https://en.wikipedia.org/wiki/Republic_XF-12_Rainbow
The Republic XF-12 Rainbow was an American four-engine, all-metal prototype reconnaissance aircraft designed by the Republic Aviation Company in the late 1940s. Like most large aircraft of the era, it used radial engines—in this case, the Pratt & Whitney R-4360 Wasp Major. The aircraft was designed with maximum aerodynamic efficiency in mind. The XF-12 was referred to as an aircraft that was "flying on all fours" meaning: four engines, 400 mph cruise, 4,000 mile range, at 40,000 feet. It is still the fastest piston-engined airplane of this size, exceeding by some 50 mph the Boeing XB-39 of 1944. Although highly innovative, the postwar XF-12 Rainbow had to compete against more modern jet engine technology, and did not enter production. Development The original proposal for the aircraft, delivered in late 1943, came from the USAAC Air Technical Service Command, stationed at Wright Field. The proposal was for a reconnaissance aircraft which included a requirement for speed (400 mph), ceiling (40,000 ft), and range (4,000 nmi). Its primary objective was for high-speed overflights of the Japanese homeland and key enemy installations. During World War II, due to the extended range requirements of operating in the Pacific, existing fighters and bombers were being used for missions for which they were never intended. The need existed for an aircraft specifically designed for the photo-reconnaissance mission. The aircraft required adequate speed, range, and altitude capabilities for its missions to be successful. In August 1943, U.S. President Franklin D. Roosevelt's son, Colonel Elliot Roosevelt, commander of the F-5 (modified P-38) "recon" unit, recommended the acquisition of a dedicated high-performance photo reconnaissance aircraft, capable of providing pre-strike target acquisition and photo interpretation. Followed by additional overflights to provide post-strike analysis of their subsequent destruction, this would give commanders the ability to make pivotal strategic decisions and set up subsequent raids. The XF-12 was Republic Aviation's attempt to meet those goals. Its primary competition during this time was the Hughes XF-11. Both were introduced at the same time, and both were powered by the new P&W R-4360. The XF-12's first flight was made on 4 February 1946. During the XF-12's subsequent flight testing and development period, it demonstrated the capability of operating at 45,000 feet (14,000 m), at a speed of 470 mph (760 km/h), over a range of 4,500 mi (7,200 km), so it met and exceeded the design goals for which it had been designed. Neither the XF-11 nor the XF-12 was purchased in any quantity by the U.S. Army Air Forces (two each), as their need evaporated after hostilities ended in World War II. Design Low drag was a primary consideration throughout the design of the XF-12. Many of its features were taken directly from Republic's considerable experience with fighter plane design. In an extremely rare case of design direction, absolutely no compromise with aerodynamics was made in the shape of its fuselage. Aviation Week was quoted as saying "the sharp nose and cylindrical cigar shape of the XF-12 fulfills a designer's dream of a no compromise design with aerodynamic considerations." To fulfill its reconnaissance role, the XF-12 contained three separate photographic compartments aft of the wing. One vertical, one split vertical, and one trimetrogon each using a six-inch Fairchild K-17 camera. For night reconnaissance missions, the XF-12 had a large hold in the belly which accommodated 18 high-intensity photo-flash bombs; these were ejected over the target area. All of the bays were equipped with electrically operated, inward retracting doors (again designed for maximum aerodynamic cleanliness). The camera lenses were electrically heated to eliminate distortion. All of this combined to allow full photo operations during high speed flights. The XF-12 also carried a variety of photographic equipment, including complete darkroom facilities to permit the development and printing of films in flight. This was augmented by adjustable storage racks, able to handle any size film containers and additional photo equipment. This allowed the Army Intelligence units to have immediate access to the intelligence the aircraft was able to collect, with no delay in processing. The Rainbow featured a wing of straight taper with squared tips and high aspect ratio for maximum efficiency. The engines featured a sliding cowl arrangement to facilitate cooling airflow instead of the normal cowl flaps, which caused too much drag. At the front of the cowls, the engines were also fitted with a two-stage "impeller fan" directly behind the propeller hub and prop spinner. This allowed the engines to be tightly cowled for aerodynamic efficiency, but still provide the cooling airflow the engines required. When the sliding cowl ring was closed (during flight), the air used for cooling the engine was ducted through the nacelle to the rear exhaust orifice for a net thrust gain, as opposed to the usual cooling drag penalty. Role Strategic aerial reconnaissance National origin United States Manufacturer Republic Aviation First flight 4 February 1946 Retired June 1952 Status Cancelled Primary user United States Army Air Forces Number built 2 Unit cost $1.25 Million (1946 Dollars) Operational history The first prototype was damaged in landing on 10 July 1947. The aircraft was undergoing maximum landing weight tests. During one particularly hard landing, the right main gear was severed at the engine nacelle. The aircraft bounced hard, and staggered back into the air. The test pilot was able to maintain control, and climb to a safe altitude. He continued to fly the aircraft to burn off excess fuel, to both make the aircraft lighter and lessen the chance of fire. Once excess fuel was burned off, the pilot landed on the left main gear and the nose wheel. The pilot touched down, and while keeping the right wing up, scrubbed off as much speed as possible before it touched down. During the incident the aircraft suffered significant damage. The right wing spar was cracked, and the #3 and #4 engines and props needed to be replaced due to the ground contact. The aircraft was repaired by Republic, and later returned to service. The only external difference between the first and second prototypes was the addition of cooling gills on the upper engine cowlings. Internally, the second prototype was far more "finished." This included its full operational reconnaissance equipment suite, to allow for further testing. On 7 November 1948, prototype number two, 44-91003, crashed at 13:00 while returning to Eglin Air Force Base, Florida. The number 2 (port inner) engine exploded as the aircraft was returning from a photographic suitability test flight. The pilot was unable to maintain control due to violent buffeting, and he ordered the crew to bail out. Five of the seven crew escaped safely, including pilot Lynn Hendrix, rescued by Eglin crash boats and helicopters. The airframe impacted two miles south of the base in the Choctawhatchee Bay. Sgt. Vernon B. Palmer and M/Sgt. Victor C. Riberdy were killed. The first prototype, which returned to service in 1948, continued the flight testing and development phase. After the U.S. Air Force declined to order any additional aircraft, and with the loss of the second prototype, the flight testing period wound down. In June 1952, the first prototype, 44-91002, was retired (having flown just 117 additional hours from 1949–1952), was stricken from the U.S. Air Force inventory, and ended up as a target on the Aberdeen Proving Ground, Maryland. Had the XF-12 Rainbow been available in 1944, it almost inevitably would have been ordered in quantity, and along with its civilian counterpart, the whole postwar structure of aircraft markets might have been altered. As it was, the XF-12 disappeared into oblivion, despite its graceful lines and high performance. According to Machat, the Rainbow remains the ultimate expression of multi-engine, piston-powered aircraft design. Its high speed, near-perfect streamlined form, and neatly cowled engines make it a design classic, often unappreciated, and not very well known. The XF-12 was the fastest, four engine pure piston-powered aircraft of its day, and the only one ever to exceed 450 mph in level flight. The closest the USAF ever got to the Rainbow, the 44 (converted from bombers) Boeing RB-50Bs, could only reach 385 mph at 25,000 feet with exactly the same engines (Wasp Majors). Specifications (XF-12) General characteristics Crew: 7 Capacity: (RC-2: 46 pax) Length: 93 ft 10 in (28.59 m) (RC-2: 98 ft 9 in (30.10 m)) Wingspan: 129 ft 2 in (39.36 m) Height: 28 ft 4 in (8.63 m) (RC-2: 29 ft 11 in (9.12 m)) Wing area: 1,640 sq ft (152 m2) Empty weight: 65,000 lb (29,484 kg) (RC-2: 66,980 lb (30,380 kg)) Gross weight: 101,400 lb (45,994 kg) (RC-2: 114,200 lb (51,800 kg)) Fuel capacity: 5,000 US gal (4,200 imp gal; 19,000 l) Powerplant: 4 × Pratt & Whitney R-4360-31 Wasp Major 28-cyl. four-row air-cooled radial piston engines, 3,250 hp (2,420 kW) each Propellers: 4-bladed Curtiss, 16 ft 1 in (4.9 m) diameter reversible-pitch constant-speed propellers Performance Maximum speed: 470 mph (760 km/h, 410 kn) plus (RC-2: 450 mph (390 kn; 720 km/h)) Cruise speed: 400 mph (640 km/h, 350 kn) at 40,000 ft (12,000 m) Stall speed: 104 mph (167 km/h, 90 kn) Range: 4,500 mi (7,200 km, 3,900 nmi) (RC-2: 4,100 mi (3,600 nmi; 6,600 km)) Service ceiling: 44,000 ft (13,000 m) plus (RC-2: 41,000 ft (12,000 m)) Rate of climb: 5,000 ft/min (25 m/s) plus (RC-2: 1,680 ft/min (510 m/min)) Wing loading: 61.8 lb/sq ft (302 kg/m2) (RC-2: 69.6 lb/sq ft (340 kg/m2)) Power/mass: 8.4 lb/hp (5.09 kg/kW) (RC-2: 8 lb/hp (4.855 kg/kW)) Take-off distance ![]() Landing distance: (RC-2: 3,550 ft (1,080 m) from 50 ft (15 m)) * |
Republic XF-12 Rainbow pics 2 [6/7] - Republic XF-12 Rainbow camera installation.jpg (1/1) | Miloch | Aviation Photos | 0 | May 10th 19 03:05 PM |
Republic XF-12 Rainbow pics 2 [5/7] - Republic XF-12 Rainbow camera installation 2.jpg (1/1) | Miloch | Aviation Photos | 0 | May 10th 19 03:05 PM |
Republic XF-12 Rainbow pics 2 [09/14] - Republic XF-12 Rainbow engine inspection.jpg (1/1) | Miloch | Aviation Photos | 0 | August 29th 17 02:52 PM |
Republic XF-12 Rainbow pics 2 [07/14] - Republic XF-12 Rainbow camera installation-1.jpg (1/1) | Miloch | Aviation Photos | 0 | August 29th 17 02:52 PM |
Republic XF-12 Rainbow pics 2 [06/14] - Republic XF-12 Rainbow camera installation.jpg (1/1) | Miloch | Aviation Photos | 0 | August 29th 17 02:52 PM |
