Identifying a Canopy Blank's Glider Model
Old November 30th 20, 04:19 AM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default Identifying a Canopy Blank's Glider Model
We have an unused canopy blank (no frame) wrapped in paper in our club's hangar's attic. It is in very nice shape and has been stored there for years.. No one seems to know anything about it or where it came from. We would like to identify and potentially sell it.
The canopy is 78" long and 24" wide at the rear. Rather long and tapers to a narrow rounded nose like a DG's or Diamont's canopy (https://en.wikipedia.org/wiki/FFA_Diamant).
A possible clue to the aircraft associated with this canopy is concerning the side window opening. First, there is only one opening which implies that it is for a single place ship. Second, the canopy has pre-drilled screw holes only located around the perimeter of the opening. This seems to preclude a Mecaplex window as there are no additional holes located aft of the opening for the rails.
Pictures of the canopy are available here; https://link.shutterfly.com/qI0hDPifPbb
Any idea?
- John (OHM)
Old November 30th 20, 04:23 AM posted to rec.aviation.soaring
The window opening is 6-1/2" x 4-1/2".
Old November 30th 20, 05:28 PM posted to rec.aviation.soaring
John Sinclair[_5_]
On Sunday, November 29, 2020 at 8:23:06 PM UTC-8, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Hi John,
It’s all in the curve......side view? Best way to check is to lay it over another ship. Yours is a good 10” longer than say the Standard Cirrus which is 68” long. I’d lay it over a DG and see how that looks. For reference the Standard Cirrus measurements a
Rear H -16”. Mid point H- 16”. Nose H- 8”
W- 24”. W-23”. W-20”
Overall length 68”
Hope this helps,
JJ
Old November 30th 20, 05:45 PM posted to rec.aviation.soaring
JJ - Thanks for the comments.
Within the club there is the opinion that this is the rear section of the two piece canopy system for an RV airplane.
Anyone have any comments on that front?
Thanks, John
Old December 1st 20, 12:42 AM posted to rec.aviation.soaring
Waveguru
Have you contacted Van's?
Boggs
Old December 1st 20, 12:48 AM posted to rec.aviation.soaring
Boggs
Contacting Vans or the Vans Airforce group is the next step.
glider canopy Morris Carter Soaring 7 February 13th 20 11:13 PM
Escaping glider on the ground with stuck canopy? Steve Koerner Soaring 27 May 21st 19 04:06 AM
Std Libelle Low profile canopy blank [email protected] Soaring 0 November 7th 15 09:35 PM
Where to get a glider canopy in the US Bob Kuykendall Soaring 0 September 4th 08 01:16 AM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
