What does REC mean on the switch?
Old June 12th 05, 02:05 PM
Jose
Default What does REC mean on the switch?
So now we have a split landing light switch, because we have lights on
the wings too. The nose light switch says LDG which is easy enough to
decipher. The other, which controls the two forward-looking
landing-type lights on the wing tips, says REC.
Well, I'm as dumb as the next one, but if I know what the switch does, I
should be able to decypher the label.
"Reconnaissance"? (lighting up the sky looking for stray F16s)
"Record"? (imagining an Ipod in each lamp)
"Recollect"? (what you do when you stop forgetting what it stands for)
"Recover"? (turn them on if you get into an unusual attitude)
Surely it's not just whatever they had around - the label probably has
to be FAA approved, and I saw the same switch in a Sporty's video anyway.
What says the combined wisdom of the group?
Jose
The price of freedom is... well... freedom.
Old June 12th 05, 02:25 PM
Steven P. McNicoll
"Jose" wrote in message
So now we have a split landing light switch, because we have lights on the
decipher. The other, which controls the two forward-looking landing-type
Surely it's not just whatever they had around - the label probably has to
In-flight use as RECognition lights.
Old June 12th 05, 02:39 PM
Larry Dighera
On Sun, 12 Jun 2005 13:05:26 GMT, Jose
wrote in ::
Well, 'REC' could stand for 'reconnoiter as when making a forced
landing on a moonless night in inhospitable terrain. Of course you'd
want to turn it off if you didn't like what you saw. :-) Or, 'REC'
may refer to 'recognition' if used during daytime to add conspicuity.
Old June 12th 05, 02:55 PM
Jose
Ok, "recognition" makes sense for daytime visibility. The lights are
non-filament, so I'm not averse to using them all the time. (I wonder
why more landing lights are not like that)
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain."
(chapter 10 of book 3 - Harry Potter).
Old June 12th 05, 03:56 PM
Larry Dighera
On Sun, 12 Jun 2005 13:55:02 GMT, Jose
wrote in ::
What type of lamps do you have.
If they are halogen lamps, they have only recently been developed for
automotive use, and do require a transformer for operation, so weight
may be a consideration.
Quartz lamps do have a filament, but are rated to last significantly
longer than regular tungsten filament lamps in aviation applications.
There's some information about them he
http://www.google.dk/groups?selm=S1K...&output=gplain
Old June 12th 05, 04:48 PM
Jose
I'm not sure, but they seem to be like those newfangled purplish lamps
new cars are farded with - resembling a florescent or other gas
discharge something-or-other (you can see how technically inclined I
am!). I'll check and get back to you.
I always though of halogen lamps as ordinary filament lamps filled with
a halogen gas that lets them burn brighter, last longer, or something,
but the filament produced the light. In my case the light does not
appear to come from a filament.
Jose
Old June 12th 05, 05:29 PM
Larry Dighera
On Sun, 12 Jun 2005 15:48:24 GMT, Jose
wrote in ::
Yeah, I think you're right about that. Perhaps I was thinking of HID
lamps: http://www.extreme-exposure.com/hid/faq-data.shtml
http://www.autoplusuae.com/products/kdg/index.shtml
HID System components
(1) BULB : - The Xenon Gas and mercury Metal Halide Salts existing
inside the light emitting tube causes the molybdenum electrodes on
both sides to plasma discharge and create energy, which in turn
produces light.
Old June 12th 05, 06:23 PM
Morgans
"Jose" wrote in message news:W8Xqe.23
The lights are
What type of lights are they?
Jim in NC
Push to Talk Switch Jackal24 Piloting 23 December 26th 04 10:01 PM
C-172 landing light switch JFLEISC Piloting 16 May 6th 04 01:15 AM
C-172 landing light switch JFLEISC Owning 10 May 5th 04 11:05 PM
Portable Push-To-Talk switch help Eric Brown Owning 9 April 16th 04 04:26 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
