Sticking altimeter
Old November 5th 20, 08:46 PM posted to rec.aviation.soaring
Kenn Sebesta
Default Sticking altimeter
My altimeter in my AC-5M is sticking. It works fine when the engine is on or when you tap on the window, but otherwise when gliding it gets stuck up to 100' worth. I suspect that a rebuild will cost as much as a new one will, so I'd rather go the route of fixing it myself (or replacing it with something with added functionality).
Any suggestions on fixing it?
Old November 5th 20, 09:28 PM posted to rec.aviation.soaring
Mike Reid
You're just flying too smoothly. Jet aircraft have electric altimeter vibrators to solve this problem.
Mike
Old November 6th 20, 07:33 PM posted to rec.aviation.soaring
Kenn Sebesta
About my flying, said to no one ever.
On Thursday, November 5, 2020 at 4:44:13 PM UTC-5, wrote:
You did not say what kind of altimeter you have?
It's a Falcon ALT20INF-3, http://www.falcongauge.com/xinjia/ALT20INF-3.jpg
Replace it with a...!
I love the idea of some of these products, but I'd rather redo the entire panel all at once so that I can optimize for space, ergonomics, and redundancy. If I can make this altimeter work just a little more smoothly it would buy me some valuable time.
Old November 6th 20, 11:39 PM posted to rec.aviation.soaring
2G
Here is one place that rebuilds altimeters:
http://rudyaircraftinstruments.com/Overhaul_Prices.html
Not sure if rebuilding includes certification (it should).
Personally, I would switch to electronic if I were you. I have a Garmin G5 in my glider and I love the smooth response; you can even use it as a vario.
https://buy.garmin.com/en-US/US/p/570665
This replaces about 5 other instruments at a very reasonable cost.
Tom
Old November 5th 20, 09:44 PM posted to rec.aviation.soaring
Dave Nadler
The vibration from the engine may have trashed the ALT bearings,
a common problem for ASI and ALT in gas-powered motorgliders.
Old November 5th 20, 09:54 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
If you're flying in a dusty place and don't have any filters fitted, i.e.
the port in the back of the altimeter is open to cockpit air, could it
have got dust or smoke in it?
If you have an instrument maintainer handy, ask them about the necessity
and cost of servicing.
I'm in the UK, so not much dust in the air here. My altimeter hasn't
misbehaved in the 15 years I've had the glider. For that matter I suspect
it was installed when the glider was new, 51 years and several owners ago.
Martin | martin at
Gregorie | gregorie dot org
Old November 5th 20, 10:07 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Kenn Sebesta wrote on 11/5/2020 12:46 PM:
That sounds like normal operation for a mechanical altimeter; certainly for the ones I've
owned. Use an electronic altimeter to avoid the sticking. A lot of varios and flight computers
have the altitude function in them. My next glider will have one of these in it - no sticking,
lots of extra functionality, and replaces 3 instruments!
https://wingsandwheels.com/lxnav-airdata-indicator.html
Old November 6th 20, 01:24 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
ACD Air Avionics Altimeter and more.
http://www.craggyaero.com/acd_altimeter.htm
IN Stock.
Richard
www.craggyaero.com
Old November 6th 20, 12:58 PM posted to rec.aviation.soaring
waremark
"ACD Air Avionics Altimeter and more."
There is also the LXNav Air Data Indicator - combined altimeter and ASI.
With either of these devices, is there any battery backup? Is there a legal requirement for a battery independent system? Do you have to have any instrumentation separate from the flight computer since flight computers can display all of altitude/height, airspeed and vario, and can control radio and transponder?
Old November 6th 20, 03:28 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
waremark wrote on 11/6/2020 4:58 AM:
I contacted Paul Remde of Cumulus Soaring, who also carries the LXNav ADI:
https://www.cumulus-soaring.com/store/lxnav-adi
He says he doesn't have one in stock right now to test, but the manual does not mention an
internal backup battery, so he doubts that it does. His recommendation, and what a lot of us do
already, is two redundant batteries you can switch between. Since the ADI will be my primary
ASI, I may power through two diodes, one to each battery, so no switching is required, and it
will always be powered by the battery with the most voltage.
Mylar Not Sticking Gary Wayland Soaring 13 January 13th 19 07:10 PM
WTB: used 57mm Altimeter OR swap for 80mm Altimeter joesimmers Soaring 0 November 3rd 09 11:59 AM
Zen and the sticking RG-45 rod wright1902glider Home Built 5 February 20th 09 06:10 AM
Sticking yoke soxinbox Owning 15 February 28th 06 04:36 AM
STICKING YOUR NECK OUT? SelwayKid Piloting 4 January 3rd 04 12:13 AM
