When my Crown trailer ramp is fully lowered my ASW-20 fuselage does not
clear the dolly cradle. Furthermore the scissors jacks require excessive torque from the fully lowered position. Currently I roll the main wheel up a small wooden ramp to raise everything a few inches. I'm interested in other solutions. In particular does anyone have experience with the screw jack ramp arrangement described on the Cobra web site? Since a Cobra or Komet ramp won't directly apply to my trailer I'm considering building my own such ramp. Does anyone have a source for this type of screw jack in the USA? I have seen similar jacks used in some older European cars. My web searches on "screw jack" only return very large capacity equipment. http://www.cobratrailer.de/english/index.html The illustration opposite shows different versions of lift ramps for the fuselage: ...a version with screw jacks, especially useful for gliders with low fuselage... |
"Papa3" wrote
scissors jack suffers from the fact that the lift vector is at a miniumum when fully compressed - ie. just when we need it most in I use a horizontal hydraulic cylinder and the upper part of a scissors jack. Erik is still right about the lift vector, but you can gain a little over a real scissors jack. My ramp cannot tilt, so lifting in the middle only works well for me. /\ --- / \ Michael |
![]() What's so wrong with using the wooden ramp? I use this solution for my ASW15/Avionic setup and in my club we also have ASW19/Komet, ASW20/Komet and ASW20/Cobra combinations all using a small wooden ramp. The Waibel designs (except the ASW12) all seem to combine a fairly low landing gear with a drooped front fuselage which makes it hard to get the dolly low enough to clear. I think it's a lot easier just to keep things the way they are. |
Trailer hitch inadvertant disconnect | Bill Daniels | Soaring | 5 | July 16th 04 03:17 AM |
Trailer spare - who woulda thunk? | Bill Daniels | Soaring | 7 | May 20th 04 04:47 PM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
Tire Stiffness & trailer swaying | chris | Soaring | 42 | October 22nd 03 03:51 AM |
Importing a glider | Gus Rasch | Soaring | 7 | August 13th 03 10:34 PM |
