Is there a simple (or complex) guideline for the relationships between
CG, pivot axis and aerodynamic center for a control surface to prevent flutter? Is it as simple as keeping the CG at or ahead of the aerodynamic center, similar to designing for stability of the aircraft itself? -- FF |
The following is an article that you may find interesting, even though it
doesn't directly answer your question. http://www.soaridaho.com/Schreder/Co...l.html#flutter Wayne http://www.soaridaho.com/Schreder wrote in message oups.com... Is there a simple (or complex) guideline for the relationships between CG, pivot axis and aerodynamic center for a control surface to prevent flutter? Is it as simple as keeping the CG at or ahead of the aerodynamic center, similar to designing for stability of the aircraft itself? -- FF |
I had to rebuild my ailerons which started fluttering when approaching
175kts IAS. The ailerons should essentially balance horizontally when suspended from the hinges. If they are tail heavy and the wing starts shaking the aileron tail "shakes" in opposite direction to the wing. But that is just the orientation that will help the wing shake even more which in turn will shake (flutter) the aileron with an increasing amplitude - with possible destructive effects. This is a forced resonance effect. If your plane is slow this scenario may not effect things much. But it all depends on wing mass, stiffness of wing support, etc. In my case I had to include more weight on the front part of the aileron to balance. ----------------------------------------- SQ2000 canard: http://www.abri.com/sq2000 wrote: Is there a simple (or complex) guideline for the relationships between CG, pivot axis and aerodynamic center for a control surface to prevent flutter? Is it as simple as keeping the CG at or ahead of the aerodynamic center, similar to designing for stability of the aircraft itself? -- FF |
![]() "Stealth Pilot" wrote so you can build in flutter proofing by balance, absence of hinge slop and control tensions but in the end it is up to some careful test flying to determine whether there is an onset of flutter. The flutter test for the brave, goes something like this. Get plenty of altitude, say 8 thousand feet AGL, put the plane into a pretty steep dive, WOT, and give the stick a sharp rap. If the plane keeps flying, and you are satisfied with this speed as Vne, OK, you are done. If the plane starts to flutter, and the wing falls off, use you parachute, now. Oh, you did have a parachute on, didn't you? g -- Jim in NC |
On Tue, 7 Jun 2005 20:03:14 -0400, "Morgans"
wrote: "Stealth Pilot" wrote so you can build in flutter proofing by balance, absence of hinge slop and control tensions but in the end it is up to some careful test flying to determine whether there is an onset of flutter. The flutter test for the brave, goes something like this. Get plenty of altitude, say 8 thousand feet AGL, put the plane into a pretty steep dive, WOT, and give the stick a sharp rap. If the plane keeps flying, and you are satisfied with this speed as Vne, OK, you are done. If the plane starts to flutter, and the wing falls off, use you parachute, now. Oh, you did have a parachute on, didn't you? g Uh, you might have made a slight error here... the correct method is to get into a dive, pull up and at the correct test velocity, give the stick a sharp rap. The difference is that you're slowing down NOT speeding up as you enter the "test".... If you do encounter flutter, it's hopeful it will stop as you slow down. John |
![]() "John Ammeter" wrote Uh, you might have made a slight error here... the correct method is to get into a dive, pull up and at the correct test velocity, give the stick a sharp rap. The difference is that you're slowing down NOT speeding up as you enter the "test".... If you do encounter flutter, it's hopeful it will stop as you slow down. Good enough. It's been a while since I read about that. I guess not being able to slow down would be a "bad thing", but it *would* give my parachute scenario a better shot. g -- Jim in NC |
On Tue, 07 Jun 2005 18:23:12 -0700, John Ammeter
wrote: On Tue, 7 Jun 2005 20:03:14 -0400, "Morgans" wrote: "Stealth Pilot" wrote so you can build in flutter proofing by balance, absence of hinge slop and control tensions but in the end it is up to some careful test flying to determine whether there is an onset of flutter. The flutter test for the brave, goes something like this. Get plenty of altitude, say 8 thousand feet AGL, put the plane into a pretty steep dive, WOT, and give the stick a sharp rap. If the plane keeps flying, and you are satisfied with this speed as Vne, OK, you are done. If the plane starts to flutter, and the wing falls off, use you parachute, now. Oh, you did have a parachute on, didn't you? g Uh, you might have made a slight error here... the correct method is to get into a dive, pull up and at the correct test velocity, give the stick a sharp rap. The difference is that you're slowing down NOT speeding up as you enter the "test".... If you do encounter flutter, it's hopeful it will stop as you slow down. John thank you john. that's exactly how it is done. if you lose control because of flutter the aircraft is moving back into a more inherently safe speed range. ...if it lasts that long. :-) Stealth Pilot |
Avoiding Vne | K.P. Termaat | Soaring | 120 | April 7th 04 07:56 PM |
and when you know how to prevent a spin.......... | Pete Zeugma | Soaring | 2 | January 28th 04 11:30 PM |
Tail flutter! | I Can Computer Services | Home Built | 3 | November 24th 03 12:56 AM |
