Mechanical tach failure?
Old November 3rd 04, 10:23 PM
Rich S.
Default Mechanical tach failure?
So, I was flying back home, happily burping all the shellfish I ate at the
Shelton Oysterfest, when my engine started speeding up. Well, it didn't
really - but my tach said it did. Without touching the throttle, I went from
2400 rpm up to 3400. Funny, my airspeed didn't change.
It looks like my sturdy, simple mechanical tach (bought used at OSH) has
gone South on me. I pulled it out and removed the case. Everything inside
looks great. It is cable driven through a magnetic coupling just like a car
speedo. The needle has a return spring wound in a coil like a clock spring.
I assume the calibration is done by setting the needle on its shaft in a
position relative to the return spring, so a given rpm matches the needle
position on the dial.
I thought I would discover a broken return spring, but it looks okay.
Turning the drive with an 1100 rpm electric drill shows ~2500 on the dial.
If I allow the needle to bypass the stop pin and add an extra full turn of
tension on the return spring, the tach shows the drill turning ~400. It
looks like the needle has slipped on the shaft releasing about a half-turn
of spring tension. Either that or
A. the spring has developed a weak spot or
B. the other end of the spring has come unsoldered from the frame.
I don't think it's "B" because the entire spring would be unwound. Visual
examination of the spring doesn't show any defects.
Any ideas?
Rich "May as well take it apart - it don't work" S.
Old November 3rd 04, 11:04 PM
rip
Or the needle slipped on the shaft?
Any ideas?
Old November 3rd 04, 11:53 PM
Bill Daniels
"Rich S." wrote in message
from
car
spring.
Any ideas?
An old gent I know who has been flying longer than anybody offered the
observation that the reason that old airplanes don't fly as fast as new ones
is that the needle return springs on tachometers and manifold pressure
gauges get weak with age causing the instrument to over-indicate. If pilots
keep setting power at the same gauge indications the airplane will indeed
fly slower as it ages. Re-calibrating the gauges restores the youthful
vigor.
If only that worked for me.
Bill Daniels
Old November 4th 04, 12:04 AM
Rich S.
"Bill Daniels" wrote in message
news:Kjdid.351704$MQ5.71307@attbi_s52...
ones
pilots
vigor.
Bill................
You mean that what I got is catching - and my tach come down with it? Oh,
Lordy.
Actually the tach started acting up all of a sudden, where my body took
years to reach its present state of weakness.
Rich "Need some vigor-ah" S.
Old November 4th 04, 01:19 AM
Cy Galley
You can take it to an automotive speedometer shop and they can clean,
lubricate, and calibrate. Tell them that it is driven off the cam in your
stock car so they get it right and don't panic.
It is standard old style AC and they uncrimp and re-crimp the bezels all the
time.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
from
car
spring.
Any ideas?
Old November 4th 04, 01:35 AM
Rich S.
"Cy Galley" wrote in message
news:eAeid.52917$R05.12713@attbi_s53...
time.
Cy...........
You the man!
Rich S.
Old November 4th 04, 02:48 PM
Cy Galley wrote:
: You can take it to an automotive speedometer shop and they can clean,
: lubricate, and calibrate. Tell them that it is driven off the cam in your
: stock car so they get it right and don't panic.
: It is standard old style AC and they uncrimp and re-crimp the bezels all the
: time.
Isn't the aircraft tach run off the cam, too? Thus indicating 2500 RPM would
require the cable at 1250?
Whatever you do... don't tell them it's for an airplane...
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old November 4th 04, 04:13 PM
Rich S.
would
When Cy mentioned that, I remembered it. I've got a couple of small
synchronus motors out in the shop. I'll hook one of them up and see if I can
get an accurate reading on the dial.
Learned that lesson well when I was building. Example - an automotive spring
shop refused to sell me some leaf spring stock until I came back the next
day and told them it was for an invention for the handicapped and NOT for an
airplane. Spring stock fer Pete's sake!
Rich S.
Old November 5th 04, 12:35 AM
John Galban
"Rich S." wrote in message ...
I like to tell them I'm building a variable oscillating frambulator.
That pretty much results in a blank stare from the other side of the
counter, and an end to the questions.
Ramifications of Cherokee Trim Jackcrew Failure Bob Chilcoat Home Built 23 June 9th 04 03:48 AM
Tail flapper failure Veeduber Home Built 2 May 22nd 04 07:52 AM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 06:39 AM
Interesting Flybaby wing failure analysis... Richard Lamb Home Built 3 August 27th 03 06:21 PM
Hinges under stress - mechanical engineering type question Corrie Home Built 21 August 6th 03 09:49 AM
