Peter wrote: I've been told that if one's GPS is an IFR approved unit (KLN94B in my case) and it's not placarded "VFR only" then I am required to have the latest database, otherwise I am not complying with the minimum equipment list (in ANY flight) - is this correct? I would think that if a database update was required and the unit displayed an appropriate message wrt the database validity, then that would satisfy any placard requirement. Does your aircraft have an MEL? If so, what would this mean for the validity of insurance? You'd have to find out from your insurance company. -- Bob Noel no one likes an educated mule |
During my instrument training I was told that if you have an IFR
certified GPS, it had to be updated if you were using it for IFR Flight. You can use it VFR even if it hasn't been updated Charlie Peter wrote: I've been told that if one's GPS is an IFR approved unit (KLN94B in my case) and it's not placarded "VFR only" then I am required to have the latest database, otherwise I am not complying with the minimum equipment list (in ANY flight) - is this correct? If so, what would this mean for the validity of insurance? Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. |
In rec.aviation.misc Charlie Derk wrote:
: During my instrument training I was told that if you have an IFR : certified GPS, it had to be updated if you were using it for IFR Flight. : You can use it VFR even if it hasn't been updated : Charlie As I've heard it, you can technically fly IFR with an expired database, so long as you have verified that the data for every piece of information in the database that you will use is correct. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Exactly... Using it for an IFR GPS is all about the POH supplement.
Garmin requires updates. UPSAT did not - just required that you verify that the approach hasn't changed. None of this prevents you from using the GPS, of course, for enroute VFR use. Now some years ago there was a controversy started by Flying magazine because of the speculation that an over zealous FAA inspector might view an out of date database as a violation. But the FAA clarified that this was not the case. Same deal as with outdated charts in the plane. Perfectly okay... But you MUST have the current information you need to complete the flight safely. That same outdated chart (or database) won't get you out of jail if you violate some airspace (or worse, violate the terrain). |
On Fri, 10 Jun 2005 04:33:58 GMT, Chuck wrote:
On Tue, 31 May 2005 12:24:32 +0000 (UTC), wrote: In rec.aviation.misc Charlie Derk wrote: : During my instrument training I was told that if you have an IFR : certified GPS, it had to be updated if you were using it for IFR Flight. : You can use it VFR even if it hasn't been updated : Charlie As I've heard it, you can technically fly IFR with an expired database, so long as you have verified that the data for every piece of information in the database that you will use is correct. -Cory I've heard that recently myself. You can use an expired database GPS for all the VFR you want. But to use it for IFR, you first have to confirm the database information for any approach you'll use hasn't changed. Or you have to manually chage it in the database if it has changed. Unless precluded by the flight manual supplement or, if incorporated by reference like "Must be operated in accordance with the owners manual" in the supplement, the users guide. The KLN89B and KLN94 are apparently two such units - their supplement introduction states "NOTE: A current database is required by regulation in order to use the (blah) GPS system for non-precision approaches". The KLN94 limitations page states "Instrument approaches must be accomplished in accordance with approved instrument approach procedures that are retrieved from the KLN 94 database. The KLN 94 aeronautical database must incorporate the current update cycle." The 89B's limitations page is similar, except they also have a minimum software revision limitation. Doesn't look to have any discretion to verify and go with expired databases with these boxes at least. |
Peter Clark wrote:
The KLN89B and KLN94 are apparently two such units - their supplement introduction states "NOTE: A current database is required by regulation in order to use the (blah) GPS system for non-precision approaches". Minus the words "by regulation," my Garmin GNS430 GPS also has such as restriction in the POH supplement. I recall reading here that at least one other GNS430 owner did not have such a restriction in his supplement. One possible explanation may be that my unit, as purchased by the previous owner of the aircraft, was one of the first GNS430s available. Perhaps Garmin and/or the FAA loosened that restriction as time went on. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Chuck wrote:
You can use an expired database GPS for all the VFR you want. But to use it for IFR, you first have to confirm the database information for any approach you'll use hasn't changed. Or you have to manually chage it in the database if it has changed. I don't have a reference on that, ... snip The applicable document is the Supplemental POH. The Supplemental POH is approved on an installation by installation basis, so there is technically no general answer, except RTFM for your airplane. In practice, the GPS manufacturer provides a boilerplate SPOH, so that's what gets sent into OK City for approval. Dave |
On Tue, 31 May 2005 12:24:32 +0000 (UTC), wrote: In rec.aviation.misc Charlie Derk wrote: : During my instrument training I was told that if you have an IFR : certified GPS, it had to be updated if you were using it for IFR Flight. : You can use it VFR even if it hasn't been updated : Charlie As I've heard it, you can technically fly IFR with an expired database, so long as you have verified that the data for every piece of information in the database that you will use is correct. All you need is a set of paper charts that are up-to-date, unless otherwise stated in either the manual or POH. This was covered in one of the flying mags this past month. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com -Cory I've heard that recently myself. You can use an expired database GPS for all the VFR you want. But to use it for IFR, you first have to confirm the database information for any approach you'll use hasn't changed. Or you have to manually chage it in the database if it has changed. I don't have a reference on that, but the subject came up in a group of instructors and a couple of FAA inspectors. In any case, I know the FAA is allowing a local FBO to rent out and train in a plane with a LONG expired database. This Garmin 430 was definitely installed complaint with TSO C129, but the owner was too cheap to keep up the database updates. Chuck |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Approved Drug List | Carl J. Hixon | Piloting | 13 | December 2nd 04 01:00 PM |
Is AWC an approved weather source? | Andrew Sarangan | Piloting | 1 | June 26th 04 01:01 PM |
clever amateur built placard mods | Joa | Home Built | 5 | January 8th 04 08:10 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
