IL2 Forgotten Battles Displays upside down
Old May 10th 05, 10:20 AM
LeonardR
Default IL2 Forgotten Battles Displays upside down
Hi folks;
Hope you can help me I have just installed IL2 Forgotten Battles but
everytime i start it up it displays upside down on my system.
I dont know how to fix this any suggestions?
I am running it on a newly purchased computer with XP Professional,
2.8GHz CPu and 504 Mb of ram.
The system runs FS2002, CFS2 and CFS3 rightway up but IL2 FB runs
upside down.
Thanks for any help
Old May 10th 05, 12:14 PM
Quilljar
You are taking the Mickey aren't you?
Check your joystick config in IL2, maybe it's set to inverted :-) :-)
Cheers,
Quilly
An individual reply goes into my spam filter
Old May 10th 05, 06:47 PM
Peter Duniho
"LeonardR" wrote in message
504MB? Really? That's a very strange number of MB of RAM to have
installed.
upside down.
What kind of video card do you have? What resolution (width, height, pixel
depth) are you using for the game? For your desktop?
I suspect that your default resolution is something unusual, and that IL2
doesn't correctly handle the inverted frame buffer format (it's assuming
it's a normal top-down format, when the resolution is actually bottom-up).
I've never actually heard of that happening, but it's the only thing that
makes sense to me, given that other games work on your computer, and that it
seems sure that IL2 runs fine on other people's computers.
If changing the desktop and/or game to a more conventional resolution
doesn't help, there may be a setting somewhere in the video card "Advanced"
settings that will help. It may or may not be obvious; the
top-down/bottom-up thing might be affected by some seemingly unrelated
setting, like texture MIP-mapping, z-buffer settings, or something like
that.
If you do get it fixed, please post back here to describe what you needed to
do to fix it (and what was wrong in the first place).
Pete
Old May 11th 05, 12:23 PM
LeonardR
thanks for that I will go through the settings and see what has gone
wrong and let you know.
The wife mentioned that i might want to stand on my head to play the
game, not too sure if she was serious though :-)
Old May 11th 05, 07:23 PM
Peter Duniho
Might not be a bad way to simulate the "red out" during those hard
negative-G maneuvers.
Old May 12th 05, 12:15 PM
LeonardR
Well I tried every setting possible with no joy. I am going to try it
on my laptop and see if the prob shows on a different system.
I dont understand how this computer can play CFS2 But not mission
builder), CFS3 and FS2002 without a hitch but not IL2 FB.
the system i am running it on is
HP Compaq DX6120 MT(PV02PA)
Windows XP PRO
2.8GHx CPU with 504MB ram (yep odd but true)
and the Video adaptor which runs everything else is id as
Intel 82915G/GV/910GL Express Chipset Family with 128MB RAM
It's frustrating as IL2 FB has all the aircraft i have been looking for
in one place.
Ah well will let you know if i fix it
thanks
Old May 12th 05, 09:41 PM
Peter Duniho
What doesn't work about the mission builder? Is it upside down too?
Also, can you confirm that by "upside down", you really mean that the
vertical axis is reversed? That is, the image isn't rotated 180 degrees,
but rather is as though you're looking at it in a mirror oriented
horizontally? (And thus, playing on your head wouldn't really fix the
problem, because all the text would be reversed)
Intel claims that your adapter works fine with IL2:
http://www.intel.com/support/graphic.../CS-011967.htm
Have you downloaded and installed the latest drivers for that hardware?
It's possible that there used to be a known problem that was fixed with a
driver update.
I suppose that there's a remote possibility that there's something wrong
with the video adapter hardware itself. Is your computer still under
warranty? Have you checked with HP to ask them about the problem?
Whether it's a hardware problem or not, I suppose one solution would be to
just get a new graphics adapter. It's not like Intel's stuff is known for
being all that great in the first place; probably wouldn't cost much to get
something at least as good.
Pete
Old May 16th 05, 08:24 PM
E Taylor
LeonardR wrote:
Hi folks;
upside down.
Thanks for any help
You might want to try support at IL2's website. It can be kind of a
pain but they've been pretty helpful to me, and they will answer email.
http://www.pacific-fighters.com/en/home.php?skin=S2
Old May 17th 05, 10:14 AM
Quilljar
Seriously; have you tried turning the CD over?
Cheers,
Quilly
