Drag of Transponder Antennae compared
Old February 9th 21, 04:06 AM posted to rec.aviation.soaring
AS
Default Drag of Transponder Antennae compared
Interesting home-brewed investigation into the drag between the fin-type and rod-type transponder antenna by one of our friends in The Netherlands.
Seems like the fin type antenna - unless mounted exactly on the centerline of the glider, where the flow is expected to be parallel - may produce a lot of turbulence and drag.
https://www.youtube.com/watch?v=8ii_...ature=emb_logo
Take a look at this type of antennae installed under the belly of power planes. In most cases, you will find one side (typically the right side due to the prop-wash)) caked with soot and grime while the other side is relatively clean. Would be interesting to quantify the drag this causes and the extra fuel burn over the lifetime of the plane. I bet most power-pilots don't even know/think about it.
Uli
'AS'
Old February 10th 21, 02:14 AM posted to rec.aviation.soaring
India November[_2_]
Uli
'AS'
Yes, theoretically the streamlined aerofoil section has a lower drag coefficient than a cylinder oriented at right angles to the airflow. However, the rod antenna has a smaller frontal area, and also if the aerofoil is misaligned with the local airflow it will disturb the flow and cause drag.
Old February 10th 21, 04:51 AM posted to rec.aviation.soaring
AS
Interesting home-brewed investigation into the drag between the fin-type and rod-type transponder antenna by one of our friends in The Netherlands..
Uli
'AS'
Ok - here is a follow-up question/challenge: The aerodynamic resistance of a cylinder vs. a tear-drop shape is about 10:1. How about a 3D-printed airfoil shape like a simple symmetric NACA airfoil made in two pieces, which snaps over the pole antenna? It could be retained/secured by the ball on the end but be free to swivel thus self-align with the airflow.
Gentlemen - Warm up your printers ... ;-)
Uli
'AS'
Old February 10th 21, 12:30 PM posted to rec.aviation.soaring
andy l
Uli
'AS'
Uli
'AS'
One or two people with aerodynamics knowledge have said before that a delta is one of the highest drag shapes there is, if the airflow is not perfectly in line, and thus they personally won't have those fence fairings at aileron ends or flap end by wing root. Some blade transponder aerials look quite like a delta shape
How does the size and drag of a rod type transponder aerial compare with the short near verticle part of a total energy tube, and how often have people worried about that?
Simpler than the 3d printing would be take a short piece of curved mylar of suitable width, wrap it around and tape the edges together with capping tape. It might need a brief wave of a heat gun to enhance the curvature at the front (which is how it's curved in the first place).. It might take 3 or 4 tries or might not work. Don't do this for the TE tube.
Is there a prize for the first person to glue a nice mini Kamm-tailed fairing on the back of the ball, which doesn't fall off in the next few months? Am I joking?
Old February 10th 21, 01:25 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
andy l wrote on 2/10/2021 4:30 AM:
Uli
'AS'
Uli
'AS'
Remove the TE portion of the probe, and use electronic TE for the vario. Put the transponder
antenna in the fin. I've done the first part; not going to do the second part until I get a new
glider :^)
But what to do with the tip wheels? Got to be worse than a blade antenna. Take one off and taxi
only on the left wing? And that scoop on the sliding canopy window - better glue that shut
before I even think about using it again! Yikes - the yaw string - better mount it waaay back
on the canopy, behind your head, so it doesn't trip the laminar flow too early (or mount it
inside, towards the front, where I can still see it).
$200,000 for a new glider, and the manufacturer doesn't do any of these things! They must think
we are rich and bereft of technical knowledge. Also, why isn't there MK VII Laminar Flow Yaw
String I can buy? Did bumper retire?
Old February 10th 21, 03:44 PM posted to rec.aviation.soaring
Dan Marotta
....And you'd tell the drag difference how? Would that be 10 oz vs 1 oz?
What's the overall drag of the glider at cruise? BTW, my Stemme has a
rod antenna for the transponder and a blade for the Flarm B.
Dan
5J
Uli
'AS'
Uli
'AS'
Old February 10th 21, 04:22 PM posted to rec.aviation.soaring
jfitch
Just fly faster. On cylinders and spheres, the drag drops to about 1/3 above the critical Re. Around 220 knots should do it for the transponder rod.
Dan
5J
Uli
'AS'
Uli
'AS'
Old February 10th 21, 04:43 PM posted to rec.aviation.soaring
Just keep it out of the airflow ... here’s a mocked up solution with dual diversity antennae ...
https://www.google.ca/url?sa=i&url=h...AAAAAdAAAAABAD
Old February 10th 21, 01:34 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
AS wrote on 2/8/2021 8:06 PM:
Excellent video.
Old February 10th 21, 02:24 PM posted to rec.aviation.soaring
Mark Mocho
To really make a difference in parasitic drag, learn how to use your rudder pedals. One little boot that misaligns your yaw string is probably equivalent to two or three years worth of drag from your transponder antenna!
Antennae John McCullagh[_2_] Soaring 34 July 23rd 19 08:50 PM
VOR Antennae Installation guynoir Home Built 1 November 8th 06 03:37 AM
Which antennae please? Robert Loer Home Built 1 October 27th 04 11:55 PM
Drag - Anti/Drag Wires log Home Built 3 August 28th 03 07:06 AM
Drag of LS3 compared LS3a. Peter Warburton Soaring 0 August 18th 03 06:59 AM
