lightweight hydraulic flap actuator?
Old May 15th 05, 06:08 PM
Default lightweight hydraulic flap actuator?
I was talking to a fellow that had a hydraulic flap actuator (hand
pumped) with a quick release return on a Top Cub. Anybody know of a
good source for these hand pumps? Any listers used something similar
for flaps and what did you think about it both in construction and
function?
I've thought of something like a floor jack pump but they're all too
heavy and have too short of travel. I need something with more throw
and less force and preferably made out of aluminum.
Joa
Old May 16th 05, 05:08 AM
Highflyer
function?
Joa
The Republic SeaBee uses a handpumped hydraulic system to drive the flaps.
They have a separate hydraulic cylinder for each flap. The flaps tend to go
down one at a time! Fortunately, the split flap condition is easy to handle
and doesn't cause a great deal of roll tendency.
Many GA airplanes use hydraulic flaps. Mooney and Piper Apache/Aztec come
to mind immediately. Look at the system in a Mooney. It has worked well
over the years.
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
PS: Annual Pinckneyville rec.aviation flyin is coming up friday, saturday,
and sunday. Let us know if you are planning on coming by emailing Mary at
so she knows how many steaks to buy.
Old May 16th 05, 05:51 PM
Chuck
Did you ever consider the pump from a "Port-a-power". Granted, it might be a
little heavy but they are quite compact.
Most of the cheap Chinese tool dealers like "Harbor Freight" have them. Just
a suggestion.
function?
Joa
Old May 16th 05, 09:53 PM
wmbjk
function?
Joa
Hopefully you can find something lighter than this - 12 pounds, $140
http://www.surpluscenter.com/item.as...name=hydraulic
Have you tried looking for used one out of an old Mooney? Quick search
found this ad
PARTING OUT 1968 M20C
Not a wreck, plenty of good parts from the firewall back, complete
tail section, fuselage, control surfaces, interior, cowling, wheels,
nose and main landing gears, fuel pump, flap pump and on and on and
on, too many individual parts to list.
Ken Shoup MAPA # 16448 GA 706-235-0555 or cell 706-857-8663
Old May 16th 05, 11:11 PM
Blueskies
wrote in message oups.com...
function?
Joa
How about some sort of brake master cylinder with a check valve along the line. Release would be a valve vented back to
tank from the flap actuator.
Old May 17th 05, 01:20 AM
LCT Paintball
line. Release would be a valve vented back to tank from the flap actuator.
Or, a faster alternative might be the pump for a hydraulic jack like they
use in some shop presses.
Old May 16th 05, 11:01 PM
Morgans
How about an electric one? Power boats sometimes have them. and they are
small and light. Search West Marine.
Jim in NC
Old May 17th 05, 10:15 PM
Blueskies
"Morgans" wrote in message ...
Jim in NC
Steering for some boats is via a hydraulic actuator in some cases....
Old May 17th 05, 11:18 PM
These are all great suggestions, thanks folks. What I'm really after
is a hand pump linear actuator since I want to use the existing flap
actuating hardware and just connect the linear actuator where the
current hand operated handle goes.
The trick here is that it really doesn't have to be that high of power,
just enough to substitute for the hand lever.
The article on the HPs was fantastic.
Joa
Cessna 172 flap skin repair Steve Owning 1 March 31st 05 01:13 AM
Stuck cowl flap cable Jim Burns Owning 7 March 24th 05 02:07 PM
Verifying flap retraction Roger Long Piloting 60 August 25th 04 11:56 AM
Flap angles DeltaDeltaDelta Piloting 34 May 18th 04 12:09 AM
757 flaps miss-aligned in cruise AnyBody43 General Aviation 1 April 2nd 04 01:01 AM
