I am trying to replace the brake linings on my Cherokee. I have had new
linings and brass rivets for some time now, along with a rivet tool. The problem I'm having is that the rivets aren't forming a decent head, but are simply being "squashed" more or less. They are spreading slightly, so the result is a tight fit, but I don't think that they're spreading enough to form an adequate head. The holes in the backing plates do not look oversized, and I am using a brake rivet tool, so I'm not sure of the problem. Any suggestions? Thanks, JKG |
![]() Jonathan Goodish wrote: I am trying to replace the brake linings on my Cherokee. I have had new linings and brass rivets for some time now, along with a rivet tool. The problem I'm having is that the rivets aren't forming a decent head, but are simply being "squashed" more or less. They are spreading slightly, so the result is a tight fit, but I don't think that they're spreading enough to form an adequate head. The holes in the backing plates do not look oversized, and I am using a brake rivet tool, so I'm not sure of the problem. Any suggestions? Put 'em on and use them. |
Newps wrote: The holes in the backing plates do not look oversized, and I am using a brake rivet tool, so I'm not sure of the problem. Any suggestions? Put 'em on and use them. Yes, I'm not sure whether they're supposed to be like that or not. The ones that came off of there had nice large, rounded lip heads, but who knows when they were put on or by whom, because it was long before I ever owned the aircraft. I just don't want to put them on and have them come flying off. JKG |
![]() Jonathan Goodish wrote: In article , Newps wrote: The holes in the backing plates do not look oversized, and I am using a brake rivet tool, so I'm not sure of the problem. Any suggestions? Put 'em on and use them. Yes, I'm not sure whether they're supposed to be like that or not. The ones that came off of there had nice large, rounded lip heads, but who knows when they were put on or by whom, because it was long before I ever owned the aircraft. I just don't want to put them on and have them come flying off. The heads on the rivets that I installed on my brakes are smashed like you said yours were. If the brake pads are solid then use them If they come flying off of there, which is highly unlikely, then put new ones on. I have had brake lines break on 3 or 4 occasions and shoot all the fluid out the crack. One operating brake is plenty. |
Newps wrote: The heads on the rivets that I installed on my brakes are smashed like you said yours were. If the brake pads are solid then use them If they come flying off of there, which is highly unlikely, then put new ones on. I have had brake lines break on 3 or 4 occasions and shoot all the fluid out the crack. One operating brake is plenty. I had a local mechanic finish mine up, and the rivet heads are a little better but not much--they're pretty much smashed. So that's the way they're supposed to be, I guess. JKG |
I had a local mechanic finish mine up, and the rivet heads are a little better but not much--they're pretty much smashed. So that's the way they're supposed to be, I guess. The most important things are that the pads are being held tight, and that you didn't smash the rivets so much that the pads crack. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Transient alternator problem | John Clonts | Owning | 6 | July 11th 04 06:01 PM |
Captain sim Mig-21 brake chute | Lee Hutchinson | Simulators | 7 | June 1st 04 10:51 AM |
Real World Problem in FS9 | The Real Cali Kid | Simulators | 12 | December 6th 03 11:15 AM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
Brake line design question | Charlie Smith | Home Built | 0 | July 2nd 03 12:31 PM |
