I have a 1918 German barograph, photos are at the URL below. It appears complete but I do not know how to make it work. Apparently it has to be wound-up. I also have a photo of the underside of the metal tray, if you need to see that.
https://www.aeroconservancy.com/flugzeug |
On Thursday, October 29, 2020 at 3:16:14 PM UTC-4, Charles Gosse wrote:
I have a 1918 German barograph, photos are at the URL below. It appears complete but I do not know how to make it work. Apparently it has to be wound-up. I also have a photo of the underside of the metal tray, if you need to see that. https://www.aeroconservancy.com/flugzeug Hello Charles - this is indeed a piece of aviation history! It looks just like an early version of the popular Winter Barographs. There has to be a clockwork located under the drum. If you could post a link to a picture of the underside of the tray, it most likely will show a hole for a key used to wind up the movement or a bail that folds out to wind it up. Take a look into the drum. There is most likely a thumb-screw used to removed the drum. Also, the front plate is labeled 'Umdrehungszeit 2' meaning the drum will turn once every 2 hours. The clockwork may have a lever to change the drum speed to go slower or faster. Thanks for sharing this link! Uli 'AS' |
On Thursday, October 29, 2020 at 2:16:14 PM UTC-5, Charles Gosse wrote:
I have a 1918 German barograph, photos are at the URL below. It appears complete but I do not know how to make it work. Apparently it has to be wound-up. I also have a photo of the underside of the metal tray, if you need to see that. https://www.aeroconservancy.com/flugzeug That's the kind of device you'd expect hanging above the basket of a hydrogen balloon. A precious piece of aviation history! |
On Thursday, October 29, 2020 at 6:10:20 PM UTC-4, Herbert Kilian wrote:
On Thursday, October 29, 2020 at 2:16:14 PM UTC-5, Charles Gosse wrote: I have a 1918 German barograph, photos are at the URL below. It appears complete but I do not know how to make it work. Apparently it has to be wound-up. I also have a photo of the underside of the metal tray, if you need to see that. https://www.aeroconservancy.com/flugzeug That's the kind of device you'd expect hanging above the basket of a hydrogen balloon. A precious piece of aviation history! Hello Herbert, I am really unfamiliar with google Groups. After you responded here I received an email with your response, as well, and tried to reply to that in gmail with photos but Google responded that they couldn't find the rec.soaring address. Anyway,I can't figure out how to add a photo here. Can you tell me? Charley |
On Friday, October 30, 2020 at 2:27:19 PM UTC-4, Charles Gosse wrote:
On Thursday, October 29, 2020 at 6:10:20 PM UTC-4, Herbert Kilian wrote: On Thursday, October 29, 2020 at 2:16:14 PM UTC-5, Charles Gosse wrote: I have a 1918 German barograph, photos are at the URL below. It appears complete but I do not know how to make it work. Apparently it has to be wound-up. I also have a photo of the underside of the metal tray, if you need to see that. https://www.aeroconservancy.com/flugzeug That's the kind of device you'd expect hanging above the basket of a hydrogen balloon. A precious piece of aviation history! Hello Herbert, I am really unfamiliar with google Groups. After you responded here I received an email with your response, as well, and tried to reply to that in gmail with photos but Google responded that they couldn't find the rec.soaring address. Anyway,I can't figure out how to add a photo here. Can you tell me? Charley Here is a photo of the underside. The green arrow points toward a clock-work mechanism that seems completely turned tight. What action or button starts the drum to turn? https://www.dropbox.com/s/eh95drbxcy...0side.jpg?dl=0 Here is a photo looking down at the drum. https://www.dropbox.com/s/mxjbxz70xw...0drum.jpg?dl=0 |
On Friday, October 30, 2020 at 2:56:53 PM UTC-4, Charles Gosse wrote:
On Friday, October 30, 2020 at 2:27:19 PM UTC-4, Charles Gosse wrote: On Thursday, October 29, 2020 at 6:10:20 PM UTC-4, Herbert Kilian wrote: On Thursday, October 29, 2020 at 2:16:14 PM UTC-5, Charles Gosse wrote: I have a 1918 German barograph, photos are at the URL below. It appears complete but I do not know how to make it work. Apparently it has to be wound-up. I also have a photo of the underside of the metal tray, if you need to see that. https://www.aeroconservancy.com/flugzeug That's the kind of device you'd expect hanging above the basket of a hydrogen balloon. A precious piece of aviation history! Hello Herbert, I am really unfamiliar with google Groups. After you responded here I received an email with your response, as well, and tried to reply to that in gmail with photos but Google responded that they couldn't find the rec.soaring address. Anyway,I can't figure out how to add a photo here. Can you tell me? Charley Here is a photo of the underside. The green arrow points toward a clock-work mechanism that seems completely turned tight. What action or button starts the drum to turn? https://www.dropbox.com/s/eh95drbxcy...0side.jpg?dl=0 Here is a photo looking down at the drum. https://www.dropbox.com/s/mxjbxz70xw...0drum.jpg?dl=0 Charles, thanks for the picture of tray's underside. You are correct - the key is used to wind the clock. If you look at the front side of the Barograph - the one that has the handle on it, you can see a sliding lever in the lower left corner. Slide that lever to the left until it snaps upwards into the detent. That starts the clockwork. The detent prevents an accidental stop of the recording. The second function of that lever is to move the recording arm onto the drum to create the trace. In your case, it looks like there is a small ink reservoir at the tip of the arm, which draws the line. Other options were a stylus, which scratched the trace onto a waxed paper or onto a layer of soot on an aluminum foil, etc. Let us know if you can get the clock to tick. ;-) Uli 'AS' |
On Friday, October 30, 2020 at 4:45:30 PM UTC-4, AS wrote:
On Friday, October 30, 2020 at 2:56:53 PM UTC-4, Charles Gosse wrote: On Friday, October 30, 2020 at 2:27:19 PM UTC-4, Charles Gosse wrote: On Thursday, October 29, 2020 at 6:10:20 PM UTC-4, Herbert Kilian wrote: On Thursday, October 29, 2020 at 2:16:14 PM UTC-5, Charles Gosse wrote: I have a 1918 German barograph, photos are at the URL below. It appears complete but I do not know how to make it work. Apparently it has to be wound-up. I also have a photo of the underside of the metal tray, if you need to see that. https://www.aeroconservancy.com/flugzeug That's the kind of device you'd expect hanging above the basket of a hydrogen balloon. A precious piece of aviation history! Hello Herbert, I am really unfamiliar with google Groups. After you responded here I received an email with your response, as well, and tried to reply to that in gmail with photos but Google responded that they couldn't find the rec.soaring address. Anyway,I can't figure out how to add a photo here. Can you tell me? Charley Here is a photo of the underside. The green arrow points toward a clock-work mechanism that seems completely turned tight. What action or button starts the drum to turn? https://www.dropbox.com/s/eh95drbxcy...0side.jpg?dl=0 Here is a photo looking down at the drum. https://www.dropbox.com/s/mxjbxz70xw...0drum.jpg?dl=0 Charles, thanks for the picture of tray's underside. You are correct - the key is used to wind the clock. If you look at the front side of the Barograph - the one that has the handle on it, you can see a sliding lever in the lower left corner. Slide that lever to the left until it snaps upwards into the detent. That starts the clockwork. The detent prevents an accidental stop of the recording. The second function of that lever is to move the recording arm onto the drum to create the trace. In your case, it looks like there is a small ink reservoir at the tip of the arm, which draws the line. Other options were a stylus, which scratched the trace onto a waxed paper or onto a layer of soot on an aluminum foil, etc. Let us know if you can get the clock to tick. ;-) Uli 'AS' I slid the lever over to the left but I can't raise it up into the detent because there's this other metal arm in the way. https://www.dropbox.com/s/fsfqx3blos...lever.jpg?dl=0 I flipped it over and took a photo of the underside. On the right is the lever and on the left is the thing in the way. https://www.dropbox.com/s/t6cazpshtv...0view.jpg?dl=0 I'm clueless. |
FS: 2 E. H. Replogle Barographs | [email protected] | Soaring | 0 | April 22nd 14 02:38 AM |
Barograph Blues | Steve Leonard | Soaring | 3 | May 12th 07 03:57 AM |
For Sale- Replogle barograph | [email protected] | Soaring | 5 | April 24th 06 02:41 AM |
Replogle Barograph For Sale | Guy Byars | Soaring | 0 | September 19th 05 10:07 AM |
FS Replogle Barograph | Al Groth | Soaring | 0 | August 14th 04 11:24 PM |
