Since the cabon mics for the TX 760 are no longer available, is there a
way a dynamic mic can be used instead? I saw some references on RAS to a schematic to do this but haven't been able to locate it. |
Terra, and any radio that was set for CARBON Mic will work fine with
AMPLIFIED DYNAMIC (like even current Telex hand microphones and others) or most ELECTRET type microphones, these also work well with normal, glider type Gooseneck microphones (most of which are DYNAMIC) with the addition of an amplifier. Many radio manufacturers simply say in their manuals CARBON Microphone or "equivalent" an these are "equivalent" tim wrote in message oups.com... Since the cabon mics for the TX 760 are no longer available, is there a way a dynamic mic can be used instead? I saw some references on RAS to a schematic to do this but haven't been able to locate it. |
Terra VOR-GS | Paul Anton | Home Built | 0 | October 8th 04 07:38 PM |
Trouble with Terra 230 Audio panel | Mark | Owning | 0 | July 20th 04 02:13 PM |
Terra TX-720 Info requested... | Oscar Alonso | Soaring | 3 | April 23rd 04 09:17 PM |
Terra TX 760D | Henry and Debbie McFarland | Owning | 0 | December 27th 03 03:04 PM |
Need Terra documentation | ncsoar | Soaring | 1 | July 15th 03 09:41 PM |
