was the fitting of wide skis in place of the landing gear for landing on the Arctic ice floes. Specifications (CG-4A) General characteristics Crew: two pilots Capacity: 13 troops, or quarter-ton truck (Jeep) and 4 troopers, or 6 litters Length: 48 ft 8 in (14.8 m) Wingspan: 83 ft 8 in (25.5 m) Height: 15 ft 4 in (4.7 m) Wing area: 900 ft2 (83.6 m2) Empty weight: 3,900 lb (1,769 kg) Useful load: "Troop Carrier (2 crew & 13 passengers): 4,197 pounds (1,904 kg)";"Cargo Carrier - Jeep (2 crew, 4 passengers, 1 Jeep Car): 4,197 pounds (1,904 kg)""Cargo Carrier - 75 mm howitzer (2 crew, 3 passengers, 1 Howitzer, 18 rounds ammunition): 4,197 pounds (1,904 kg) Loaded weight: 7,500 lb (3,402 kg) Max. takeoff weight: 7,500 lb (3,402 kg) Max take off (Emergency Load): 9,000 lb (4,082 kg) Performance Never exceed speed: 150 mph IAS (241 km/h) Maximum speed: 150 mph CAS (240 km/h CAS) at 7,500 pounds (3,400 kg) 128 mph (206 km/h) CAS/135 mph (217 km/h) IAS at 9,000 pounds (4,100 kg) Cruise speed: IAS 72.6 mph (117 km/h) Stall speed: 49 mph (79 km/h) with design load 7,500 lb (3,400 kg) Glide ratio: 12:1 Rate of sink: About 400 ft/min (2 m/s) at tactical glide speed (IAS 60 mph, 96 km/h) Landing run: 600-800 feet (180-244 m) for normal three-point landing; "Landing rolls of approximately 2,000 to 3,000 feet (610 to 910 m) are to be expected at the higher emergency gross weights..." Wing loading: 8.33 lb/ft2 (40.7 kg/m2) Armament none * |
Waco E series pics [11/14] - Waco SRE Rear Seat.jpg (1/1) | Miloch | Aviation Photos | 0 | September 22nd 17 03:26 PM |
Waco E series pics [09/14] - Waco SRE N1252W at Belvidere Poplar Grove airport Illinois in 2010.jpg (1/1) | Miloch | Aviation Photos | 0 | September 22nd 17 03:26 PM |
WACO Fly-In - Troy, OH - WACO YMF (Classic Aircraft Corp) 1992 - fvl.jpg | Roadsign | Aviation Photos | 0 | September 25th 10 05:33 PM |
WACO Fly-In - Troy, OH - Waco YMF (Classic Aircraft Corp - 1993) - rvl.jpg | Roadsign | Aviation Photos | 0 | September 25th 10 05:33 PM |
WACO Fly-In - Troy, OH - WACO on ramp - variable pitch prop - fvl.jpg | Roadsign | Aviation Photos | 0 | September 25th 10 05:28 PM |
