Having a "better G" idea, decided to hang my engine on M1 fuselage without
wings in order to have the ability to roll it outside the hanger for breakin efforts. After struggling with several versions of a wooden framed, wheeled "wagon", a thought occurred that I may be "reinventing the wheel" (as usual). Has anyone out there found a method to move the "engine on fuselage without wings" or move a completed plane with one wing removed?? The M1 has main gear on the wings, not on the fuselage. Thanks, Dick |
![]() "Dick" wrote in message m... Having a "better G" idea, decided to hang my engine on M1 fuselage without wings in order to have the ability to roll it outside the hanger for breakin efforts. After struggling with several versions of a wooden framed, wheeled "wagon", a thought occurred that I may be "reinventing the wheel" (as usual). Has anyone out there found a method to move the "engine on fuselage without wings" or move a completed plane with one wing removed?? The M1 has main gear on the wings, not on the fuselage. Thanks, Dick In order to move my Piper Apache fuselage around the hangar while I have the wings off I made up a little cart. It is basically a frame with two ends and a bottom mounted on large heavy duty casters. I stretched a length of carpeting about three feet wide across the frame ends to make a wide carpet saddle that the fuselage lays on. When I park it I put a two by six through the spar openings and take a bit of a strain on it with the jacks. That steadys the fuselage in the sling. The third wheel on the ground also steadys it fore and aft. It looks kind of like an old bedstead with carpet slung from the headboard to the footboard and the airplane across the bed! :-) Highflyer |
Thanks, the 3' carpeting sling and stabilizing 2x4 thru spar openings is a
good idea. "Highflyer" wrote in message ... "Dick" wrote in message m... Having a "better G" idea, decided to hang my engine on M1 fuselage without wings in order to have the ability to roll it outside the hanger for breakin efforts. After struggling with several versions of a wooden framed, wheeled "wagon", a thought occurred that I may be "reinventing the wheel" (as usual). Has anyone out there found a method to move the "engine on fuselage without wings" or move a completed plane with one wing removed?? The M1 has main gear on the wings, not on the fuselage. Thanks, Dick In order to move my Piper Apache fuselage around the hangar while I have the wings off I made up a little cart. It is basically a frame with two ends and a bottom mounted on large heavy duty casters. I stretched a length of carpeting about three feet wide across the frame ends to make a wide carpet saddle that the fuselage lays on. When I park it I put a two by six through the spar openings and take a bit of a strain on it with the jacks. That steadys the fuselage in the sling. The third wheel on the ground also steadys it fore and aft. It looks kind of like an old bedstead with carpet slung from the headboard to the footboard and the airplane across the bed! :-) Highflyer |
I don't know what an "M1" is. I think you you plan on mounting your
engine to the fuselage, then mounting the fuselage on some sort of wheeled table so that you can move the assembly around, and also run the engine (not while you're moving it around, of course). And you want it to be simple, cheap and easy to build, made out of 2 x 4's held together with drywall screws and duct tape. I happen to know a very simple solution, much simpler than building a custom carriage. This method has been thoroughly tested and it really is the way that at least 99% of successful aircraft builders do it. Attach both wings and the landing gear to the aircraft, and then hook up all engine and airframe systems before running the engine. That way the aircraft is easy to move around on its own wheels, you have a safe engine test stand for engine break in, and you're running the aircraft as a complete system, the way it was designed to work. Why would anyone want to do it any differently? Skystar Aircraft, manufacturers of the Kitfox, almost went bankrupt when a runaway 182 went through their hangar. The A&P mechanic decided to test run the engine without installing the pilot seats. He had the throttle linkage backwards. When the engine ran away from him, he lost his balance in the unfurnished cockpit and became a baggage compartment passenger while the 182 made a full throttle tour of Skystar's hangar. $300,000 in uninsured damage for Skystar. That sounds like the kind of adventure you're preparing for. Dick wrote: Having a "better G" idea, decided to hang my engine on M1 fuselage without wings in order to have the ability to roll it outside the hanger for breakin efforts. After struggling with several versions of a wooden framed, wheeled "wagon", a thought occurred that I may be "reinventing the wheel" (as usual). Has anyone out there found a method to move the "engine on fuselage without wings" or move a completed plane with one wing removed?? The M1 has main gear on the wings, not on the fuselage. Thanks, Dick -- John Kimmel Naturally, these humorous remarks are all entirely my own opinion, based solely on rumor, supposition, innuendo and damned lies, and should be interpreted in a spirit of fun. My memory is faulty, also. |
Midget Mustang, single seater experimental.
There are 2 other planes crammed into the hanger and having wings installed is not an option at this time. The builders on the field have broke-in engines on a fuselage without wings several times previously. Safety of course is most important. I find builders innovative and some, basically cheap (myself). Hence the 2x4 approach. Although my stand has no duct tape, we did race a formula Vee back in the 60's and sometimes used duct tape for securing body skin at 95-100 mph.. "guynoir" wrote in message ... I don't know what an "M1" is. I think you you plan on mounting your engine to the fuselage, then mounting the fuselage on some sort of wheeled table so that you can move the assembly around, and also run the engine (not while you're moving it around, of course). And you want it to be simple, cheap and easy to build, made out of 2 x 4's held together with drywall screws and duct tape. I happen to know a very simple solution, much simpler than building a custom carriage. This method has been thoroughly tested and it really is the way that at least 99% of successful aircraft builders do it. Attach both wings and the landing gear to the aircraft, and then hook up all engine and airframe systems before running the engine. That way the aircraft is easy to move around on its own wheels, you have a safe engine test stand for engine break in, and you're running the aircraft as a complete system, the way it was designed to work. Why would anyone want to do it any differently? Skystar Aircraft, manufacturers of the Kitfox, almost went bankrupt when a runaway 182 went through their hangar. The A&P mechanic decided to test run the engine without installing the pilot seats. He had the throttle linkage backwards. When the engine ran away from him, he lost his balance in the unfurnished cockpit and became a baggage compartment passenger while the 182 made a full throttle tour of Skystar's hangar. $300,000 in uninsured damage for Skystar. That sounds like the kind of adventure you're preparing for. Dick wrote: Having a "better G" idea, decided to hang my engine on M1 fuselage without wings in order to have the ability to roll it outside the hanger for breakin efforts. After struggling with several versions of a wooden framed, wheeled "wagon", a thought occurred that I may be "reinventing the wheel" (as usual). Has anyone out there found a method to move the "engine on fuselage without wings" or move a completed plane with one wing removed?? The M1 has main gear on the wings, not on the fuselage. Thanks, Dick -- John Kimmel Naturally, these humorous remarks are all entirely my own opinion, based solely on rumor, supposition, innuendo and damned lies, and should be interpreted in a spirit of fun. My memory is faulty, also. |
I still don't understand why you want to break in an engine on a
non-flying aircraft. What's the point? You're going to have to finish putting the aircraft together anyway, and it will probably be days, weeks or months between the assembly and actual airworthiness. Why not run the engine then? Dick wrote: Midget Mustang, single seater experimental. There are 2 other planes crammed into the hanger and having wings installed is not an option at this time. The builders on the field have broke-in engines on a fuselage without wings several times previously. Safety of course is most important. I find builders innovative and some, basically cheap (myself). Hence the 2x4 approach. Although my stand has no duct tape, we did race a formula Vee back in the 60's and sometimes used duct tape for securing body skin at 95-100 mph.. -- John Kimmel Naturally, these humorous remarks are all entirely my own opinion, based solely on rumor, supposition, innuendo and damned lies, and should be interpreted in a spirit of fun. My memory is faulty, also. |
I don't know if you're pulling my leg or not,but..
some reasons a Running the engine gives a lot of personal satisfaction; debugging the instrumentation and operating parameters as actually connected to the planes panel and not on a test stand; something to do while awaiting parts, whatever; can figure out exhaust and mufflers layout; can figure out cowling fit; can solve any heating/cooling problems; etc, etc.. Boils down to my project and whatever makes me happy G "guynoir" wrote in message ... I still don't understand why you want to break in an engine on a non-flying aircraft. What's the point? You're going to have to finish putting the aircraft together anyway, and it will probably be days, weeks or months between the assembly and actual airworthiness. Why not run the engine then? Dick wrote: Midget Mustang, single seater experimental. There are 2 other planes crammed into the hanger and having wings installed is not an option at this time. The builders on the field have broke-in engines on a fuselage without wings several times previously. Safety of course is most important. I find builders innovative and some, basically cheap (myself). Hence the 2x4 approach. Although my stand has no duct tape, we did race a formula Vee back in the 60's and sometimes used duct tape for securing body skin at 95-100 mph.. -- John Kimmel Naturally, these humorous remarks are all entirely my own opinion, based solely on rumor, supposition, innuendo and damned lies, and should be interpreted in a spirit of fun. My memory is faulty, also. |
See........ Dick is a dick. "Dick" wrote in message ... I don't know if you're pulling my leg or not,but.. some reasons a Running the engine gives a lot of personal satisfaction; debugging the instrumentation and operating parameters as actually connected to the planes panel and not on a test stand; something to do while awaiting parts, whatever; can figure out exhaust and mufflers layout; can figure out cowling fit; can solve any heating/cooling problems; etc, etc.. "guynoir" wrote in message ... I still don't understand why you want to break in an engine on a non-flying aircraft. What's the point? You're going to have to finish putting the aircraft together anyway, and it will probably be days, weeks or months between the assembly and actual airworthiness. Why not run the engine then? Dick wrote: Midget Mustang, single seater experimental. There are 2 other planes crammed into the hanger and having wings installed is not an option at this time. The builders on the field have broke-in engines on a fuselage without wings several times previously. Safety of course is most important. I find builders innovative and some, basically cheap (myself). Hence the 2x4 approach. Although my stand has no duct tape, we did race a formula Vee back in the 60's and sometimes used duct tape for securing body skin at 95-100 mph.. -- John Kimmel Naturally, these humorous remarks are all entirely my own opinion, based solely on rumor, supposition, innuendo and damned lies, and should be interpreted in a spirit of fun. My memory is faulty, also. |
Your reasons for running the engine suck. A proper, deliberate and
methodical approach to finishing your aircraft will result in a finished flying aircraft in the minimum time and with fewest problems. Disasters like the Skystar incident are rare, but pursuit of instant gratification is all the invitation needed. I agree with your reasons for having the engine mounted on the fuselage. You have already figured out a way to support the fuselage with the engine on it, since you have the fuselage completed and the engine is mounted on it. It seems to me that there is no obstacle to your completing the aircraft. Final debugging can be done with the wings and landing gear installed, as has been the usual practice for everyone else who's ever built a midget mustang or mustang 2. Dick wrote: I don't know if you're pulling my leg or not,but.. some reasons a Running the engine gives a lot of personal satisfaction; debugging the instrumentation and operating parameters as actually connected to the planes panel and not on a test stand; something to do while awaiting parts, whatever; can figure out exhaust and mufflers layout; can figure out cowling fit; can solve any heating/cooling problems; etc, etc.. Boils down to my project and whatever makes me happy G "guynoir" wrote in message -- John Kimmel Naturally, these humorous remarks are all entirely my own opinion, based solely on rumor, supposition, innuendo and damned lies, and should be interpreted in a spirit of fun. My memory is faulty, also. |
I was originally going to suggest making a structure that would bolt to
the ends of the main spar fittings, but that could impart stress on those fittings that could damage them. The bed/carpet sling idea is OK, except that you will be running the engine, not just moving the assembly around. How about making a wood structure that "sandwiches" the wing stub ( say about a foot outboard of the fuselage sides ) Think of the "clapboard" that the movie industry uses before each "take" of a scene. Cut out the shape of the airfoil between (2) 2 x 8's. Hinge the 2 x 8's on one end and bolt them together on the opposite end. Then extend a vertical board on the forward end of the structure and put casters/wheels on the end. You could arrange the casters far enough forward that you wouldn't have to add weight to the tail with the wings removed. Make one for each side and maybe secure each structure to the other one for rigidity. Of course making the whole thing stout as hell and protect the wing. Might work. Neal |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | July 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 07:27 AM |
