Mooney Low Voltage
Old July 27th 05, 02:15 PM
Default Mooney Low Voltage
Can anybody help me diagnose this problem? Just bought my new (to me)
1978 Mooney 201, flew it back from Kansas City to Atlanta, no problem.
Flew to Richmond, VA - again no problem. Leaving RIC for Atlanta, the
low voltage light started flashing. Didn't want to carry on IFR so
stopped into Danville. Left the plane there, and the mechanic removed
the altinator and tested it (all ok) and replaced the voltage regulator
with a new one. All ok (charging 13.9 volts). Started the plane, the
altinator gauge was showing a charge, and took off. About 30 mins into
the flight again the low voltage started flashing. By the time I had
checked all the CB's it stopped. Then about an hour later it started
again. I tried pulling the Alt Field CB and resetting, no joy. It
continued to flash untill I was in the pattern at LZU.
So, now - what next? Bad Diodes on the Altinator breaking down at
altitude?(I was at 8000'), loose altinator belt? (unlikely - it had
just been reinstalled). Over voltage on the Altinator causing the
Voltage reg to drop off line, and I didn't wait long enough when I
reset the Alt-Field circuit breaker? Bad ground straps??
Any and all thoughts welcomed at this point - this is the worst kind of
problem to hunt down.
Thanks
Ian
Old July 27th 05, 02:45 PM
Battery is almost new (I believe it was replaced last year, or the year
before). It cranks just fine - I have never had any feeling that I was
running out of juice. Of course, the plane is starting first time!
According to the manual, the low volage would flash if the altinator is
not delivering a charge. That is what is leading me in that direction.
Old July 27th 05, 02:44 PM
Michelle P
Check all of your ground connections first. Disconnect them all and
clean them.
Diodes do not break down with altitude. They are sealed. They will break
down with heat. Once they break down they are dead. The do not fail
intermittently. The brushes may be an issue though. Is the Alternator
getting enough air? Mine overheated until I installed a blast tube.
Michelle
Thanks
Ian
Old July 27th 05, 02:48 PM
Thanks for that. Heat might be an issue - I had to crack the cowl flaps
open to keep the cyl head temps down yesterday - it was 10C at 8000'!
How did you install a blast tube?
Old July 27th 05, 07:16 PM
Michelle P
SInce you mentioned an alternator belt. I am assuming it is a Lycoming
with the alternator up front.
My new alternator came with the blast attachment on the back of the
unit. We ran a 1" hose to the front of the cowling. A flange may be
necessary for your installation. Mine is attached under the air filter
housing. Just under the engine air intake.
Michelle
Old July 27th 05, 07:25 PM
David Lesher
Michelle P writes:
clean them.
What the woman said. Grounds are the #1 cause of intermittent problems.
Also, how do you KNOW you have a problem; besides, that is. a flakey
LV warning? Put a DVM on the bus for a flight.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old July 28th 05, 01:08 PM
Denny
B I N G O !
Actually, one of those analog voltmeters from the auto store that you
plug into the cigarette lighter should be in everyone's airplane...
Also, does your GPS show voltage? The Garmin 295 does, and perhaps
others...
denny
Old July 28th 05, 04:08 PM
Thanks for all the advise folks. If I check the voltage at the
cigarette lighter - any idea what it should be? What voltage would
cause the warning light to illuminate? (12,11, 10?).
I am going out to work on the plane tonight (first the ground straps
then go fly with a voltmeter). I'll let y'all know how it turns out...
Landing a Mooney Jon Kraus Owning 42 November 16th 04 07:00 PM
Landing a Mooney iain_hutchison Piloting 0 November 4th 04 02:38 PM
Mooney M20 K on Grass ? Andrew Boyd Owning 0 August 13th 04 03:00 PM
Loading luggage in other than Mooney Robert M. Gary Piloting 21 June 28th 04 06:23 PM
Anyone have experience with InterAv alternator flyer Home Built 6 October 19th 03 03:24 AM
