FES climb rate question.
Old October 7th 20, 11:27 PM posted to rec.aviation.soaring
JM LN
Default FES climb rate question.
Hi everybody.
I would like to know the opinion of a owner of a HPH Shark with FES.
Which is the true climb rate?.
Somebody has proven to use FES like a supplement tow mechanism?. I mean, how efficient is take a tow to 300 or 400 m and later start FES to climb at 900 or 1000 m.
Thank you very much.
Juan.
Old October 8th 20, 10:56 AM posted to rec.aviation.soaring
Peter F[_2_]
So you're spending 150k Euro on your glider then trying to save a few Euro
per launch on the tow?
The climb rate of a FES glider easily beats the traditional Turbos but do
you really want to use up the limited duration of the batteries in this
phase of the flight?
You'd be better off taking the higher tow & saving the FES for the retrieve
if needed.
Or take the lower tow & soar
PF
At 22:27 07 October 2020, JM LN wrote:
Hi everybody.
at
900 or 1000 m.
Juan.
Old October 8th 20, 01:11 PM posted to rec.aviation.soaring
Matthew Scutter
if needed.
PF
Hi everybody.
at
900 or 1000 m.
Juan.
You'll get at least 2m/s dry. But like PF says, better to take a tow to 400m and use the FES straight and level until you find a thermal. It's much more efficient in level flight than climbing.
Old October 8th 20, 09:14 PM posted to rec.aviation.soaring
Mana
On the Shark, based on a test flight I think that you will get less than 2m/s as it is a heavier glider than Matthew's Diana 2 :-).
From the FES manual:
5.3.4.1 Rate of climb
The maximum rate of climb is available only for a few minutes with fully charged battery packs. As battery voltage is reduced, the maximum achievable climb rate is lower. The average rate of climb depends mostly on the type of sailplane and its take-off weight. Maximum attainable altitude gain that in standard atmosphere conditions depends on the type of sailplane, its weight and aerodynamic qualities. To achieve the maximum altitude gain, use about 15kW of power. Do not use full power as the efficiency of the system is lower. Usually, 80-85 km/h is best for the climb with positive flap setting (the same setting as used while thermaling). Here are rough numbers:
•1600 m (5200 ft) for UL sailplanes at 300kg take-off weight, i.e. Silent 2 Electro
•1400 m (4500 ft) for the 18m class sailplanes at 400kg take-off weight (without water ballast), i.e.LAK17A FES
•1200 m (3900 ft) for the 18m class sailplanes at 450kg take-off weight (without water ballast); LAK17B FES, Ventus 2cxa FES, Discus 2c FES, HPH 304ES
Old October 9th 20, 01:54 AM posted to rec.aviation.soaring
2G
•1600 m (5200 ft) for UL sailplanes at 300kg take-off weight, i.e.. Silent 2 Electro
Sounds like a very marginal self-launch system and is really just a decent self-retrieve (turbo) setup.
Tom
Old October 12th 20, 09:30 AM posted to rec.aviation.soaring
Dne pátek 9. Å™Ã*jna 2020Â*vÂ*2:54:13 UTC+2 uživatel 2G napsal:
•1600 m (5200 ft) for UL sailplanes at 300kg take-off weight, i..e. Silent 2 Electro
Tom
HI
stefan langer discus capabilities of Shark FES in some of his videos, I dont remenber exact number but you can try wach it.
https://www.youtube.com/user/SLSoaring
Old October 12th 20, 03:46 PM posted to rec.aviation.soaring
kinsell
Tom
These gliders are sustainers only.
Old October 8th 20, 07:57 PM posted to rec.aviation.soaring
JM LN
if needed.
PF
Hi everybody.
at
900 or 1000 m.
Juan.
Thank you Peter.
The idea is not to take a tow and release early.
Now I have a turbo discus and all my tow are at 500 or 600 m, but if the day is weak and lose the fisrt thermal when I start the turbo at 300 m I usually can not climb. Whe this happen the zone near the aerodrome is dead even you find descendet air and usually the mountain works, but it is a litle far away. I was thinking in this kind of situation. If I will move to a FES glider I want to be sure it can climb at 2m/s, and you can travel to the mountain gaining height.
Regards.
Why Isn't Vx The Best Rate Of Climb? RandyL Piloting 18 September 28th 06 07:50 PM
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Climb Rate for DG-600M Steve B Soaring 5 August 25th 03 08:17 AM
