What's your maximum G-load?
Old June 30th 05, 04:52 PM
Happy Dog
Default What's your maximum G-load?
wrote in message news:
G-LOC= "G force induced loss of consciousness" There's a fairly linear
relationship between time spent at positive Gs and loss of consciousness
for
any individual. (Vector pointing straight down or parallel to the
spine.)
The graphs at the site linked below are far from linear!
At any particular g load.
As another example, I just realized my kids pull more than 2 G's
every day on the swings (although a sub-second timeframe may not meet
my definition of "sustained" :-).
Five seconds is "sustained".
OK. What happens at timescales significantly above 5s?
Sleep.
http://aeromedical.org/Articles/g-loc.html
What is the baseline in the graph at the site? 0g or 1g? Note that
level flight is 1g, of course.
1G
It is mentioned that G-LOC has happened with as little as 2g. This
would mean 60 degree banking turn. I think even airliners allow more -
like, IIRC, Airbus flight envelope protection extends to 67 degrees.
What is the corresponding +g load?
About 3Gs.
And I suspect that this G-LOC at +3, +4, +2 concern pilots sitting and
staying seated in a pilot seat. Thighs horizontal, buttocks supported,
back somewhat supported (reclining enough not to slump forward or aside
on G-LOC). Right?
At which g would one suffer G-LOC while standing up in an aisle?
Walking along aisle?
At which g can one feel safe to get up suddenly and put a heavy item in
an overhead bin? Go and use a lavatory?
It really depends on the individual. Almost anyone can tolerate 2Gs for a
sustained period but moving about or lifting anything heavy would be
difficult. I think that the cutoff point for the average person (sustained)
is around 3.5Gs.
What would be the effect of 2g sustained for 5 minutes? Or for 5 hours?
I mean, I suppose circling at 60 degrees bank angle would be somewhat
wasteful of fuel, but the airliners do manage 18-19 hours level flight
nonstop and without tanking...
Over 30 degrees of bank angle is unusual for an airliner. If you're not
used to it, 60 degrees looks and feels like 90.
Can one sleep (and get up again) at 2g?
That's an interesting question. xposted for an answer.
moo
Old July 1st 05, 12:16 PM
Cub Driver
On Thu, 30 Jun 2005 11:52:33 -0400, "Happy Dog"
is around 3.5Gs.
A young pilot in good physical condition ought to tolerate 5 Gs. With
specialized training, as was given to Spitfire pilots in WWII, 9 Gs is
possible.
That's strapped in, of course, and in the case of the Spitfire pilot,
he's grunting and straining for all he's worth.
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old July 1st 05, 01:24 PM
john smith
is around 3.5Gs.
possible.
Gotta disagree with you Dan.
happydog has it right.
G-tolerance is something you develope, you cannot just strain at the
right time and stay awake.
Back when I was younger and in excellent physical condition, I did
aerobatic training. Sustained or repeated G's will quickly drain you
with each successive maneuver. I never did enough to go to sleep, but
repeated 4-5 G maneuver's caused be to gray out for several seconds (the
instructor was then in control of the aircraft).
Old July 1st 05, 02:02 PM
Jay Honeck
G-tolerance is something you develope, you cannot just strain at the right
aerobatic training. Sustained or repeated G's will quickly drain you with
each successive maneuver. I never did enough to go to sleep, but repeated
4-5 G maneuver's caused be to gray out for several seconds (the instructor
How do pilots like Sean Tucker and Patty Wagstaff sustain G loads for their
entire routine?
I know Tucker "takes a break" half-way through his, doing a long climb out
while he catches his breath (or clears his head), but, still -- they seem to
be under incredibly high Gs for a large portion of their 15 minute routines.
I've only had one aerobatic flight, pulling a maximum of 4 Gs that lasted
maybe ten seconds, and even that was a pretty good workout. I can't
imagine doing that -- and far more -- every few seconds for 15 minutes!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old July 1st 05, 10:27 PM
Happy Dog
"Jay Honeck" wrote in message
news:3abxe.119054$xm3.82811@attbi_s21...
Grey out is something you learn to tolerate. Although it's flirting with
the edge of G-LOC, it's safe to do once you've learned to predict the onset
of G-LOC and learned your personal limits. When I started training, I once
blacked out, in part, from an improper straining maneuver. The instructor
just let me ride it out. Waking up was like coming out of a dream. It took
over ten seconds from lights out to initiating recovery. G-LOC is not to be
****ed with.
their entire routine?
Practice, practice, practice. That, and, as you noted, the routines are
designed to allow breaks in G loads.
moo
Old July 1st 05, 06:56 PM
Chris Schmelzer
is around 3.5Gs.
possible.
Most healthy military pilot sorts (completely healthy and fit) have a
RESTING G tolerance of 4-5G, that is without any muscular contraction or
strain maneuver.
Leg and abdominal muscle straining typically adds another 0.5-1.0G on
top of this resting tolerance, and then adding the G-Strain maneuver
(pushing against a closed glottis to increased intrathoracic pressure)
adds above that.
I recently spun in the centrifuge at Brooks AFB and started to gray out
at around 4.2-4.5, and then had to begin the strain (lightly at first of
course) at around 5.3-5.4 G. I was able to go to just over 9G without
blacking out or G-LOCing which was fun (in hindsight) but it REALLY is a
lot of work.
Tolerance varies widely, with some graying out at 3.5 and some going to
7+G with no strain whatsoever.
Good lower limb and abdominal muscle strength helps peak tolerance, and
good cardiovascular fitness seems to help with repetitive Gs.
-Chris Schmelzer, MD, Captain
Medical Corp, Flight Surgeon
110th Fighter Wing, Michigan ANG
Chris Schmelzer, MD
Capt, 110th Fighter Michigan ANG
University of Michigan Hospitals
Ann Arbor, MI
Old July 1st 05, 09:40 PM
Erik Max Francis
I heard a report that women tended to tolerate high gee forces better
than women because they tend to be shorter and have different centers of
gravity. Is that still thought to be the case?
Erik Max Francis && && http://www.alcyone.com/max/
San Jose, CA, USA && 37 20 N 121 53 W && AIM erikmaxfrancis
Heaven ne'er helps the man who will not act.
-- Sophocles
Old July 2nd 05, 02:19 AM
Apparently the problem of legs getting jammed while exiting the
Spitfire was a common one. Bader was lucky in that he could just pull
the rip-cord, and leave the legs behind.
Actually, it was even better luck for Bader: he had been told that if
he landed a parachute jump with his no-knee-joint prosthetic attached,
the shock would drive the thing right thru his pelvis (More,
short-term, g-loading!)
F/A-18 external stores load [email protected] Naval Aviation 3 December 27th 04 07:59 AM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
Stupid question about flight testing and "the envelope" Scott Ferrin Military Aviation 12 January 7th 04 03:56 AM
Va: maneuvering speed ad nauseam Koopas Ly Piloting 14 November 29th 03 05:07 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
