Rings per inch for spruce?
Old May 16th 05, 01:17 AM
Esstern
Default Rings per inch for spruce?
I've been offered some spruce for spars that's pretty much perfect in every
way except there's 21 rings per inch instead of the recommended 12-15. Good
stuff or no? I don't really see the problem with finer grain spruce and in
fact, can't even remember where iread it's advisable to use 12=15 rings
per inch.
Old May 16th 05, 04:20 AM
Morgans
"Esstern" wrote in message ...
every
Good
per inch.
If you have never read this publication, and you are going to build an
airplane with a wood spar, and possibly other wood parts, take the time to
read it. You will learn things that you didn't know that you didn't know.
Every answer is in there. (really)
http://www.fpl.fs.fed.us/documnts/fp.../fplgtr113.htm
As I recall, more grains = more strength = more weight. As long as it has
the desired maximum grain divergence of 1 inch to 15 inches run, and no
pitch pockets and knots, you should be golden.
Jim in NC
Old May 16th 05, 05:10 AM
Highflyer
every
Good
per inch.
The more rings per inch the slower the growth. The slower the growth the
better. 12 to 15 rings per inch is the minimum recommended in ANC14.
Highflyer
spinner paint scheme Dick Home Built 3 January 27th 05 09:58 PM
striped spinner Pianome Home Built 1 July 4th 04 09:56 PM
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 08:11 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar General Aviation 4 March 11th 04 11:31 PM
Winch rope 1/4 inch poly Robert Curry Soaring 22 January 18th 04 01:10 AM
