Running XCSOAR on an ereader
Old February 24th 21, 07:23 PM posted to rec.aviation.soaring
john firth
Default Running XCSOAR on an ereader
I would like advice on tablets such as KOBO mini which will
run XCSOAR; my Kobo Usb port has died.
stay safe.
John Firth
Old February 24th 21, 08:10 PM posted to rec.aviation.soaring
Moshe Braner
stay safe.
John Firth
I use Tophat on both Nooks and a Kobo. My experience is that the micro
USB connector breaks very easily. So I try to avoid using it. Moreover
GPS input via USB was flaky on the Nook, sometimes froze up in mid
flight and I had to reboot it (not a big deal). So I hard-wired a GPS
module (in one Nook) or an RS232 adapter (in another Nook) to the serial
port that is hidden inside, that has worked great. While at it, I added
a (non-micro) USB cable to one Nook for external power.
For more details see the Tophat forum, or send me personal email.
(Tophat is based on XCsoar, and these hardware issues are the same for
both.)
Old February 24th 21, 09:31 PM posted to rec.aviation.soaring
Dave Nadler
... my Kobo Usb port has died.
You can usually find Kobo on eBay for around $50.
Well OK $750 Canadien...
I use the Kobo Glo (not Glo HD) with TopHat.
Old February 24th 21, 10:45 PM posted to rec.aviation.soaring
Tom BravoMike
stay safe.
John Firth
I've got this color e-ink reader:
http://www.onyxbooxusa.com/products/...ox-poke-color/
Checked it out (XCSoar) with an external GPS source (WiFi and BT connection available) and it works fine on the ground; still need to check it in the air. No speaker, but can attach one using either BT or USB-C OTG adapter (checked positive).
Old February 24th 21, 11:13 PM posted to rec.aviation.soaring
Moshe Braner
stay safe.
John Firth
Interesting. Seems like a recent model. Did you have to hack control
away from the e-reading software, or does this model allow installing
other Android apps (such as XCsoar) in addition to the e-reading
software it comes with?
Old February 24th 21, 11:59 PM posted to rec.aviation.soaring
Tom BravoMike
stay safe.
John Firth
It's a regular Android 9.0 OS, it has the Google Play Store. No issue and no hacking needed to install the XSSoar and other Android apps so far.
Old February 25th 21, 01:55 PM posted to rec.aviation.soaring
Muttley
stay safe.
John Firth
There is also a 7,8 inch version due out next month
Old February 25th 21, 02:00 PM posted to rec.aviation.soaring
Muttley
stay safe.
John Firth
my previous e-mail forgot to add https://tinyurl.com/h1dek3nr
Oudie 2 Lite Running XCSoar, any fix yet? Blake Seese 3Y Soaring 0 June 1st 15 02:04 AM
Anybody running a Butterfly Vario with XCSoar? jfitch Soaring 26 July 18th 13 04:41 PM
XCSoar and Top Hat issues running on Samsung Galaxy Tab 3 Gary Adams Soaring 4 July 11th 13 02:55 PM
I am up and running again Danny Deger Piloting 2 June 27th 07 05:20 PM
Running an 0-235 well beyond TBO Paul Folbrecht Owning 8 March 14th 04 12:30 AM
