Trailer compatibility
Old June 8th 05, 09:19 PM
Ramy
Default Trailer compatibility
How doable is it to retrieve a 15m glider (LS4 in particular) with
other trailers? Does it have to be a Komet trailer, or any other
popular 15m trailer should do? Any modifications may be required?
The idea is to share trailers during a safari trip in case of ground
retrieves, thus reducing the number of crew needed.
Anyone has experience with this?
Thanks,
Ramy
Old June 8th 05, 10:08 PM
John Sinclair
with
or any other
be required?
in case of ground
Thanks,
Ramy
I would try the 'other' ship in the trailer, first.
Several things may vary like the distance of spar to
floor, cord at root and tip, tail wheel pod in floor
location, nose cone, etc. The clam shell also has retaining
fittings that are set for each particular ship. I doubt
you will find 2 ships that compatable, except the ASW-20
and Pegasus, but thats another thread, isn't it?
JJ
Old June 9th 05, 02:39 AM
Ken Kochanski (KK)
The chord from leading edge to the trailing edge fillet on the wings
are typically longer on standard class ships. i.e. the height of the
clamshell can be higher at the spar end for standard class trailers vs
15M trailers of the same era.
We had a pilot borrow a 15M trailer to retrieve a standard class ship
.... everything seemed fine ... they closed the top and didn't feel any
resistance ... but then noticed two 'horns' sticking through the top of
the clamshell at the front ... i.e. the trailing edge wing fillets of
the wider std class wing had pushed through the glass top of the 15M
trailer.
You can measure ... but if tolerances are close ... put the wings in
and have your partner close the top slowly as you check the distance
from the wing root TE to the top of the trailer. Depending on how safe
you want to be, and how close your measureed tolerances are, you can do
this in the trailer with a flashlight. Also, newer trailers have spar
hold-downs that may have to be adjusted ... the older models have holds
downs that kinda grab the wing root ... not as good to prevent bouncing
.... and maybe more of a pain to adjust for different gliders.
KK
trailer interior lighting? Ted Wagner Soaring 1 February 16th 05 11:31 AM
Trailer hitch inadvertant disconnect Bill Daniels Soaring 5 July 16th 04 03:17 AM
Trailer spare - who woulda thunk? Bill Daniels Soaring 7 May 20th 04 04:47 PM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
Tire Stiffness & trailer swaying chris Soaring 42 October 22nd 03 03:51 AM
