Seat Belt Age?
Old July 6th 03, 05:37 PM
BD5ER
Default Seat Belt Age?
~$300. Are there any other cheaper ratcheting seatbelts out there?
There are some things in this world that you just should not be judged only on
price.
Among these are your:
Personal defense pistol
Body armor
Parachute
Fire extinguisher
Lasix surgeon
Climbing rope..............
Your safety restraint system is in the same class. When you need it and it
fails you really wish you had bought the better one - at least for a few
seconds. While anything is better than nothing sometimes there is no
substitute for the best.
Old July 6th 03, 09:25 PM
Bart D. Hull
I would definitely suggest a replacement.
Here in Arizona we have had problems with seatbelts on the older cars
breaking. Mostly the thread that holds them together rots out and the
whole shooting match falls apart when you try to put it on.
For Racing purposes the belts are only good for one year due to stress
and if your involved in a roll over or other major incident you must
replace them as well. I figure in a airplane the belts get more use and
a bit more wear and tear due so I'd definitely replace them more often.
That said, our local upholstery shops make up replacement belts and sew
them together with kevlar thread on industrial sewing machines. They are
probably stronger than the original belts.
Bart D. Hull
Tempe,Arizona
Check
http://www.inficad.com/~bdhull/engine.html for my Subaru Engine
Conversion
Check http://www.inficad.com/~bdhull/fuselage.html for Tango II I'm
building.
VTflyer wrote:
I have a seat belt and shoulder harness that was made in 1958. Should I
replace it based on age? The webbing feels somewhat hard in the places
where it is looped through the fittings and sewn to itself. Must harder
than other seatbelts I've seen. It was made by Atchison Leather Products
and is a Standard V Type MS 6068-V383(17) 52951 A. Could anyone suggest a
modern equivalent?
I was thinking about a ratcheting Hooker but the cost is a little steep at
Bart D. Hull
Tempe,Arizona
Check
Conversion
building.
Of parachutes and things ShawnD2112 Aerobatics 34 July 21st 04 06:13 PM
Used Strong 304 seat parachute dmayer Aerobatics 0 January 23rd 04 07:53 PM
Pitts Seat Mod Martin Morgan Aerobatics 0 November 21st 03 03:56 AM
Hard Core homebuilders... Prglgw Home Built 6 July 7th 03 04:13 AM
