So, I am well aware of the drag chutes supplied by Walter Kostelezky, K.G. of Germany. I am aware of the rings and swivels at the connection to the aircraft, and that the aircraft end is a release somewhat resembling a Tost style release. But, I have a plane that has a different sort of interface with the airplane.
On the plane I have, the release is at the front end of a tube that is about 10 mm in inside diameter. It was just large enough for me to put my borescope camera inside. At the front of this hole, about 4-5 inches forward, is something that sticks in from one side, and goes maybe 1/3rd of the way across the diameter of the hole. I was not able to verify operation by pulling on the jettison handle, as I was the only one at the airport on that cold day. Near as I can tell, it looks like this particular jettison mechanism would interface with something that looks like the end of a microphone plug. I am guessing this would be roughly 9 mm OD, tapered end, then a near 90 degree cut in or maybe even a o-ring style groove that the visible retaining feature would drop into to lock and hold the chute to the airframe until the jettison lever is pulled. My best guess is that there is a 5 inch or so long steel ferrel that is swaged onto the rope that goes back to the chute. This tube exits the fuselage aft of the tailwheel and below the bottom of the rudder. From what I can tell, the rope went outside the airframe from attach point into the cover that is on the bottom of the rudder. Any of you seen anything like that? The plane was built between 1962 and 1967 in Switzerland. Thanks in advance for any assistance! Steve Leonard HB-723 soon to be N723HB |
On Sunday, February 14, 2021 at 4:18:45 PM UTC-6, Steve Leonard wrote:
So, I am well aware of the drag chutes supplied by Walter Kostelezky, K.G.. of Germany. I am aware of the rings and swivels at the connection to the aircraft, and that the aircraft end is a release somewhat resembling a Tost style release. But, I have a plane that has a different sort of interface with the airplane. On the plane I have, the release is at the front end of a tube that is about 10 mm in inside diameter. It was just large enough for me to put my borescope camera inside. At the front of this hole, about 4-5 inches forward, is something that sticks in from one side, and goes maybe 1/3rd of the way across the diameter of the hole. I was not able to verify operation by pulling on the jettison handle, as I was the only one at the airport on that cold day. Near as I can tell, it looks like this particular jettison mechanism would interface with something that looks like the end of a microphone plug. I am guessing this would be roughly 9 mm OD, tapered end, then a near 90 degree cut in or maybe even a o-ring style groove that the visible retaining feature would drop into to lock and hold the chute to the airframe until the jettison lever is pulled. My best guess is that there is a 5 inch or so long steel ferrel that is swaged onto the rope that goes back to the chute. This tube exits the fuselage aft of the tailwheel and below the bottom of the rudder. From what I can tell, the rope went outside the airframe from attach point into the cover that is on the bottom of the rudder. Any of you seen anything like that? The plane was built between 1962 and 1967 in Switzerland. Thanks in advance for any assistance! Steve Leonard HB-723 soon to be N723HB Steve, No answers...just questions. - What aircraft is this for? The "HB-723 soon to be N723HB"? HB-723 doesn't Google. - Can I assume (!) that this is a drag/drogue chute for landing in lieu of airbrakes? Can I then further assume that the 10mm tube and the rope (cable?) inside that you speak of triggers the release of a cover of where the chute is packed into? - Do you have pictures taken with your borescope? Other pics? - I see Walter Kostelezky's company's web site but not much info. http://www.kostelezky.de/ Any other information you can share? - There are some pictures found when I Googled "Walter Kostelezky parachute" which look drag/drogue like. https://www.google.com/search?sxsrf=...w=1481&bih=836 Expiring minds want to know. Best of luck, John |
Would that be an Elfe? I filmed one back in 1978 in Switzerland, landing with a drag chute after an aerobatic display. You can see it he https://vimeo.com/160379590 (bad quality, I know, copied from Super 8 movie). The chute seems not to open fully.
At about 4 min 10...
Thank you for the link, Stéphane. I wonder how many Elfe's got the shark mouth painted on the nose? I have a "trading card" with an Elfe with the shark mouth on it.
John, the plane is question is an Akaflieg Braunschweig SB-7. There are two handles in the cockpit for operating the chute. There is the deploy, which drops the chute cover (bottom of the rudder) with the chute. The chute is probably a 1.3 meter diameter, ribbon type chute. There is a second handle, on the opposite side of the cockpit, which allows you to jettison the chute if it is making too much drag and you will come up short if you don't do something. The particular SB-7 also has trailing edge dive brakes like what Irv Prue used on the Prue Standard. They are also like what is used on the Elfe. Hinged on the upper surface at roughly 90% chord, the lower surface leading edge is at about 80% chord. So, sort of like an inverted SH trailing edge air brake. But it doesn't go from wing root to aileron, but is only about 6 feet long. I am hoping to get information on the type of fitting that was on the end of the rope or lines that connect the chute to the airframe. I need to make a new cover/lower rudder, as the original appears to have been lost somewhere in the 30+ years since it last flew. Unfortunately, so has the drag chute. Would be nice to know how to make something so I could have the drag chute available. Steve Leonard |
You might want to contact the Akaflieg Braunschweig. I think the original SB7 is still flown by a group of former members.
I don't remember it to have trailing edge brakes though, but I've flown it only once, and that was30+ years ago. Le mercredi 17 février 2021 Ã* 07:20:41 UTC+1, Steve Leonard a écritÂ*: Thank you for the link, Stéphane. I wonder how many Elfe's got the shark mouth painted on the nose? I have a "trading card" with an Elfe with the shark mouth on it. John, the plane is question is an Akaflieg Braunschweig SB-7. There are two handles in the cockpit for operating the chute. There is the deploy, which drops the chute cover (bottom of the rudder) with the chute. The chute is probably a 1.3 meter diameter, ribbon type chute. There is a second handle, on the opposite side of the cockpit, which allows you to jettison the chute if it is making too much drag and you will come up short if you don't do something. The particular SB-7 also has trailing edge dive brakes like what Irv Prue used on the Prue Standard. They are also like what is used on the Elfe. Hinged on the upper surface at roughly 90% chord, the lower surface leading edge is at about 80% chord. So, sort of like an inverted SH trailing edge air brake. But it doesn't go from wing root to aileron, but is only about 6 feet long. I am hoping to get information on the type of fitting that was on the end of the rope or lines that connect the chute to the airframe. I need to make a new cover/lower rudder, as the original appears to have been lost somewhere in the 30+ years since it last flew. Unfortunately, so has the drag chute. Would be nice to know how to make something so I could have the drag chute available. Steve Leonard |
On 2/17/2021 1:20 AM, Steve Leonard wrote:
...so I could have the drag chute available. Oh Steve, don't be a wimp... |
I need a chute...anyone got one for sale? | [email protected] | Soaring | 4 | March 16th 09 01:45 AM |
Chute | Maple1 | Aviation Photos | 0 | August 3rd 07 04:50 AM |
emergency chute | Sven Olivier | Soaring | 49 | April 11th 05 03:41 PM |
BRS chute | Rich S. | Home Built | 6 | May 30th 04 05:21 AM |
Chute for sale | dmayer | Soaring | 0 | February 5th 04 07:37 PM |
