A Kodiak owner requested installation of a lighter power socket notshown in its wiring diagram. also wants BOSE noise cancelling headset whichrequire 28vdc to work, wiring diagram shows installation for David Clarkwhich is similar
Old June 13th 21, 04:21 AM posted to rec.aviation.homebuilt
Ariel Romero
Default A Kodiak owner requested installation of a lighter power socket notshown in its wiring diagram. also wants BOSE noise cancelling headset whichrequire 28vdc to work, wiring diagram shows installation for David Clarkwhich is similar
El martes, 15 de octubre de 2002 a las 21:38:58 UTC-3, Joe Norris escribió:
Omar Filipovic wrote:
Does any of this actually apply to experimentals, especially those where the
original builder is making the modifications?
An FAA Form 337 is not used for repairs or alterations on an
experimental airplane, regardless of whether it's the original builder
or another person doing the work. The procedure for approving a major
change to an experimental aircraft is covered in that particular
aircraft's operating limitations document. These "OpLims" are a part of
the airworthiness certificate, and as such must be carried in the
aircraft at all times.
If you are making a change to your experimental aircraft, familiarize
yourself with the requirements for approving a major change as outlined
in the OpLims.
Joe Norris
Borgelt B50 Wiring Diagram? JohnDeRosa Soaring 3 July 9th 13 02:45 AM
Wiring Diagram for Vertex Headset Cable Jerry Owning 0 August 30th 06 04:54 AM
Wiring diagram for mic? Gary G Home Built 5 November 3rd 05 03:21 PM
Wiring diagram for GA mic Gary G Piloting 0 November 2nd 05 01:15 PM
King KMA-26 Wiring Diagram Keith Dobbins General Aviation 0 August 23rd 03 04:03 AM
