I am just starting to use CU to create DA4 files to load into my LX7000
Pro. If you look at the CU waypoint detail screen, some of the columns a Name = Long Name Style = 'airport', 'waypoint', etc. Code = Short Name Description = 'Airport' or blank Which of these does the LX use to display AP/TP names ... I assume short name (i.e. code). How does it determine something is an airport vs a way/turnpoint ... does it use style ... and are the terms 'airport' and 'waypoint' the values the LX uses to identify record type. If something is an AP, I assume it shows up in the airport list ... and can all AP and TP records can be used to create a task on the LX. Thx, KK |
Ken Kochanski (KK) wrote: I am just starting to use CU to create DA4 files to load into my LX7000 Pro. If you look at the CU waypoint detail screen, some of the columns a Name = Long Name Style = 'airport', 'waypoint', etc. Code = Short Name Description = 'Airport' or blank Which of these does the LX use to display AP/TP names ... I assume short name (i.e. code). How does it determine something is an airport vs a way/turnpoint ... does it use style ... and are the terms 'airport' and 'waypoint' the values the LX uses to identify record type. If something is an AP, I assume it shows up in the airport list ... and can all AP and TP records can be used to create a task on the LX. Thx, KK Hi, In a task everything is a turnpoint, airport or waypoint. But airport have to be in the waypoint file wich is easy to do. S6 |
| Thread Tools | |
| Display Modes | |
| Recording and Deleting Tasks and Turnpoints in the Volkslogger | Nyal Williams | Soaring | 3 | May 18th 05 10:42 PM |
| SeeYou MOBILE v2.0! | Roy McMaster | Soaring | 10 | July 12th 04 01:25 AM |
| Distance Task Opinions? | Kilo Charlie | Soaring | 14 | September 6th 03 05:23 AM |
| FS - Collection of Aircraft Information Files | Matt | Aviation Marketplace | 0 | July 21st 03 01:03 AM |
| FS - Collection of Aircraft Information Files | Matt | Aviation Marketplace | 0 | July 21st 03 12:59 AM |
