Any Apache drivers ?
Old May 17th 05, 01:58 AM
omk
Default Any Apache drivers ?
Hi all,
Back into aircraft ownership, this time I was able to go whole four
months without an airplane ! After owning couple Cessnas, I got hold of
a '56 PA-23-150 project, completely stock except for newer radios,
cleveland wheels, and the (Horton ?) tips. My friend and I are going
through a partial restoration, its been a lot of fun. Engines and props
are good, had to do the flap torque tube AD, all new tires, generator
bracket & belt, rebuild two struts, bunch of new seals, o-rings, etc,
etc.
So... just curious if there are any other Apache pilots in the NG. All
the old timers at the field stop by the hangar periodically and
reminisce about flying these machines. We really have it apart and I've
been nothing short of impressed by the workmanship and effort that must
have gone into building the thing.
I've never flown twins (ok, this is more of a two-part 300hp engine
;-), but after doing a ground runup with fistful of throttles, there is
really no going back, is there...
Martin
Old May 17th 05, 05:04 AM
Jim Burns
My partners and I all did our initial MEL in a 23-150... shopped hard for
one until we realized that we really wanted something with more payload.
Stepped up to a '66 Aztec, and even though it drinks almost twice the fuel
of it's little brother, we love it so far. As far as the workmanship and
effort, the way some of the cables and wires are routed, they went through a
lot of effort but basically it's a tube frame that they wrapped aluminum
around and said, "Hey, put a screw or ten in it, that should hold it."
Built like a brick-s*t house for guys with strong wrists or electric
screwdrivers.
Sounds like you're already up to speed on several of the AD's, other things
to watch for include
Leaky hydraulic power pac
Janitrol or Southwind heater AD's, lots of info and parts at
www.aircraftheater.com
old or dried out fuel bladders
Hartzell prop and hub AD's
50 hour AD for fuel leakage inspection
100 hour ADs for fuel valve inspection, engine mounts, exhaust cracks
Outboard flap hinge inspection
You may want to consider dual generators and electric fuel pumps or even an
electric back up hydraulic pump as long as you have everything torn a part.
Copper battery cables would also be on my list, makes starting less
strenuous on the 12v battery.
I'm sure Denny can fill you in on more.
"omk" wrote in message
Hi all,
etc.
Martin
Old May 17th 05, 05:46 AM
nobody
Like Jim, I am an Aztec owner. Mine is a '64C model. Big
brother of the Apache with the same PA23 designator. Welcome
to twin-land. The fist full of throttles is fun to fly but it looses some
of its attractivness every time I stop for fuel :-)
"Jim Burns" wrote in message
a
screwdrivers.
things
an
part.
Hi all,
etc.
Martin
Old May 17th 05, 06:53 AM
Chuck
Martin
Not an owner, but helped a local school get one up off the ground
recently. See attached picture. Story goes like this:
SETTING Student and Instructor in parked Aztec with engines running.
Instructor reading down checklist gets to "Gear down and locked".
Kid in pilot seat "Gear down and locked" at which he promptly reaches
over and pulls the gear handle UP!
Instructor hearing the warning klaxon as the gear starts going up --
reaches over and pulls the mixture on both engines. As the left one
(with the pump on it) winds down, the gear stops retracting. JUST in
time to keep the props from striking.
Turns out the safety switch (that is supposed to keep that from
happening) wasn't working and probably hadn't been checked in years.
We got it back up and pumped the gear down. Copilot side wouldn't
lock down. Turns out it bend a brace up at the top that had to be
sent to California to get straightened. But that was all the damage
(besides of course, the student's embarrassment and the school's
wallet for the repairs).
I mention it so you will be sure to check those locking cams, the
"locked-in" indicator switches, and the safeties. Enjoy her after the
refurb...
Chuck
Cherokee-180 7498W
Old May 17th 05, 01:28 PM
Ron Natalie
He's lucky it wasn't a Navion. On the Navion, the engine driven
pump will develop enough power to drop her on her nose from just
the starter spinning the engine with the handle in the UP position.
I know of only one Navion with a squat switch, the plane wasn't
designed with one.
Old May 18th 05, 04:29 AM
Scott Skylane
designed with one.
That's interesting, Ron. Do you know what, exactly, the switch did(i.e
operate a solenoid that blocked the gear handle, or somesuch)?
Happy Flying!
Scott Skylane
N92054
Old May 18th 05, 01:19 PM
Ron Natalie
Scott Skylane wrote:
designed with one.
Exactly, there's actually a secondary gear lock (this was either an SB
or AD, probably an AD I've never seen a Navion that doesn't have it).
Normally the only thing that keeps you from raising the gear is that you
have to pull out the handle over a detent. The seconary lock is a
small lever that hooks over the handle (behind the panel). I believe
Don added a solenoid that makes it impossible to release the secondary
lock on the ground.
Frankly, the inadvertant retracts that I know about have all been after
maintenance.
Old May 17th 05, 06:27 PM
omk
Good story !
I don't think there is a "switch", just a valve on the left gear that
causes the fluid to bypass the actuators when the strut is compressed.
I didn't know about this and spent a good hour "troubleshooting" the
gear when the airplane was jacked up, wheels off (no weight to extend
the deflated strut). Anyway, at least I know it *is* working ! :-)
Martin
Chuck
Martin
Woops,
Forgot to attach the picture.
Chuck
Old May 17th 05, 04:28 PM
xyzzy
Chuck wrote:
Martin
Woops,
Chuck
Most of us won't be able to see it. Most news servers strip pictures.
Suggest you put it on a website (like a free geocities site) and provide
a link.
Apache helicopter brought down Richard Military Aviation 0 April 11th 04 11:20 AM
Apache crews sharpen gunfighting skills Otis Willie Military Aviation 0 January 12th 04 12:45 AM
UK pilots start Apache training Otis Willie Military Aviation 0 September 13th 03 11:37 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
Early Bonanza or Apache? Brinks Owning 11 July 16th 03 07:01 PM
