I've been asked to do a follow on article on Porting & Polishing for The
Aviation Consumer from a user perspective, as it pertains to certified engines. (The article I wrote in Light Planes Maintenance was from a mechanical perspective.) Would like some user feedback, good or bad. If you have a certified aircraft and had your cylinders Ported and Polished: - Why did you do it? - How much did it cost (per cylinder)? - Did the shop flow match or use a flow bench? ("Don't know" is okay answer.) - Did the shop do a fancy valve grind as part of the package? - If you flew the engine before the change, and if that's all that changed (i.e. no higher compression pistons) can you tell any difference in performance? Any WOW! factor? - How did climb, top speed, cruise speed and fuel burn change? - Any problems related to P&P? (any cylinder cracking in the head?) - If the shop worked the valves, did you have any problems with valves before and are you having any problems now? - What kind of paperwork in the logbook, if any, discusses the modification to the cylinders? - Was it worth it? Would you do it again? I would appreciate your input. Please respond to mppalmer at a o l . c o m Thanks, Mike Palmer |
Mike;
Rather than asking the group, why not speak to some of the boutique engine builders that operate throughout the country. One that comes to mind is Bill Cunningham of Powermasters in Tulsa. he's a straight guy that will tell you the real story and you won't have to waste time trying to verify it. 918-299-0269 On Fri, 13 May 2005 23:22:31 -0700, MikePalmer wrote: I've been asked to do a follow on article on Porting & Polishing for The Aviation Consumer from a user perspective, as it pertains to certified engines. (The article I wrote in Light Planes Maintenance was from a mechanical perspective.) Would like some user feedback, good or bad. If you have a certified aircraft and had your cylinders Ported and Polished: - Why did you do it? - How much did it cost (per cylinder)? - Did the shop flow match or use a flow bench? ("Don't know" is okay answer.) - Did the shop do a fancy valve grind as part of the package? - If you flew the engine before the change, and if that's all that changed (i.e. no higher compression pistons) can you tell any difference in performance? Any WOW! factor? - How did climb, top speed, cruise speed and fuel burn change? - Any problems related to P&P? (any cylinder cracking in the head?) - If the shop worked the valves, did you have any problems with valves before and are you having any problems now? - What kind of paperwork in the logbook, if any, discusses the modification to the cylinders? - Was it worth it? Would you do it again? I would appreciate your input. Please respond to mppalmer at a o l . c o m Thanks, Mike Palmer |
Feedback needed on Porting & Polishing | JohnSmith | Owning | 4 | May 15th 05 01:00 AM |
Force Feedback Yoke? | Richard Kaplan | Simulators | 1 | December 31st 04 01:09 PM |
All feedback stick users....read this! | FaxCap | Simulators | 13 | January 1st 04 08:26 PM |
Clearence available upon request | Jeff | Instrument Flight Rules | 22 | November 17th 03 06:35 PM |
L.A. Times -- Request and Amendment | Blueskies | Home Built | 0 | August 11th 03 02:35 AM |
