(RST Engineering, Please read!) "The Muse"
Old May 23rd 05, 12:28 PM
H.P.
Default (RST Engineering, Please read!) "The Muse"
In other words, the volume of the music audio has to
be fairly high, or the Muse will cut out during softer parts of a song.
The audio output device needs a compression circuit to keep audio levels
more near a constant output. There are portable cd players out there that
have such a feature.
Another issue is that my unit only seems to pass one of the stereo
channels through to the headset. I hear the music in both ears, but it's
only the left or right (not sure which) channel.
Your headset may have a dip switch that's factory set to mono-out a stereo
input - like the Bose headset. Try the other setting. Or it may be wired in
mono. Try it on a stereo source at home.
Old May 23rd 05, 05:47 PM
RST Engineering
Why renamed to me?
Old May 23rd 05, 05:57 PM
Jim Fisher
"RST Engineering" wrote in message
Why renamed to me?
We need you to fix that, Jim. When you're done, will ya do something about
that Iraq situation and Global Warming?
Thanks,
Jim Fisher
Old May 23rd 05, 07:25 PM
Javier Henderson
"Jim Fisher" writes:
Why renamed to me?
I'd rather he'd work on important stuff. Like, no alcohol on mogas
in California so we can use the stuff in our Skylanes.
-jabv
Old May 23rd 05, 08:34 PM
Why renamed to me?
Hey! Run Jim for Gov!
Best regards,
Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jer'at'frii.com WEB http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 227 Young Eagles!
Old May 23rd 05, 08:57 PM
Scott Skylane
RST Engineering wrote:
Why renamed to me?
O.K., I guess I'll get out the 2X4, and start smacking.
Jim, would you consider adding to your product line a device that feeds
music into an individual aviation headset. I would bet you could design
a pretty stout, useable device that would be superior in quality to, and
more reasonably priced than, the PSE Muse. I, for one, would be
interested in buying such a device.
Happy Flying!
Scott Skylane
Old May 24th 05, 12:04 AM
RST Engineering
Without me doing a lot of research that most of you seem to have done, what
is the input, what is the output, and what is the function? And no, I won't
do stereo. There are good reasons.
"Scott Skylane" wrote in message
Why renamed to me?
Old May 24th 05, 04:07 PM
Jose
And no, I won't
I'd be curious to know what they are.
Jose
The price of freedom is... well... freedom.
Old May 24th 05, 09:05 PM
RST Engineering
And no, I won't do stereo. There are good reasons.
Stereo In The Aircraft
RST does not produce any stereo intercoms, audio panels, headsets, or other
devices that
reproduce stereo music. If you are absolutely determined to have stereo in
your aircraft, you
might just as well stop reading now, because anything we have to say isn't
going to change your
mind.
We made a conscious business and engineering decision not to produce any
product for stereo.
There are good aviation and engineering reasons for this.
First, a little background music or listening to the ballgame in a cockpit
environment isn't all
that bad. Sometimes flying is miles and miles of nothing but miles and
miles. On the other
hand, I know from my own love of music that when there is a particularly
good cut playing on my
home stereo and I have the headphones on (try "Sweet Sir Galahad" by Baez or
"Minstrel Of The
Dawn" by Lightfoot at somewhere slightly below the threshold of pain in the
'phones to see what I
mean) that I get totally lost within the music and the world just sort of
blurs away. Just
about the LAST thing I want in an airplane is a pilot that has zoned out on
music and is just
holding the controls to have something to do with their hands. That's item
#1.
Second, stereo is expensive. Yes, I understand that FLYING is expensive,
too, but to go to the
expense of specially-designed headphones, intercoms, audio panels, and all
the rest of it seems
to us to be on the other side of reasonable. Our company thrust has, and
always will be, to make
flying affordable for everybody. That's point #2.
Now to the engineering stuff. Suppose you try and take your stereo headset
and fly in somebody
else's airplane that is "regular airplane". Will your stereo headset work
without the trick
little switch on the cable to convert it to a monophonic headset? No, you
will hear one ear of
the conversation only. And what did that little switch do? It put both
earphones in parallel,
which cut the impedance of the headset in half. Properly designed, this
MIGHT not be noticeable
to the aircraft radio, or it might. Since airplane radios weren't designed
to figure out whether
or not you were messing around with a stereo headset, the manufacturer
didn't worry about making
sure his radio would drive that low of an impedance.
Even worse, if somebody else takes his standard aircraft headset and puts it
into your stereo
airplane jack, it will short out one of the channels. Depending on the
design of the intercom,
the best you can hope for is that one stereo channel will be dead in
everybody's headphones.
Second worst is that the short on that channel will blow out the amplifier
for that channel. In
a really lousy design, that short will cause the whole intercom/audio panel
to fail, leaving you
without any headphone audio at all.
Given all these reasons, RST has decided not to produce any stereo
equipment. While it probably
won't sway your decision for stereo in your airplane, we thought you should
at least consider
these problems.
FS Aeronautical engineering textbooks for sale john hawkins Home Built 0 March 26th 05 09:53 PM
FS Aeronautical engineering textbooks for sale john hawkins General Aviation 0 March 26th 05 09:53 PM
Navy enlistment questions Atcrossroad Naval Aviation 53 September 23rd 04 10:43 AM
PS Engineering Report Jeff Owning 44 December 7th 03 11:24 PM
PS Engineering Hankal Owning 0 December 5th 03 12:25 AM
