http://www.rcshowcase.com/html/engines/rcs400.html
20 lb, 23hp 400cc 5 clyinder radial. This engine has got to be getting close to bridging the gap between ultralight and RC (understanding it is expensive for an ultralight) What could you do with this? twin engine PBY ultralight? (twin because, reliability?) the 215 cc verion gets 76 lbs of thrust (that info is not available for this engine) |
("pittss1c" wrote)
20 lb, 23hp 400cc 5 clyinder radial. This engine has got to be getting close to bridging the gap between ultralight and RC (understanding it is expensive for an ultralight) What could you do with this? twin engine PBY ultralight? (twin because, reliability?) Would it work on this plane? ...it's a twin. http://www.flight.cz/cricri/english/index.php http://www.amtjets.com/gallery_real_plain.html Montblack |
I believe the Cri-Cri flew with 2 8 HP chainsaw engines.
"Montblack" wrote in message ... ("pittss1c" wrote) 20 lb, 23hp 400cc 5 clyinder radial. This engine has got to be getting close to bridging the gap between ultralight and RC (understanding it is expensive for an ultralight) What could you do with this? twin engine PBY ultralight? (twin because, reliability?) Would it work on this plane? ...it's a twin. http://www.flight.cz/cricri/english/index.php http://www.amtjets.com/gallery_real_plain.html Montblack |
So.....why do you have to mix the oil and gas for this "4-cycle"
engine? Neal Cy Galley wrote: I believe the Cri-Cri flew with 2 8 HP chainsaw engines. "Montblack" wrote in message ... ("pittss1c" wrote) 20 lb, 23hp 400cc 5 clyinder radial. This engine has got to be getting close to bridging the gap between ultralight and RC (understanding it is expensive for an ultralight) What could you do with this? twin engine PBY ultralight? (twin because, reliability?) Would it work on this plane? ...it's a twin. http://www.flight.cz/cricri/english/index.php http://www.amtjets.com/gallery_real_plain.html Montblack |
Excelent question...
Maybe there is no oil bath/sump (like other common 4 stroke RC engines) wrote: So.....why do you have to mix the oil and gas for this "4-cycle" engine? |
pittss1c wrote:
http://www.rcshowcase.com/html/engines/rcs400.html 20 lb, 23hp 400cc 5 clyinder radial. This engine has got to be getting close to bridging the gap between ultralight and RC (understanding it is expensive for an ultralight) What could you do with this? twin engine PBY ultralight? (twin because, reliability?) the 215 cc verion gets 76 lbs of thrust (that info is not available for this engine) Heh. And I thought the ultralight engines were expensive...... Yeah, two of them might power something that you could sit in yourself... But at 5900 bucks, it's not worth it at all. You could get a Rotax 447 for half that, or a 503 for about 2/3 that - either of those motors you definitely could power a 'real' airplane with.... LS N646F |
| Thread Tools | |
| Display Modes | |
