I had about a third of the inside of the horizontal stab get a through
dose of water repellent for leather. The stuff has a very low viscosity and I think will soak right into the resin preventing a good bond. No it's not silicon. Any good way of removing this stuff without destroying the stab in the process. There are a not of nooks and crannies that you just can't reach. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger wrote: I had about a third of the inside of the horizontal stab get a through dose of water repellent for leather. The stuff has a very low viscosity and I think will soak right into the resin preventing a good bond. No it's not silicon. Any good way of removing this stuff without destroying the stab in the process. There are a not of nooks and crannies that you just can't reach. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I would start by soaking a cloth with the repellant and seeing what will remove it from the cloth. First thing that comes to mind is good old hot water and soap, after that I would slowly move up the solvent ladder, taking care to use non-oily solvents (i.e. no turps, mineral spirits). The first would be alcohol. Yours Vern |
On Thu, 02 Dec 2004 00:59:32 GMT, Vernon Klukas
wrote: In article , Roger wrote: I had about a third of the inside of the horizontal stab get a through dose of water repellent for leather. The stuff has a very low viscosity and I think will soak right into the resin preventing a good bond. No it's not silicon. Any good way of removing this stuff without destroying the stab in the process. There are a not of nooks and crannies that you just can't reach. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I would start by soaking a cloth with the repellant and seeing what will remove it from the cloth. I like the idea of using the cloth. I'm also making some test lay-ups using pieces a 2 layer laminate I made up some time ago so it's fully cured like the stab shell. I'm going to use one lightly coated, one with a good dose and a control with none. Then I'm going to try an acetone wash on another that has received a good dose. IOW Trying them in various states of clean up and using different methods. As it's a hydrocarbon it appears the critical areas that are open (top of the shear web and ribs *should* be relatively easy to clean. Those areas that are difficult to reach were also some what sheltered. I may have to open up the edges of the ribs and shear web a little in the areas of the reinforcements, which is where the other bonding must take place. First thing that comes to mind is good old hot water and soap, after Water is one of the things they recommend staying away from until all the laminates are done. It causes any exposed glass to deteriorate. Although a wash and dry shouldn't hurt anything as long as the water is removed soon. that I would slowly move up the solvent ladder, taking care to use non-oily solvents (i.e. no turps, mineral spirits). The first would be alcohol. Alcohol should be a good one as it also removes water. Hexane has been recommended, but I'm not sure how readily obtainable it may be. I'm going to try the one drug store than carries reagents for a local company. Yours Vern Thanks, Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
| Fiberglass / Mold release advice requested | Mark Zivley | Home Built | 10 | April 3rd 04 12:15 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
