Tow plane ideas
Old May 26th 21, 07:37 PM posted to rec.aviation.soaring
jackson maddux
Default Tow plane ideas
My glider club is looking into the possibility of a new or upgraded tow plane. We currently have a 160hp supercub, but we have also looked into a rare-as-hens-teeth piper pawnee. As i poke around barnstormers and trade a plane, i have seen ads for a 190hp vans RV-6, a maule 235, a stinson 200+ hp, motorgliders, cessna 188, etc.
Anyone out there have some ideas for a tow plane that might be very functional but also (perhaps) not well known? Ive seen stories on stinson's maule's and wilga's being used in the past, for example, but it would be good to hear of some currently used "unusual" towplanes.
thanks for any feedback!
Old May 26th 21, 08:42 PM posted to rec.aviation.soaring
Dan Marotta
I did a few tows using a Maule back in the 80s and I didn't like it.Â*
Flying with a stick is much easier for towing and the visibility out of
the Maule did not compare to that from a Pawnee.
I've also towed with an L-19 and they're great but expensive to acquire,
180-hp Super cub and Citabria which were both great, a CalAir A-9B which
tows quite well but it's physically demanding to fly due to the location
of the stick and the fowler flaps are very difficult to deploy but it's
the easiest landing tail dragger I've ever flown.Â* I've also towed with
a 235-hp Pawnee which is very easy to fly and gets gliders into the air
quickly.Â* Finally I would highly recommend a Cessna Ag Wagon.Â* It's the
roomiest and most comfortable of all of the above, flies naturally and
easily, and is easy to land, but with 300-hp it's the hungriest of all
the rest.
Dan 5J
Old May 26th 21, 09:10 PM posted to rec.aviation.soaring
Before you get rid of that 160 Super Cub, have you tried a bigger “bush” prop
on the Super Cub? We used a 82” Bohrer prop with very good results. It performed
like it had 180 Hp, but without the 6 cylinder maintenance. For the required prop
to ground clearance, mid sized balloon tires are required though.
Our club operates a 235 Hp Pawnee as well, and when our membership shrank to where we couldn’t justify having two tow planes anymore, we sold the Cub to an Alaskan bush pilot.
It just so happens though, that we have unearthed a “new in box” 82/41 McCauley
(their version of the Bohrer) prop in the rafters of our hangar this past week. I believe the club will be looking to sell it sometime soon. People are trying to see if they can find the paperwork to accompany the prop right now.
If new tires and a new prop can get you what you need without having to find a PA-25,
you may be better off financially to try it. If you don’t like it, some guy from Alaska will probably fly down to take the upgraded Cub off your hands.
Mike Opitz
RO
www.NutmegSoaring.org (Freehold, NY)
Old May 26th 21, 10:56 PM posted to rec.aviation.soaring
Don't know much about unusual towplanes, they are all just workhorses. I have had three Pawnee's and flown many more towplanes , currently have what we call Towpecker, a 235 that is actually about 270, and it pulls very well. The Pawnee is the go to towplane, but there are others that do quiet well like the old straight tail 182. I like the way the 188 flies a bit better that the Pawnee, also flew a 400 hp Brave that did very well.
Everybody wants a Pawnee, for obvious reasons, finding a towplane these days is not the problem, finding a tow pilot is another story. The Wilga makes a good towplane, but operational cost are high, also there are a few ugly looking French towplanes around, just cannot remember their names. Recently ran across a good old Air Tractor, but once again the operational cost are high. You must look at operational cost vs performance,
You might be better off going to 180 hp in that Super Cub, we did that back in the day in Miami and it worked very well. The Purist, Old Bob
Old May 27th 21, 07:43 PM posted to rec.aviation.soaring
John Foster
What about looking at a C 180/182, particularly with the 180HP motor? Those should work adequately for most applications.
Old May 27th 21, 10:44 PM posted to rec.aviation.soaring
Marton KSz
8GCBC Scout
Aviat Husky
Old May 27th 21, 11:09 PM posted to rec.aviation.soaring
Underpowered
Old May 28th 21, 01:00 AM posted to rec.aviation.soaring
George Haeh
One club decided on a 182 over a Pawnee. Parts availability was a major factor. Also easier to do check outs.
Considerable cylinder work and cooling issues ensued. Changed to a Pawnee.
Old May 28th 21, 08:42 PM posted to rec.aviation.soaring
Dan Marotta
The C-180 has 230 hp.
Dan
5J
Underpowered
Old May 28th 21, 11:25 PM posted to rec.aviation.soaring
Jeff Bures
Dan
5J
Don't know much about unusual towplanes, they are all just workhorses.. I have had three Pawnee's and flown many more towplanes , currently have what we call Towpecker, a 235 that is actually about 270, and it pulls very well. The Pawnee is the go to towplane, but there are others that do quiet well like the old straight tail 182. I like the way the 188 flies a bit better that the Pawnee, also flew a 400 hp Brave that did very well.
Underpowered
I don't think the RV-6 is viable, legally speaking (experimental cert). But I'm just reading from google searches, and could be wrong.
Too bad, I think a bare bones Zenith or similar STOL kit might make a good economical tow plane.
Given the expense and dwindling availability of tow planes, has SSA considered lobbying to change CFR 91.319 to allow towing of any (not just LSA) sailplane?
PW-5 Trailer Ideas? Ed Anderson Soaring 2 September 16th 17 01:07 PM
Any ideas, chaps ? Dingo[_4_] Aviation Photos 5 October 27th 10 03:32 PM
pc ideas? derFlieger Simulators 3 May 5th 05 11:26 PM
GPS Ideas RD Piloting 24 December 12th 03 10:53 AM
flight sim Ideas Steve Simulators 0 July 13th 03 08:56 AM
