These are the most wonderfully engineered oleo struts in the world. They
are easy to rebuild and easy to service. Filling one with 5606 hydraulic fluid, however, is not best done by the book. You slip a tube which fits tightly over the schrader (with the stem removed) and the other end of the tube into your can of red hydraulic fluid. Then you pull out the collapsed strut to its full extension, thereby sucking 5606 fluid into the hollow strut. Extend and collapse the strut several times until you have filled it so no more air comes out of the strut, only red fluid. Make sure the strut is collapsed and yet full to the brim with 5606. Then you put the stem back in, screw it down for a good seal, and pump dry nitrogen through the schrader until the airplane's nose comes up to the desired level. If you pump it up too high, you'll overstress the strut and you CAN break it with a hard landing, or in sod because of the long arm. Nitrogen, an inert gas, keeps the inside of the strut from corroding. |
I don't understand what advantage this has over simply deflating the strut,
removing the schrader fitting, filling it to the brim with 5606, replacing the schrader, and pumping it with a gas (air or nitrogen). You can argue for nitrogen if you want, but the sloshing of the 5606 inside that strut keeps it pretty well oiled for plain old air. Besides, nitrogen comes out the spigot at a pretty good pressure, and you can adjust an air compressor down to where it won't blow the piston out the bottom of the strut. Jim " jls" wrote in message .. . These are the most wonderfully engineered oleo struts in the world. They are easy to rebuild and easy to service. Filling one with 5606 hydraulic fluid, however, is not best done by the book. You slip a tube which fits tightly over the schrader (with the stem removed) and the other end of the tube into your can of red hydraulic fluid. Then you pull out the collapsed strut to its full extension, thereby sucking 5606 fluid into the hollow strut. |
![]() "RST Engineering" wrote in message ... I don't understand what advantage this has over simply deflating the strut, removing the schrader fitting, filling it to the brim with 5606 That will work just fine if you can get the fluid to it, way back there on the firewall behind the mags and alternator and all those wires, without making a mess. , replacing the schrader, and pumping it with a gas (air or nitrogen). You can argue for nitrogen if you want, but the sloshing of the 5606 inside that strut keeps it pretty well oiled for plain old air. OK. Besides, nitrogen comes out the spigot at a pretty good pressure, and you can adjust an air compressor down to where it won't blow the piston out the bottom of the strut. We use nitrogen by adjusting the pressure with a relief valve upstream of the schrader before inflating the strut. Nitrogen is cheap and so is the relief valve. A nitrogen bottle without a relief valve could be dangerous, or I guess even more dangerous than it already is because of the high pressure. Have a good cross-country, now, heah? Jim " jls" wrote in message .. . These are the most wonderfully engineered oleo struts in the world. They are easy to rebuild and easy to service. Filling one with 5606 hydraulic fluid, however, is not best done by the book. You slip a tube which fits tightly over the schrader (with the stem removed) and the other end of the tube into your can of red hydraulic fluid. Then you pull out the collapsed strut to its full extension, thereby sucking 5606 fluid into the hollow strut. |
![]() I don't understand what advantage this has over simply deflating the strut, removing the schrader fitting, filling it to the brim with 5606, replacing the schrader, and pumping it with a gas (air or nitrogen). You can argue for nitrogen if you want, but the sloshing of the 5606 inside that strut keeps it pretty well oiled for plain old air. Besides, nitrogen comes out the spigot at a pretty good pressure, and you can adjust an air compressor down to where it won't blow the piston out the bottom of the strut. Jim We can all invent our own way of maintaining an airplane, but the approved proceedures and materials, what ever they are, are in the airframe maintenance manual. I don't know how Cessna built these, but some struts have metering pins or other devices that won't allow them to be completely filled unless they are extended first. Do what the manufacuter says and you won't get in to trouble. Ever seen water come out of your air compressor? Ever seen an aluminum strut tube corrode from water mixed with the fluid? I've seen both. Nitrogen is cheaper than struts. Why bother changing engine oil if the airplane's been setting for six months? Lots of oil sloshing around in there. Why don't you just recommend commercial hydraulic fluid? It's cheap and you can get it everywhere. Works fine in tractors so it must be OK in an airplane!! |
![]() "Don Hammer" wrote in message news:1121355676.d3689304ec05d387a512c3739194101f@t eranews... We can all invent our own way of maintaining an airplane, but the approved proceedures and materials, what ever they are, are in the airframe maintenance manual. I don't know how Cessna built these, but some struts have metering pins or other devices that won't allow them to be completely filled unless they are extended first. Do what the manufacuter says and you won't get in to trouble. See Cessna Service Manual section 2-18. Don't you think Clyde's boys know what they are talking about when they write a manual? Don't post out of ignorance. Ever seen water come out of your air compressor? Ever seen an aluminum strut tube corrode from water mixed with the fluid? I've seen both. Nitrogen is cheaper than struts. Why bother changing engine oil if the airplane's been setting for six months? Lots of oil sloshing around in there. Ever seen an A&P's shop that doesn't have a water trap on the compressed air? Why don't you just recommend commercial hydraulic fluid? It's cheap and you can get it everywhere. Works fine in tractors so it must be OK in an airplane!! Damned fool. Jim A&P/IA |
![]() See Cessna Service Manual section 2-18. Don't you think Clyde's boys know what they are talking about when they write a manual? Don't post out of ignorance. Don't have the manual. Guess it says to use compressed air and not nitrogen huh? My point is I see lots of posts from "experts" here that lead people down a not-so-good path. What I said stands - Do what is in the maintenance manual and you can't go wrong. Am I not correct? |
Out of the 100-series service manual.
I'll do this in some abbrvtd method (I don't type more than I have to): quote on 1. Remove valve cap and release all **AIR** (emphasis mine) 2. Remove valve housing 3. Compress strut completely 4. Fill strut with hydraulic fluid to valve hole 5. Get nose wheel off the ground 6. Replace valve housing and inflate: 35 psi (or 20 psi on the 150 and 50 psi on the 182 both models after the 1961 model year) quote off Note they said to release AIR and not nitrogen. They don't specify WHAT to inflate with, so it is left to the A&P to determine the correct gas. However, you might infer from the first instruction that they expect air. Jim "Don Hammer" wrote in message news:1121375152.eb841dd4e866bfcb751910a2ac0e0572@t eranews... Don't have the manual. Guess it says to use compressed air and not nitrogen huh? |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Products | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
