I am running a system that includes WinPilot running on an Ipaq 37XX
series, Colibri GPS/logger and Borgelt B50. The system is very unstable and will usually only run for an hour at the most and often only a few minutes before it crashes or gives an error message. I get a "lost GPS signal" quite often even though the colibri is showing nine satellites and a 3D lock. Other times the Ipaq just locks up and has to have the reset button pushed to get it running again. I have spoken to an other pilot with the same configuration and he is having similar problems. Has anyone dealt with this and found a solution or has any ideas of what ot do to fix this? Tim |
ttaylor at cc.usu.edu wrote:
I am running a system that includes WinPilot running on an Ipaq 37XX series, Colibri GPS/logger and Borgelt B50. The system is very unstable and will usually only run for an hour at the most and often only a few minutes before it crashes or gives an error message. If there is too much GPS data being passed through the B50, its output will be garbled, which will occasionally cause software running on the PDA to lock up. In the case of the Colibri, there is an NMEA configuration screen that determines the set of NMEA sentences that it outputs. You probably need to disable all sentences except those that are actually used by WinPilot. Marc |
Marc, Having the same trouble with WinPilot running on an Ipaq 37xx
with a Cambridge GPS. Cambridge has been updated with new battery. Any ideas, Tom Marc Ramsey wrote: ttaylor at cc.usu.edu wrote: I am running a system that includes WinPilot running on an Ipaq 37XX series, Colibri GPS/logger and Borgelt B50. The system is very unstable and will usually only run for an hour at the most and often only a few minutes before it crashes or gives an error message. If there is too much GPS data being passed through the B50, its output will be garbled, which will occasionally cause software running on the PDA to lock up. In the case of the Colibri, there is an NMEA configuration screen that determines the set of NMEA sentences that it outputs. You probably need to disable all sentences except those that are actually used by WinPilot. Marc |
Eric and Marc,
Thanks for the replies. Marc, I have the Colibri set up following the Winpilot recommendations of GPGGA and GPRMC outputs. I can try turning them off one at a time. Eric, I checked and the IR port is turned off. So hopefully that is not the problem. I will try some test to see if things improve. I would like to get this all worked out before heading to Ely next week. Thanks, Tim |
Marc, I have the Colibri set up following the Winpilot recommendations of GPGGA and GPRMC outputs. I can try turning them off one at a time. As I know winpilot use these NMEA sentences. So if you disable them it won't work at all... Eric, I checked and the IR port is turned off. So hopefully that is not the problem. I will try some test to see if things improve. I would like to get this all worked out before heading to Ely next week. Try to log the nmea output (as suggested on the winpilot page). "1. How do I troubleshoot cable connection between my GPS/Logger and Windows CE device? We have written a special application to make it easier. Right-click on one of the links below , save it on your PC, and transfer it to your Windows CE device to \Windows\Start Menu directory. You should then be able to start it from the Start button menu. The application shows if NMEA data is arriving to the serial port, and saves the incoming data into a file named NMEA_Log.txt. WinPilotTTy for MIPS WinPilotTTy for iPAQ " Do not use any tweak software/hardware (overclocking, special system functions etc-etc). /Janos |
Eric and Marc, Thanks for the replies. Marc, I have the Colibri set up following the Winpilot recommendations of GPGGA and GPRMC outputs. I can try turning them off one at a time. I'm not a WinPilot user, but if you have just GPGGA, GPRMC, plus the LXN-specific sentence that outputs pressure altitude, your B50 should be able to handle that amount of data without problem. I'll be at Ely, so if you haven't solved it by then, I can take a look... Regards, Marc |
Tom,
Make sure the beam is off on your ipaq. Start, Settings, Connections, Beam, uncheck box. The green light on the GPS NAV blinks when there is a GPS lock, solid light then you don't have a GPS lock. If you get error messages when the GPS-NAV is solid then there may be a problem with a weak GPS engine in your GPS-NAV. If the GPS_NAV is blinking and you get the message then possibly a problem with the wiring or the connectors. Richard www.craggyaero.com |
![]() Tim The colibri NMEA output should be GPGGA, GPRMC, LXWpx all YES, Baud rate 4800, and make sure the infared port in off in the ipaq. If this does not fix your problem, then I would look to the cabling quite possibily a bad connection. Richard www.craggyaero.com ttaylor at cc.usu.edu wrote: I am running a system that includes WinPilot running on an Ipaq 37XX series, Colibri GPS/logger and Borgelt B50. The system is very unstable and will usually only run for an hour at the most and often only a few minutes before it crashes or gives an error message. I get a "lost GPS signal" quite often even though the colibri is showing nine satellites and a 3D lock. Other times the Ipaq just locks up and has to have the reset button pushed to get it running again. I have spoken to an other pilot with the same configuration and he is having similar problems. Has anyone dealt with this and found a solution or has any ideas of what ot do to fix this? Tim |
An Update:
Marc, Eric, Richard, Al and Janos Thanks for the suggestions. On my last flight the system worked flawlessly for the entire flight. I did not do the conversion scientifically, i.e. one change at a time so I don't have the definitive answer to what was wrong. I made three major changes at one time so that any or all may have made the difference. Al let me know one of my Ipaq's may have a problem. I also noticed that the one I was using was having trouble syncing with my desktop computer the last few weeks. This would indicate a com port problem on the unit. I was not using the LXWpx string from the Colibri. I turned that on. I upgraded WinPilot to the 6.07 version from the 5.xx version I had. Jerry at WinPilot was very helpful as well as Richard at Craggy Aero. A side note, I love the new GO TO feature in WinPilot 6.0. I think this is worth the upgrade by itself. I confirmed the autobeam infrared function was off on both of my Ipaqs. So after changing to my second Ipaq 3760, upgrading the software and turning on the LXWpx stream the system is rock solid stable. I even tested it by turning off the Colibri and then back on. The WinPilot would note the data stream was lost, but resume working as soon as the Colibri was sending data again. Thanks, Tim |
