https://en.wikipedia.org/wiki/Fairchild_C-123_Provider
The Fairchild C-123 Provider is an American military transport aircraft designed by Chase Aircraft and then built by Fairchild Aircraft for the U.S. Air Force. In addition to its USAF service, which included later service with the Air Force Reserve and the Air National Guard, it also went on to serve most notably with the U.S. Coast Guard and various air forces in Southeast Asia. During the War in Vietnam, the C-123 was used to deliver supplies, to evacuate the wounded, and also used to spray Agent Orange. The C-123 Provider was designed originally as an assault glider aircraft for the United States Air Force (USAF) by Chase Aircraft as the XCG-20 (Chase designation MS-8 Avitruc) Two powered variants of the XCG-20 were developed during the early 1950s, as the XC-123 and XC-123A. The only difference between the two was the type of engines used. The XC-123 used two Pratt & Whitney R-2800-23 air-cooled radial piston engines, while the XC-123A was fitted with four General Electric J47-GE-11 turbojets, in two pods. The XC-123A also has the distinction, while only experimental, of being the USAF first jet-powered military transport. While the piston-powered XC-123 was initially well-regarded for tactical transport for its ruggedness and reliability, and its ability to operate from short and unimproved airstrips, the turbojet-powered XC-123A – designed for high-speed transport between USAF bases for critical parts and personnel – was found unable to operate from short and rough airstrips. There was also no practical speed advantage due to the wing and fuselage design, and a drastic reduction in range. Only the one turbojet-powered test and evaluation version was built. Role Military transport aircraft Manufacturer Chase Aircraft Fairchild Aircraft Designer Michael Stroukoff First flight 14 October 1949 Introduction 1956 Retired United States Air Force c. 1980 Status Active with flying clubs Primary users United States Air Force (historical) United States Coast Guard (historical) Republic of Vietnam Air Force (historical) Produced 1949–1970 Number built 307 Developed from Chase XCG-20 Variants Chase XC-123A Stroukoff YC-134 The first recipients of C-123 aircraft were USAF transport units, soon followed by the U.S. Coast Guard (USCG) which used the aircraft for search and rescue (SAR) missions, and even the U.S. Air Force Demonstration Team, the "Thunderbirds," used C-123s for a time as a logistics support aircraft for transporting the team's ground crews and equipment. The type would also be widely exported under various U.S. military assistance programs, directly from USAF stocks. A C-123 was used to transport President John F. Kennedy's limousine during his November, 1963, Texas tour. The C-123 was nearly ignored by the USAF for service in Vietnam, but a political rivalry with the U.S. Army and the Army's use of the CV-2 Caribou and later pre-production order for the de Havilland Canada C-8 Buffalo, led to a decision to deploy C-123s there. To compete with the well-performing CV-2, the USAF and Fairchild furthered development on the C-123 to allow it to do similar work on short runways. This additional development increased the utility of the aircraft and its variants to allow it to perform a number of unique tasks, including the HC-123B which operated with the USCG fitted with additional radar equipment for search and rescue missions through 1971, and the C-123J which was fitted with retractable skis for operations in Greenland and Alaska on compacted snow runways. By 1962, the C-123K variant aircraft was evaluated for operations in Southeast Asia and their stellar performance led the Air Force to upgrade 180 of the C-123B aircraft to the new C-123K standard, which featured auxiliary jet pods underneath the wings, and anti-skid brakes. In 1968, the aircraft helped resupply troops in Khe Sanh, Vietnam, during a three-month siege by North Vietnam. In 1958, the U.S. Coast Guard received its first HC-123B, followed by seven more in 1961. Installation of a dome on the nose of the aircraft accommodated a large radar allowing the plane to meet the requirements for search and rescue and long range flight over water. The Coast Guard manned the aircraft with a crew of five: two officers serving as the pilot and copilot, augmented by an enlisted flight mechanic, an enlisted navigator, and an enlisted loadmaster. The HC-123B's role in the Coast Guard was slowly replaced by the longer-ranged Coast Guard HC-130 aircraft during the 1960s and 1970s as those newer airframes came on line. With the end of the Vietnam War, remaining C-123Ks and UC-123Ks were transferred to tactical airlift units of the Air Force Reserve (AFRES) and the Air National Guard (ANG) that were operationally-gained by Tactical Air Command (TAC) before 1975 and Military Airlift Command (MAC) after 1975. The final examples of the C-123 in active U.S. military service were retired from the Air Force Reserve and Air National Guard in the early 1980s. Some airframes were transferred to the Federal Aviation Administration (FAA) for test and evaluation programs while others were transferred to the U.S. Department of Agriculture (USDA) for miscellaneous programs. These aircraft were also retired by the end of the 1990s. Specifications (C-123K Provider) General characteristics Crew: 4 Capacity: 60 passengers, 50 litters, or 24,000 pounds (11,000 kg) of cargo Length: 76 ft, 3 in (23.25 m) Wingspan: 110 ft, 0 in (33.53 m) Height: 34 ft, 1 in (10.39 m) Wing area: 1,223 ft² (113.7 m²) Empty weight: 35,366 lb (16,042 kg) Max. takeoff weight: 60,000 lb (27,215 kg) Powerplant: 2 × General Electric J85-GE-17 turbojets, 2,850 lbf (13 kN) each 2 × Pratt & Whitney R-2800-99W "Double Wasp" 18-cylinder radial engines, 2,500 hp (1,865 kW) each Performance Maximum speed: 228 mph (198 knots, 367 km/h) at 10,000 ft (3,050 m) Cruise speed: 173 mph (150 knots, 278 km/h) Stall speed: 95 mph (83 knots, 152 km/h) Range: 1,035 mi (899 nm, 1,666 km) with max payload Ferry range: 3,280 mi (2,852 nmi, 5,280 km) Service ceiling: 21,100 ft (6,430 m) "OEO" (One engine failed) Rate of climb: 1,220 ft/min (6.2 m/s) "OEO" (One engine failed) * |
Fairchild C-123 Provider pics 3 [5/8] - U.S. Coast Guard Fairchild HC-123B Provider.jpg (1/1) | Miloch | Aviation Photos | 0 | June 28th 18 02:15 PM |
Fairchild C-123 Provider pics 3 [4/8] - fairchild-c-123b-provider-3.png (1/1) | Miloch | Aviation Photos | 0 | June 28th 18 02:15 PM |
Fairchild C-123 Provider pics 3 [2/8] - Fairchild C-123K Provider - US Marshals Service.jpg (1/1) | Miloch | Aviation Photos | 0 | June 28th 18 02:14 PM |
Fairchild C-123 Provider pics 2 [6/6] - Fairchild C-123 Provider Philippine Air Force 2.jpg (1/1) | Miloch | Aviation Photos | 0 | June 28th 18 02:13 PM |
Fairchild C-123 Provider pics 2 [4/6] - Cockpit of a C-123K Provider at the Castle Air Museum.jpg (1/1) | Miloch | Aviation Photos | 0 | June 28th 18 02:13 PM |
