New Battery Type?
Old November 26th 20, 03:27 AM posted to rec.aviation.soaring
AS
Default New Battery Type?
Winter is coming and it is time to get the annual Battery / Battery Charger discussion going.
I ran across this ad for a new (to me) battery type. It is a Lithium Nickel Manganese Cobalt Oxide (LiNiMnCoO2) chemistry and the Ah rating the mfg claims is phenomenal.
Has anybody seen or even used this type already?
http://www.millenair.nl/shop/batteri....4v-20.5ah-nmc
Uli
'AS'
Old November 26th 20, 04:38 AM posted to rec.aviation.soaring
Uli
'AS'
Yes, i made 3 packs for a guy who owns a discus with a lot of avionics and no place for much batteries.
He is reselling one (in Argentina) because with two has enough power to fly 24h transmitting with the radio.
The packs are made with the same cells that I have on the grasshopper and in most of the electric propulsion projects with the exception of FES that uses KOKAM cells.
The only thing that you need to look up before installing is the compatibility of your avionics with the output voltage.
And of course, taking good care of the packs.
Old November 26th 20, 12:15 PM posted to rec.aviation.soaring
Richard Large
escribi=C3=B3=
Charg=
er discussion going.=20
Nick=
the mfg
claims is phenomenal.=20
Has anybody seen or even used this type already?=20
=20
http://www.millenair.nl/shop/batteri...equipment/nmc-
batteries=
/airnergy-14.4v-20.5ah-nmc=20
=20
Uli=20
'AS'
and
to
fly=
and
i=
u=
ses KOKAM cells.
compatibil=
We have been using an NMC 20AH battery in our Arcus for the last year
running LX9000 F and R plus a radio and so far our longest flight has
been 7 hours bat then 14V so looks like 8 Hours possible, our 12v
LiF3PO4 only gave us 3.5Hrs, take care as initial voltage is approx 16v
Old November 26th 20, 04:06 PM posted to rec.aviation.soaring
John Galloway[_2_]
escribi=C3=B3=
Charg=
Nick=
the mfg
=20
batteries=
=20
Uli=20
'AS'
and
to
fly=
and
i=
u=
ses KOKAM cells.
compatibil=
I'll stick with LFP batteries. Apart from the price there are considerable human and environmental costs of current cobalt production, most of which comes from the DRC. Its no surprise that e.g. Tesla are trying move on from cobalt in their batteries.
Old November 26th 20, 04:19 PM posted to rec.aviation.soaring
Robert Danewid[_2_]
I have used such a battery since July. Works just fine for me in my ASG 32 Mi with lots of electronic stuff.
/Robert
Old November 26th 20, 04:59 PM posted to rec.aviation.soaring
AS
/Robert
So there is already some operational experience with this type of batteries, which is good to hear. The warnings about the initially high voltage of 16+V is well taken. I checked the spec's of the stuff I have on and behind my panel and most of it is limited to only 15V.
That would lead me to more follow-up questions for the experts:
- what would happen if this battery was charged with only 15V?
- if the above is not advisable, would the use of an electronic voltage regulator like this one be an option?
https://vetco.net/products/dc-dc-adj...kaAnEdEALw_wcB
- I am not familiar with this type of electronics but reading the specifications of it, I see a 'Ripple Frequency' of 150kHz on the output. Could that mess up the electronics?
Thanks for any constructive replies.
Uli
'AS'
Bristol Type 138 pics [8/8] - Bristol Type 138 Monoplane & Pressure Suit c1930s.jpg (1/1) Miloch Aviation Photos 0 September 4th 19 03:09 PM
Bristol Type 138 pics [7/8] - Bristol Type 138 Monoplane & Pressure Suit c1930s 2.jpg (1/1) Miloch Aviation Photos 0 September 4th 19 03:09 PM
Bristol Type 138 pics [6/8] - Bristol Type 138 High Altitude Monoplane, K4879. Completed in early 1936.jpg (1/1) Miloch Aviation Photos 0 September 4th 19 03:09 PM
Bristol Type 138 pics [5/8] - Bristol Type 138 high altitude aircraft with pressure suit.jpg (1/1) Miloch Aviation Photos 0 September 4th 19 03:08 PM
Bristol Type 138 pics [4/8] - Bristol Type 138 high altitude aircraft with pressure suit 2.jpg (1/1) Miloch Aviation Photos 0 September 4th 19 03:08 PM
