Flaperons
Old November 12th 04, 02:54 PM
Lou Parker
Default Flaperons
I just don't get it. Can anyone successfully explain how flaperons
work? Are they better or worse than seperate flaps? What are the pro's
and con's? It seems to me if one fails you have no recovery.
Lou
Old November 12th 04, 03:14 PM
Bill Daniels
"Lou Parker" wrote in message
om...
Lou
At least in sailplanes, they work very well. My Nimbus 2C droops the
ailerons with the flaps but at a lesser rate which introduces a large
effective wing twist at low speeds.
The upside of flaperons is that the whole span is flapped which improves low
speed performance and the total aileron area is larger which improves roll
authority.
The down side is when you need a lot of aileron at a time when full flaps
are deployed they the roll response heavy and sluggish. The solution is to
hold off on full flaps until you are on short final.
Bill Daniels
Old November 12th 04, 08:55 PM
Dan Nafe
In article _q4ld.24439$V41.4860@attbi_s52,
"Bill Daniels" wrote:
[snip]
always a good idea
Old November 12th 04, 09:14 PM
QDurham
The solution is to
always a good idea
Of course if you are really good, and are flying a real airplane, to hell with
the flaps. Slip it in. Can always "unslip," you know, but "unflapping" is
looking for trouble.
Quent
Old November 12th 04, 09:29 PM
Bill Daniels
"QDurham" wrote in message
The solution is to
always a good idea
with
Quent
Actually, the dive brakes on my sailplane will convert the 50:1 glider (30:1
with approach flaps) to 5:1 and back in the blink of an eye. Slips aren't
needed or, for that matter, very effective.
Bill Daniels
Old November 12th 04, 10:13 PM
Ron Natalie
QDurham wrote:
The solution is to
always a good idea
How effective a slip is depends on what how much rudder you have and how big
the sides of your aircraft is. A lot of go fast planes and high performance
gliders don't get too much drag out of a slip.
Old November 13th 04, 01:05 PM
BRO
Never mind mate, I got it, and had a laugh..
Brett.
The solution is to
always a good idea
with
Quent
Old November 12th 04, 03:31 PM
Larry
om...
Lou
My experience is on the A-6 (series) military aircraft that has a Flaperon
System. As the stick is moved Right, the Right Flaperon gradually comes up,
killing some of the lift on the right wing, causes a loss of lift, the wing
drops, and the A/C banks Right. These surfaces are what you would think a
'spoiler' would look like and operate much like an Aileron.
A completely separate system causes both Flaperons to 'popup' on touchdown
while landing 'shorebased'. This kills the lift (as soon as the wheels
touchdown) and allows the aircraft to quickly 'settle into the gear' so the
Anti-Skid system can work effectively, thus slowing the A/C safely.
An added note: the Flaperons are really 'misnamed' because (at least in the
case of the A-6) they have nothing to do with Flaps. The A-6 (and many other
Naval Aircraft) have Flaps (on the trailing edge) and Slats (on the leading
edge).
Hope this helps.
Larry
AECS (AW/SW/MTS)
USN 'Retired'
20 years if gettin 'em off the pointy end
AND safely home again!
Old November 12th 04, 04:04 PM
"Larry" wrote in message
other
leading
edge).
Hope this helps.
Larry
AECS (AW/SW/MTS)
USN 'Retired'
Larry,
You are correct. The A-6 Flaperons are indeed misnamed. In reality they
are spoilers very similar in design to the glide slope control spoilers used
on Schweizer sailplanes.
http://www.soaridaho.com/Schreder
Retired A-6 Bombardier
Old November 13th 04, 02:32 AM
Larry
"Wayne Paul" wrote in message
other
leading
edge).
Hope this helps.
Larry
AECS (AW/SW/MTS)
USN 'Retired'
Larry,
used
I can recall spending many a late night out there re-rigging the control
surfaces on the Prowler (Navy EA-6B) when I worked in Quality Assurance. The
Airframes guys would make an adjustment and we'd have to witness the
'throws' to ensure all was within specs. That dam Hydraulic Genny was
screaming and the hydraulics were whining- It's no wonder I lost most of my
hearing.
All that 'so we could 'make the flight schedule'. Now it's somebody else's
turn to 'wrench on those jets'.
Larry
AECS (AW/SW/MTS)
USN 'Retired'
