All,
I'm in the process of rebuilding a Standard Libelle instrument panel. I would like to use my CNC router to cut the holes but to do that I need accurate data to put in the CAD program. If anyone has either an accurate digital file (DXF or SVG) that would be marvelous! Other files type can probable be used as well. Failing that if there is a good dimensioned drawing I can enter the data that way. Does anyone have something like that they can share with me? Mike Bamberg The cirrus.cfi (at) gmail (remove the . before cfi, you know the rest) |
On Monday, March 8, 2021 at 10:17:32 PM UTC-6, wrote:
All, I'm in the process of rebuilding a Standard Libelle instrument panel. I would like to use my CNC router to cut the holes but to do that I need accurate data to put in the CAD program. If anyone has either an accurate digital file (DXF or SVG) that would be marvelous! Other files type can probable be used as well. Failing that if there is a good dimensioned drawing I can enter the data that way. Does anyone have something like that they can share with me? Mike Bamberg The cirrus.cfi (at) gmail (remove the . before cfi, you know the rest) Email with details sent. Robert |
All,
I've received several sets of drawings, No more needed. Thanks to all who contacted me and shared their drawing files. Mike |
Hello, I am also in the process of redoing a Libelle panel and would like a copy of the drawings if still available.
Email: Happy Landings, Scott |
Wanted: Standard Libelle parts | JS | Soaring | 0 | February 23rd 11 06:01 PM |
Interesting Standard Libelle | Steve Leonard | Soaring | 1 | April 22nd 06 10:17 PM |
Interesting Standard Libelle | [email protected] | Soaring | 3 | April 22nd 06 03:33 AM |
Interesting Standard Libelle | Peter Thomas | Soaring | 0 | April 21st 06 11:00 PM |
Standard Libelle | Pam Kurstjens | Soaring | 4 | May 22nd 05 05:40 PM |
