solo x/c for commercial
Old May 25th 05, 07:09 AM
Default solo x/c for commercial
Okay, I've decided to start on my commercial, and after looking at
61.129 I have painfully accepted the fact that the 300nm cross country
really needs to be vfr, solo. That means long trips I've done on
instrument flight plans (imc or vmc) won't cut it, and more painfully,
long trips I've done with my girlfriend and climbing buddies (non pilot
passengers) are also not acceptable.
I really have to fly somewhere 250nm away and back again, being sure to
stop somewhere on the way home.
It is so tempting to go into a rant about the pointlessness of this reg
as written, but I'm going to limit myself to just stating that,
generally, I prefer to fly with friends, because it's just more fun (in
the plane and at the destination) and, well, more cost-effective. And
my logbook shows this dearth of truly solo post-private time. I
sometimes go up just to tool around and practice maneuvers on my own,
but I just haven't done much x/c flying that way.
No matter.
I want to make this trip as interesting and educational as possible.
I'm looking for ideas to spice up a several hours in cruise. Games to
practice my dead reckoning?
What do you guys do to make sure every flight is a learning experience?
(aside from "I learned about flying from that" stories, which I'd
prefer to read about rather than re-enact.)
Ideas?
-- dave j
-- jacobowitz73 --at-- yahoo --dot-- com
Old May 25th 05, 09:46 AM
Peter Duniho
Personally, I don't go out of my way to "make sure every flight is a
learning experience". Many flights are, of course. But every flight should
be planned with the goal of the flight taking place exactly as planned,
without any surprises. And then you should actually fly the flight as if
nothing will go according to plan, so that you are always ready to fix the
plan to accomodate the new situation.
Now, that said, you have a very specific flight in mind, and I think it's
reasonable to look for ways to make it more interesting. I don't think it's
rocket science though. You can probably come up with most, if not all, of
the various ways yourself.
Some strategies that might be helpful:
* Make one of your landings at an airport that appears to be especially
hard to find. Of course, they all look easy on the chart, but a short
runway (not shorter than you can safely manage, of course) is often more
difficult, as are airports without lots of services or based aircraft
(airports are harder to find if there aren't a bunch of airplanes sitting
around on the ground ).
* Route your flight through various kinds of airspace requiring contact
with ATC. Use VFR flight following. Use a VFR flight plan.
* Challenge yourself to use the available weather information to verify
and/or correct the winds aloft forecast. For extra credit, use this
information along with your suggestion of doing some dead reckoning. See
how close to the mark you get.
* Practice your pilotage. Dead reckoning is fine, but for VFR flight
pilotage is where it's at. It's something you can use on every single
flight if you want to, and it is lots of fun.
* Actually get out at one of your stops. Try to get a meal. Fill up
the airplane's gas tanks. You may have already done this many times, but
personally I have found that the elements of flight between takeoff and
landing tend to be very similar. It's when you get to your destination that
every trip is different. For extra credit, see how close to your actual
fuel burn you can get with your calculations.
* Find a place to land that's unusual, even beyond being hard to find.
Here in the Pacific Northwest, Copalis Beach (a "runway" on the sand) is a
new experience for many. Near Los Angeles, landing on Catalina Island can
be a fun, but reasonably safe challenge (though, I haven't heard a report on
the pavement conditions in awhile). I don't know where your flight is
likely to take you, but surely there's an airport or two around that is
particularly unusual, even beyond some specific dimensional characteristic.
Most of all, just have fun. Frankly, while I can definitely relate to the
"having friends along is more fun", I think you're missing out if you don't
do a good long flight solo once in awhile. For me, it's about as far as I
can get from the real world. I have the whole plane to myself. No one is
expecting me to chat with them. The headsets keep the airplane noise down,
and otherwise my experience is completely silent. Obviously this works
better if you don't have to talk to ATC, but I've found that especially for
VFR flights, the occasional need to talk on the radio doesn't negate the
great "wakeful meditation" that solo flight provides.
Beyond any suggestion for making the flight more challenging or interesting,
simply take advantage of this rare opportunity to experience flight in a
completely new way. A way that you are not accustomed to experiencing,
since you always work so hard to bring someone else along. It's not bad.
It's just different.
Pete
Old May 25th 05, 10:17 AM
Ray
Are you sure it has to be VFR? Assuming you have 61.129(a)(2)(iii), the PIC
100nm VFR XC covered, 61.129(a)(4)(i), the 300nm solo XC doesn't seem to say
anything about VFR.
I agree though, that the definition of solo for the purposes of this
requirement should be broadened to include flights with non-pilot
passengers.
- Ray
Old May 26th 05, 02:17 AM
buttman
meh, I disagree. If you're going for a commercial certificate, you are
going to have to learn how to do stuff alone. All the guys I know who
went off to work for cargo carriers do most of their flying alone. Even
a non-pilot can help a lot. Anyways, its just one flight.
When I did my long cross country for the commercial, I went to
Baltimore. This of course was just over a week or two ago. It was
actually the sunday before the ADIZ incident. most of the flight was
over the emptyness of West Virginia, and let me tell you it was very
boring, but I must get used to it if I plan on doing this
professionally.
Old May 25th 05, 01:05 PM
kontiki
Pick a place you've never been before and just enjoy the ride.
Every flight can be a learning experience if you want it to be.
Old May 26th 05, 07:07 PM
Andrew Gideon
That's what I planned. I planned to visit Maine; a place I've never been.
However, I went a little further. The *flight* has to be solo, but not the
visit. I found a couple of pilots that were interested in making the same
trip. So at least there'd be friends with which to eat.
Unfortunately, my wife's pregnancy shifted gears a bit so I'm staying in the
neighborhood. But I'm going to try the same plan when I can finally fly
again.
- Andrew
P.S. How did you decide that it needed to be VFR?
Old June 11th 05, 05:06 PM
Scott Draper
Is this something like the PPL where you have to get an instructor
to sign off on it to prove it was done within 61.127(b)(1)
There is no such requirement for the PPL or CPL.
Old June 11th 05, 05:52 PM
Peter Clark
On Sat, 11 Jun 2005 16:06:41 GMT, Scott Draper
So a student pilot can launch off on a solo XC without an instructor
endorsement? Or are you quibbling on "prove it was done within 61.x",
meeting the standards of which are implied by the instructor endorsing
the flight in the case of the PPL.
Old May 25th 05, 01:17 PM
OtisWinslow
Do you write in your log book when you have passengers? When I did mine
(admittedly a
lonnnng time ago) I took a couple friends and we made a day of it. I believe
it was 250nm
legs back then .. 3 of them. Stopped at both places and did stuff. The
flight school was
aware that 2 people were going with me and never said a thing. Did the
requirements
change since the 70s?
No matter.
Ideas?
-- dave j
Frst Solo, Non-stop Round the World Airplane Flight Larry Dighera Piloting 7 March 4th 05 03:51 PM
1.4 solo.. Beav Rotorcraft 0 November 5th 04 12:27 AM
SOLO flight rules Gig Giacona Rotorcraft 60 January 25th 04 06:36 PM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
