I'm hoping the home built community can assist me with a small problem.
I own a glider that does not fly straight without applying a little constant cross control (L stick and R rudder). If hands are removed from the controls, it slips (or yaws?) to the left, and then the nose gently swings around to the right. If allowed to continue, the aircraft begins to dive to the right and rapidly builds up airspeed. The aircraft was never damaged but may have had control rods for the ailerons replaced putting the control surfaces out of alignment. The maintance manual gives the proper aileron and flap deflection angles. The angle is measured from a reference point on the bottom surface of the wing 100mm forward of the aileron-wing junction to the trailing edge of the aileron. My question is how do you measure the angles of the control surfaces to see if they are within tolerance of their deflection angles? |
![]() wrote My question is how do you measure the angles of the control surfaces to see if they are within tolerance of their deflection angles? The easy way is to find someone with, or buy, a "smart level" that electronicaly reads out the degrees of the surface it is set upon. A real handy tool to have around, for many other purposes. I would get one that has a small removable core with the guts, that can be put into different levels of many different lengths. You can also make a widget using a protractor and a plumb bob hanging down from it's center pivot point. Make sure the aircraft has been blocked up level, and stationary. Check that the wings themselves were rigged correctly, with the same angle of incidence, if it has removable wings, and that the trim tabs are where they are all supposed to be. -- Jim in NC |
My question is how do you measure the angles of the control surfaces to see if they are within tolerance of their deflection angles? One of these cost about $2 at Harbor Freight. (The tool, not the elevon). http://ernest.isa-geek.org/Delta/Pic...DownTravel.jpg -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
![]() "Ernest Christley" wrote \\ One of these cost about $2 at Harbor Freight. (The tool, not the elevon). http://ernest.isa-geek.org/Delta/Pic...DownTravel.jpg How accurate and reliable are those things? I'll bet they are not accurate to more than 2 degrees, and reliable? Good for guesses, but I wouldn't even want to build a house with one, let alone an airplane. Sorry if I step on any toes with this. -- Jim in NC |
Morgans wrote:
"Ernest Christley" wrote \\ One of these cost about $2 at Harbor Freight. (The tool, not the elevon). http://ernest.isa-geek.org/Delta/Pic...DownTravel.jpg How accurate and reliable are those things? I'll bet they are not accurate to more than 2 degrees, and reliable? Good for guesses, but I wouldn't even want to build a house with one, let alone an airplane. Sorry if I step on any toes with this. Guess you would never ride with me in my RV-6 then because that is what I used. On July 14 I will have been flying it for 16 years so I guess they must work. You are right I would never build a house with one.:-) Jerry |
Jerry Springer wrote:
Morgans wrote: How accurate and reliable are those things? I'll bet they are not accurate to more than 2 degrees, and reliable? Good for guesses, but I wouldn't even want to build a house with one, let alone an airplane. Sorry if I step on any toes with this. Guess you would never ride with me in my RV-6 then because that is what I used. On July 14 I will have been flying it for 16 years so I guess they must work. You are right I would never build a house with one.:-) They were good enough for 2 degree spacing for satellite antenna alignments. Course 2 degrees at 22,300 miles is a far piece and that was over 20 years ago... |
Morgans wrote:
"Ernest Christley" wrote \\ One of these cost about $2 at Harbor Freight. (The tool, not the elevon). http://ernest.isa-geek.org/Delta/Pic...DownTravel.jpg How accurate and reliable are those things? I'll bet they are not accurate to more than 2 degrees, and reliable? Good for guesses, but I wouldn't even want to build a house with one, let alone an airplane. Sorry if I step on any toes with this. How accurate is a plumb bob? All this is, is a weight on a pivot. The accuracy is wholy dependant upon the radius of the scale. I'll leave the envisioning of the geometry as an exercise. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
![]() "Ernest Christley" wrote All this is, is a weight on a pivot. The accuracy is wholy dependant upon the radius of the scale. I'll leave the envisioning of the geometry as an exercise. My reasons for doubting its accuracy are two. One, is the closeness together of the degree markings. No doubt, they are very small distances between the degrees. Could you see if it was reading 11.3, or 11.8, or even if it was 11 or 13? Two, if there is any friction or binding, the weight would not allow the mechanism to be pointing to the true number that it should be. In a cheap plastic mechanism, I think the chances of a non binding system is pretty low. -- Jim in NC |
Morgans wrote:
"Ernest Christley" wrote All this is, is a weight on a pivot. The accuracy is wholy dependant upon the radius of the scale. I'll leave the envisioning of the geometry as an exercise. My reasons for doubting its accuracy are two. One, is the closeness together of the degree markings. No doubt, they are very small distances between the degrees. Could you see if it was reading 11.3, or 11.8, or even if it was 11 or 13? Two, if there is any friction or binding, the weight would not allow the mechanism to be pointing to the true number that it should be. In a cheap plastic mechanism, I think the chances of a non binding system is pretty low. You are correct, but... -a plastic housing doesn't necessarily imply plastic movements -only a very small amount of weight hangs on that movement -you can only guess between 11.3 and 11.8, but who cares?! It's control surfaces, not wings. I use a water level for that, because being off by ..1 degree will show up as a very noticeable 1/16" difference over 8ft. With control surfaces, you adjust them centered with the stick centered and then verify that the movements are withing a degree or two. You never see where they're actually at in a light plane, just how they 'feel' and 'react'. (I think I've stated this last sentiment poorly.) -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ernest Christley wrote: Morgans wrote: "Ernest Christley" wrote \\ One of these cost about $2 at Harbor Freight. (The tool, not the elevon). http://ernest.isa-geek.org/Delta/Pic...DownTravel.jpg How accurate and reliable are those things? I'll bet they are not accurate to more than 2 degrees, and reliable? Good for guesses, but I wouldn't even want to build a house with one, let alone an airplane. Sorry if I step on any toes with this. How accurate is a plumb bob? 4.271839526+ times more accurate than a Billy-Bob. *snicker* |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
PIK20D Control surface hinge moments | PIK20D | Soaring | 3 | November 19th 04 03:06 PM |
Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 02:20 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
