Engine driven fuel pump necessary with gravity feed tank?? Lycoming
Old May 8th 05, 03:02 AM
RonLee
Default Engine driven fuel pump necessary with gravity feed tank?? Lycoming
Situation with experimental airplane:
Gravity feed tank with Lyc IO320B1A fuel injected engine.
Gravity free fuel flow is greater than 20 gph and the engine burns 15
gph at full throttle take off.
Cruse fuel flow 7.5 to 8 gph.
I want to test the engine without the engine driven fuel pump as I
feel it is not a necessary item. For start priming the engine I use an
electric fuel pump (Dukes).
Any one have knowledge of this situation? Perhaps the fuel injected
engine needs the fuel pressure
All comments welcome.........thanks
Old May 8th 05, 03:31 AM
On Sun, 08 May 2005 02:02:55 GMT, RonLee
"generally" injection requires pressure. Otherwize it's just
dribbling.
Old May 8th 05, 06:10 PM
Check the FARs. In Canada, at least, a gravity fed fuel system must
flow 150% of max required fuel flow in the most critical attitude for
flight with minimum fuel aboard. A pump system requires 125%. Your 20
gph won't cut it.
Dan
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
Rick Stitt strikes again... Please Read. Dennis Chitwood Rotorcraft 13 January 10th 04 05:29 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
