How come GPS reads different
Old June 12th 05, 01:38 AM
Aluckyguess
Default How come GPS reads different
How come the GPS reads a different altitude than the Altimeter?
Old June 12th 05, 02:14 AM
Matt Whiting
For many reasons. The main reason is that they derive altitude by two
completely different methods and this inevitably introduces errors.
Then each method has its own inherent errors.
Even two altimeters side by side won't read the same altitude other than
by accident.
Matt
Old June 12th 05, 04:54 AM
Aluckyguess
I am getting over 500ft. difference and more.
"Matt Whiting" wrote in message
completely different methods and this inevitably introduces errors. Then
by accident.
Matt
Old June 12th 05, 05:41 AM
Casey Wilson
"Aluckyguess" wrote in message
by accident.
Matt
The number of sattelites being received is one of the variables -- how many
are you registering on the GPS? What brand/model is the GPS. Is the GPS
certified for navigation? Does the GPS have a Kohlsman equivalent input?
What are the altitude specifications of the GPS? Are you comparing it to an
altimeter in an airplane? Is the calibration data on the altimeter valid?
Have you compared the altimeter to the GPS while parked at a known reference
(i.e., the benchmark of your local airport)? My Magellan handheld takes
about five mintues of averaging to get a reasonably close altitude
correlation -- how much time are you giving yours?
Bottom line, forget the GPS altitude reading, dial in the local pressure
data into the airplane's altimeter and trust it.
Old June 12th 05, 04:11 PM
Aluckyguess
Its a 296. It seems the like the higher I go the farther off it is.
I am one to think the GPS would be more accurate than the altimeter.
I was thinking that we get incorrect altimeter settings
"Casey Wilson" N2310D @ gmail.com wrote in message
news:x1Pqe.2896$9a1.185@trnddc01...
by accident.
Matt
many are you registering on the GPS? What brand/model is the GPS. Is the
GPS certified for navigation? Does the GPS have a Kohlsman equivalent
input? What are the altitude specifications of the GPS? Are you comparing
it to an altimeter in an airplane? Is the calibration data on the
altimeter valid? Have you compared the altimeter to the GPS while parked
at a known reference (i.e., the benchmark of your local airport)? My
Magellan handheld takes about five mintues of averaging to get a
reasonably close altitude correlation -- how much time are you giving
yours?
Old June 12th 05, 05:13 PM
Fred G. Black
The altimeter is only "accurate" when the temperature profile of the
airmass is equal to the ISA standard atmosphere. The rest of the time,
there will be some error which increases with altitude (wrt wherever the
source for the altimeter setting is located). This isn't a concern for
en-route operations since everybody's altimeter has the same "error".
It can be a concern for terrain clearance in the mountains or in some
cases instrument approaches in cold weather since the altimeter reads
higher than the plane actually is.
Old June 12th 05, 11:27 AM
Cub Driver
On Sat, 11 Jun 2005 20:54:01 -0700, "Aluckyguess"
Oh,. good grief! I'm sure I've never had as much as 100 ft of
variance, and more often it's 20 feet or so. (Garmin 296)
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old June 12th 05, 03:28 PM
GeorgeB
I frequently drive by 2 signs marking the "eastern continental divide"
with the elevation. With my WAAS equipped, non-aviation GPSR
(Meridian Gold), I habitually flip to a screen with elevation
displayed and have yet to differ by more than 40 ft. As Dan says, I
am usually within 15 ft.
I took two trips across parallel bridges in eastern Virginia 3 days
apart; the reading was stable and within 5 ft of what I visually
estimated it should be. It differed by 2 ft betweent he 2 days; my
eyes told me the bridge heights did also ...
I would trust a WAAS equipped GPS, tracking 5 or more birds in a clear
environment, to be more ACCURATE than a barometric altimeter. I would
USE my barometric altimeter if it were working as other aircraft in
the area are, adjusted to local barometer per information gained by
radio from official sources.
Old June 12th 05, 09:25 PM
Matt Whiting
But sometime and someplace you may not be:
http://gpsinformation.net/main/altitude.htm
Yes, augmented systems are a different matter.
Matt
Old June 12th 05, 02:13 PM
Matt Whiting
by accident.
Not that unusual. GPS isn't very accurate vertically. Most GPS manuals
tell you not to rely on the altitude in any serious way.
Matt
GREAT AVIATION READS Cribsheet Piloting 1 September 12th 04 02:51 AM
GREAT AVIATION READS Cribsheet Rotorcraft 0 September 10th 04 06:06 PM
GREAT AVIATION READS Cribsheet Military Aviation 0 September 7th 04 06:37 PM
When the ASI Reads Below Zero BTIZ Piloting 11 August 23rd 04 04:57 PM
Newsweek Reads RAM! Bob McKellar Military Aviation 0 February 17th 04 02:10 AM
