Drag Reduction Thru Aero Deturbulators
Old July 11th 05, 05:43 AM
Default Drag Reduction Thru Aero Deturbulators
The June-July issue of Gliding Kiwi features an enlightening article
about the developement of a new very thin surface mounted passive strip
that promises to reduce aerodynamic skin friction drag significantly.
The article is complete with photographs, preliminary flight test data,
and explanations as to the functioning of the deturbulator. It is being
tested on both a sailplane and a light powered airplane.
Most of this article, and more recent updates can be seen by going
to: http://www.sinhatech.com/.
Dick Johnson
Old July 11th 05, 12:29 PM
For those interested you can view the full text patents that relate to Dr
Sinha's work. These provide further technical detail on how the deturbulator
strip works.
References are listed on:
http://www.sinhatech.com/SinhaBackground.asp
per Dick Johnson's post.
Then go to:
http://patft.uspto.gov
and do a search ... you will find the patent listed on the above page + some
other associated patents that were not referenced above. I was unable to
located the two patent applications listed on Dr Sinha's web site. If anyone
can find them please post the details here. Alternatively the patents may
have been issued .. needs more research.
You need to download and install a TIFF plugin for your web browser to view
the patents but that is no big deal.
Steve
Dick Johnson
Data wanted on wheel pants drag reduction [email protected] Home Built 2 May 22nd 05 04:02 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 09:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 01:18 AM
Did we decide if ballasted pullups are higher???????? Lars Peder Hansen Soaring 22 October 8th 03 01:45 AM
